Time to reach thermal equilibrium and/or a steady state
In summary, the spherical sample takes 5-10 seconds to reach thermal equilibrium in an oven where the temperature is held constant. The heat transfer coefficient, h, can be determined using the lumped capacity method.
geo101
56
I want to calculate the time it takes for a spherical sample (radius, r) to reach thermal equilibrium in an oven where the temperature is held constant.
I don’t need a super accurate answer, within 5-10 seconds is sufficient. Is it reasonable to simply say that when the Fourier Number (Fo) is 1 that the system is almost in a steady state and almost in equilibrium? Or does Fo have to be higher to make this assumption? I read somewhere that Fo = 1 equates to an energy transfer of ~97%, is this true? (There was no reference given).
Cheers
Science news on Phys.org
First try the lumped capacity method. See Equation 6.9 in:
http://ec.pathways-news.com/Text-PDF/Part B-6.pdf
Check your Biot number is within limits (Equation 6.15), or your result will not be very accurate.
If your Biot number is out of range, let me know - there are other (more complex) models to treat this case.
Thanks for the reply. Is there another link to the PDF? The link you posted doesn’t work for me, but I am in living China so many it is not too much of a surprise.
I know very little about thermodynamics and my hope of a simple solution may not be so simple. For the lumped capacity method is the solution what is on the wiki page? http://en.wikipedia.org/wiki/Lumped-capacitance_model#Solution_in_terms_of_object_heat_capacity
For this and the Biot number I need h, the heat transfer coefficient. On wiki this is describes in terms of convective heat transfer, so should I use the value for the media? In this case it is air (10-100 W m^-2 K^-1).
Thanks again for the help
For your heat transfer coefficient h, use the T. Yuge correlation for external flow on a sphere in the wiki link:
NuD = 2 + 0.43 RaD^1/2
Your Rayleigh number is a function (amoung other things) of the temperature difference between the surface and external. So this also varies with time.
To get started and learn the method, assume RaD = 0, and thus NuD = 2. This will overestimate the heatup time. When you get comfortable with this, you can include the Rayleigh number in the treatment.
Thanks for the info. I haven't had a chance to work on this yet, but I'll let you know how it goes (hopefully by the end of the week). Rayleigh and Nusselt numbers are ringing old bells (I did an undergrad degree in Geophysics where they are used in core and mantle dynamics).
Cheers
OK, so I have found some time to crunch through this in more detail.
The furnace cavity is cylindrical with diameter, D = 0.1 m, and length > D (more than 10 times D). The furnace is held at constant temperature, [itex]T_{env}[/itex]= 873 K. A spherical sample of radius = 0.0125 m at temperature, [itex]T_{samp}(t=0)[/itex]= 293 K is "instantaneous" introduced into the furnace with no heat loss.
So the Rayleigh Number, [itex]\mathrm{Ra}[/itex], (when [itex]\mathrm{Pr}=1[/itex]) is given by:
[itex]\mathrm{Ra} = \mathrm{Gr}= \frac{g \beta} {\nu^2} (T_{env} - T_{samp}) D^3[/itex]
To first order I assume that [itex]\beta[/itex] and [itex]\nu[/itex] are temperature independent and values for air at 873 K are used (1.17e-3 [itex]K^{-1}[/itex] and 98.65e-6 [itex]m^2s^{-1}[/itex], respectively)
Following the equation for [itex]\mathrm{Nu}[/itex], the heat transfer coefficient, [itex]h[/itex] can be determined by:
[itex]h=\frac{\mathrm{Nu}k}{L}[/itex],
where k is the thermal conductivity of the sample (taken to be ~2.5 [itex]W.m^{-1}.K^{-1}[/itex] for a basalt sample). Should this be for air?
L is the characteristic length scale, here I use the ratio of the sample volume/area [itex]\left(L\approx{\frac{V}{A}}\right)[/itex].
The solution to the lumped capacity method is given by:
[itex]T_{samp}(t) = T_{env} + (T_{samp}(0) - T_{env}) \ e^{-r t}[/itex],
where [itex]r=\frac{hA}{C_p\rho{}V}[/itex].
My sample is a basalt so...
The mass specific heat capacitance, [itex]C_p=1200 J. K^{-1}. kg^{-1}[/itex]
and the density, [itex]\rho{}=2800 kg. m^{-1}[/itex]
Again, these are assumed to be invariant of temperature.
Still following me? I'll admit it's interesting learning this stuff! :smile:
Using the above I calculate Ra(t=0) = 685730 and h (t=0) = 35.9.
By t = 1000 s, Ra(t=1000) = 114221, h (t=1000) = 24.8, and [itex]T_{samp}[/itex](t=1000) = 776.5 K.
And by t = 2000 s Ra(t=2000) = 38227, h (t=2000) = 20.0, and [itex]T_{samp}[/itex](t=2000) = 840.8 K.
Since Ra, and hence [itex]r[/itex], depend on [itex]T_{samp}[/itex] I evaluate [itex]T_{samp}(t_n)[/itex] using [itex]r(t_{n-1})[/itex] and use 50 s time steps. This will introduce an error, which will be reduced as the time steps decrease, correct?
Are these reasonable values? They seem OK to me. But am I using the appropriate values? By that I mean, am I making the correct distinction between fluid (air) and sample (rock) properties in the equations?
I know I skipped ahead of the simple example you suggested, but I find it easier to learn by applying methods to more realistic situations, assuming of course I have done it correctly.
If I am on the correct track then I will build in the temperature variation of the "constants" ([itex]\beta[/itex] and [itex]\nu[/itex]). Should these be evaluated at
[itex]T_f=\frac{T_{samp}+T_{env}}{2}[/itex]?
Also, in the strictest sense, the furnace cavity is cylindrical (so is the sample) and [itex]\mathrm{Pr}\neq1[/itex]. Would it then be more appropriate to calculate h using:
[itex]h = \frac{k} {D}\left({0.6 + \frac{0.387 \mathrm{Ra}^{1/6}}{\left[1 + (0.559/\mathrm{Pr})^{9/16} \, \right]^{8/27} \,}}\right)^2[/itex]
Cheers for all the help so far!
1) What is thermal equilibrium and why is it important in science?
Thermal equilibrium is a state in which two or more substances have reached the same temperature and there is no net flow of heat between them. It is important in science because it allows for accurate measurements and predictions of energy transfer and helps in understanding the behavior of systems.
2) How long does it take for a system to reach thermal equilibrium?
The time it takes for a system to reach thermal equilibrium depends on various factors such as the size and composition of the system, the surrounding temperature, and the materials involved. It can range from a few seconds to hours or even days.
3) What is the difference between thermal equilibrium and a steady state?
Thermal equilibrium refers to a state in which there is no net flow of heat between substances, while a steady state refers to a condition in which a system's properties do not change over time. A system can be in thermal equilibrium without being in a steady state, and vice versa.
4) How does energy transfer occur in a system that has reached thermal equilibrium?
In a system at thermal equilibrium, energy transfer occurs through conduction, convection, or radiation. These processes continue to occur, but they are balanced so that there is no net transfer of heat between substances.
5) Can thermal equilibrium ever be achieved in an isolated system?
No, thermal equilibrium cannot be achieved in an isolated system as there is no external energy source to maintain the balance of energy transfer. Eventually, the system will reach a state of maximum entropy and no longer be in thermal equilibrium.
  • Thermodynamics
12K
  • Mechanical Engineering
