Register to reply
Conversion between density and column density
by bagherihan
Tags: column, conversion, density
Share this thread:
bagherihan
#1
Jul18-14, 05:27 AM
P: 7
What's the way to convert n(r) to [itex] \rho(r) [/itex] in case of a spherical cloud.
n(r) is the column density, [itex] \rho(r) [/itex] is the density.
I tried (but didn't manage) to get it from their relation to the total mass:
[itex] M = 4 \pi \int r^2 \rho(r)dr = 2 \pi \int r n(r)dr [/itex] (is it correct anyway?)
Thank you,
Phys.Org News Partner Astronomy news on Phys.org
Chandra X-ray Observatory finds planet that makes star act deceptively old
Astronomers release most detailed catalogue ever made of the visible Milky Way
Planets with oddball orbits like Mercury could host life
Simon Bridge
#2
Jul18-14, 07:45 AM
Homework
Sci Advisor
HW Helper
Thanks
Simon Bridge's Avatar
P: 13,067
In general, no there isn't.
The reason being that the column density calculation hides information.
But if you know the density distribution has a special symmetry - i.e. it is radial, then you may be able to.
In this case it appears you have a cloud whose density function depends on on the distance from the center.
\rho(r) is the density of the cloud a distance r from the center, so the mass of the spherical shell between r and r+dr is dm = \rho (4\pi r^2 dr) so the total mass is the integral over all radii. See how that works?
This is r in spherical coordinates.
To get to the column density, you need to convert to cylindrical coordinates.
This is because the column at a horizontal distance r from the center, area dxdy (say) will have a different density for different z values (since different z values will have different spherical r values)
It should be clearer if you use a different symbol for r in the two equations.
Register to reply
Related Discussions
Density Column, Need Polar/Nonpolar Examples Chemistry 0
Help on conversion of units (density) Introductory Physics Homework 2
Finding density of air in air column from just pressure? Introductory Physics Homework 2
Unit conversion/density Introductory Physics Homework 1
Density conversion Chemistry 4
