Circular kinematics a star in orbit around another star.
In summary, a star has a mass of 2.96 x 10^30 kg and is moving in a circular orbit about the center of its galaxy. The radius of the orbit is 3.3 x 10^4 light-years (1 light-year = 9.5 x 10^15 m), and the angular speed of the star is 1.6 x 10-15 rad/s. The tangential speed of the star is 501600 m/s, and the magnitude of the net force that acts on the star to keep it moving around the center of the galaxy is 2.38 x 10^21 N.
lalalah
i got part a, but i can't get part b!
1. A star has a mass of 2.96 x 10^30 kg and is moving in a circular orbit about the center of its galaxy. The radius of the orbit is 3.3 x 10^4 light-years (1 light-year = 9.5 x 10^15 m), and the angular speed of the star is 1.6 x 10-15 rad/s. (a) Determine the tangential speed of the star. (b) What is the magnitude of the net force that acts on the star to keep it moving around the center of the galaxy?
F_c = m * a for centripetal force
a_c = V^2 /r
I'm not sure if my idea for part b is right.
For part A, i got 501600 m/s.
I was wondering if the answer to part b would be attained by:
a_c = v^2 /r
a_c = 501600^2 / radius of orbit
using the radius of orbit given in the problem.
... and then, taking the calculated value for a_c and multiplying it by the given mass to give the F_centripetal.
is this correct reasoning? and sorry! my scientific calculator is located miles away, and my computer's calculator is a bit slow so i would rather punch in everything in the morning...
thanks!
Yes, your method is completely valid.
awesomeee. thanks for your help!
ackkkk...
so when i punched out the answer, i got 2.38 x 10^21 N, and naturally, it doesn't fit in the answer type-in box! does anyone know if i did anything wrong? maybe my part a wasn't as correct as i thought it was...
i calculated part a using
V_t = w * r,
r = 33,000 Light years * (9.5 x 10^15 m)
r = 3.135 x 10^20
w = the given angular speed 1.6 x 10^-15
using the above equation, i got V_t = 501600.
is any of my work flawed whatsoever? eek!
ahhhhhhh... so i found out that i should have punched in the answer as 2.4E21 instead of trying all the zeros! I'm an idiot. but thank you for all of the help! :)
1. What is circular kinematics?
Circular kinematics is the study of motion in a circular path. It involves analyzing the position, velocity, and acceleration of an object as it moves in a circular orbit.
2. How does a star orbit around another star?
A star orbits around another star due to the force of gravity between the two objects. The larger star exerts a stronger gravitational force, causing the smaller star to follow a curved path around it.
3. What factors affect the orbit of a star?
The orbit of a star is affected by the mass of the two stars, the distance between them, and the velocity of the star. These factors determine the shape, size, and speed of the orbit.
4. What is the difference between circular and elliptical orbits?
A circular orbit is perfectly round and has a constant distance between the two stars, while an elliptical orbit is oval-shaped and has varying distances between the two stars. Circular orbits are also considered a special case of elliptical orbits.
5. Can a star's orbit change over time?
Yes, a star's orbit can change over time due to external forces such as the gravitational pull of other stars or planets. These changes can cause the orbit to become more elliptical or even send the star out of orbit entirely.
  • Astronomy and Astrophysics
