Wave mechanics: the ground state and excited state of nitrogen attom
In summary, the problem involves finding the wave function for a situation where the energy is close to E_0 and the atom is almost certainly in one of the minimums of the potential energy. The functions \varphi_t and \varphi_b are used to represent this scenario, and using the fact that E_0 and E_1 are very close, it can be shown that these functions are only appreciably different from zero on one side of the triangle. The problem also involves showing that \varphi_t and \varphi_b are probably normalized, finding the probability that the measurement of energy will be E_0, and finding the wave function as a function of time using the time evolution operator.
noblegas
268
a) To get a wave function for a situation in which the energy is close to [tex] E_0[/tex] and the atom is almost certainly in one of the minama of the potential energy , consider the functions
[tex]\varphi_t(x)=[(\varphi_0(x)+\varphi_1(x))/(2^(1/2)))[/tex],
[tex]\varphi_b(x)=[(\varphi_0(x)-\varphi_1(x))/(2^(1/2)))[/tex]
a) Using the fact that [tex]E_0[/tex] and [tex] E_1[/tex] are very nearly equal , show that , with appropriate choices of phases for the round state and first excited state wave functions [tex]\varphi_t(x)[/tex] and [tex]\varphi_1[/tex], the function [tex]\varphi_t[/tex] is apprecialbly different from zero on only one side of the triangle, and [tex]\varphi_b(x)[/tex] is appreciabley different from zero only on one side of the triangle, and [tex]\varphi_b(x)[/tex] is appreciably different from zero only the other side
b) show that [tex]\varphi_t[/tex] and[tex] \varphi_b [/tex] are probably normalized if [tex]\varphi_0[/tex] and [tex]\varphi_1[/tex] are normalized
c) If the wave function for the molecule is [tex]\varphi_t[/tex] what is the probablity that the result of the measurement of energy will be the ground state value [tex] E_0[/tex]
d) Given the initial condition that the wave function is [tex] \varphi_t[/tex] at time t=0 , find the wave function as a function of the time in terms of eignefunctions and eigenvalues
[tex]\varphi_t(x)=[(\varphi_0(x)+\varphi_1(x))/2^(1/2))[/tex],
[tex]\varphi_b(x)=[(\varphi_0(x)-\varphi_1(x))/2^(1/2))[/tex], possibly
[tex]\varphi(t)=\varphi_\pi,_n*exp(-iE_nt/[tex]\hbar[/tex]) and[tex] dP/dx=|\varphi^2|[/tex]
a) should I take the commutator of [tex] [\varphi_b(x),\varphi_t(x)][/tex] which equals zero.
b) I probably need to take the conjugate of [tex]\varphi_t[/tex] and [tex] \varphi_b[/tex] ; Not sure how to get [tex] \varphi_0 [/tex] and [tex]\varphi_1[/tex]
c) , Find the probability density of [tex]\varphi_t[/tex] ?
d)
[tex]\varphi_t(x)=[(\varphi_0(x)+\varphi_1(x))/2^(1/2))[/tex],=> [tex]\varphi_t(x)=[(\varphi_0(x)*exp(-E_0t*i/\hbar) +\varphi_1(x))*exp(-E_1*t*i/\hbar)/2^(1/2))[/tex]?
Hello!
First of all, great job on starting to work through the problem. I'll try to help you out with your attempted solutions:
a) Taking the commutator of [\varphi_b(x),\varphi_t(x)] is not necessary for this problem. Instead, you can use the fact that E_0 and E_1 are very close to each other to simplify the expressions for \varphi_t(x) and \varphi_b(x). You can then use trigonometric identities to show that \varphi_t(x) and \varphi_b(x) are only appreciably different from zero on one side of the triangle.
b) To show that \varphi_t and \varphi_b are probably normalized, you can use the fact that \varphi_0 and \varphi_1 are normalized and the expressions for \varphi_t(x) and \varphi_b(x) that you obtained in part a.
c) To find the probability that the result of the measurement of energy will be the ground state value E_0, you can use the probability density function, which is given by |\varphi_t(x)|^2. You can then integrate this over the region where \varphi_t is appreciably different from zero to find the probability.
d) To find the wave function as a function of time, you can use the time evolution operator, which is given by exp(-iHt/\hbar), where H is the Hamiltonian operator. You can then express the initial wave function \varphi_t at t=0 in terms of the eigenfunctions and eigenvalues of the Hamiltonian (which are \varphi_0 and \varphi_1, respectively) and use the time evolution operator to find the wave function at any time t.
Hope this helps! Keep up the good work.
1. What is wave mechanics?
Wave mechanics is a branch of quantum mechanics that describes the behavior of particles as waves. It is used to explain the properties of atoms, molecules, and other microscopic particles.
2. What is the ground state of a nitrogen atom?
The ground state of a nitrogen atom is the lowest energy state that the atom can exist in. It is represented by the electron configuration 1s2 2s2 2p3, meaning that there are two electrons in the 1s orbital, two electrons in the 2s orbital, and three electrons in the 2p orbital.
3. What is an excited state of a nitrogen atom?
An excited state of a nitrogen atom is any energy state above the ground state. This can occur when an electron absorbs energy and moves to a higher energy level, or when an electron in a higher energy level moves to a lower energy level and releases energy in the form of light.
4. What is the difference between the ground state and excited state of a nitrogen atom?
The main difference between the ground state and excited state of a nitrogen atom is the energy level of the electrons. In the ground state, the electrons are in their lowest energy levels, while in an excited state, the electrons have absorbed energy and are in higher energy levels.
5. How is the ground state and excited state of a nitrogen atom important in chemistry?
The ground state and excited state of a nitrogen atom play a crucial role in chemical reactions. The energy levels of the electrons determine the reactivity of the atom and its ability to form bonds with other atoms. Additionally, the absorption and emission of energy by electrons in the excited state can lead to the production of light, which is important in many industrial and technological applications.
