At what probability is it rational to look for paranormal explanations?
In summary, you're flipping a quarter while your friend guesses which side will come up. You agree to switch turns after one incorrect guess each.He gets 2 in a row right before guessing wrong, and now it's your turn.You incorrectly guess the outcome of the first flip he does, and now it's his turn again.He guesses 250 flips correctly before you give up (132 heads, 118 tails). You're absolutely dumbfounded and check the coin again just to reassure everything is right.What do you conclude has happened (What's the most likely explanation)?How many correct guesses would your friend have to make in a
Firefight
You're about to flip a quarter while your friend guesses which side will come up. You agree to switch turns after one incorrect guess each.
How many correct guesses would your friend have to make in a row in order for you to stop believing it was chance based?
The chance of correctly guessing 250 coin flips in a row on one try is 2^250 or 1 in 1.8*10^75Assumptions:
You start triple checking everything and flipping at different speeds past flip 15 to ensure 'randomness' and minimal human error.
Your friend is not manipulating the coin in any predictable way below a success ratio of 1:1.85.
blank edit.
Assumptions:
This is an interesting scenario.
In terms of likelihood estimation, if you used an MLE approach, your proportion parameter would end up being close to 1 instead of 0.5.
If you wanted to do inference that the true underlying population parameter was 0.5 given the sample, it would be highly unlikely. (It's not improbable, just implausible).
But you need to remember that this information does not give any information about the mechanics of the actual underlying process, and I think this is what you are trying to focus on.
In terms of the mechanics of the process, you need to focus not on the data (which is what you are doing in probability/statistics), but on the process itself.
In doing this, there could be a number of avenues to take. You might think about a physical explanation by using mathematical modelling to generate results using various parameters along with initial conditions.
You might also present something more 'esoteric'. It could be based on something that is independent of the physical parameters of the coin, like the 'paranormal' element. It might even be a combination of the two.
Statistics doesn't really shed insight into actual processes in the context you are describing (the real mechanics of the process). It can only make inferences on things that are probabilistic.
The big thing I see is choosing a model that finds a perfect (or good enough) fit between complexity and accuracy. You can have models that are completely accurate (millions of variables or more), but completely complex (and practically useless), or you can have a model with very few numbers of variables (practical in terms of using the model), but completely useless (doesn't replicate the mechanics of the system in any meaningful way).
Applied mathematics is in one way, centered around the idea of finding a good balance between complexity and useability in the context of replicating the mechanics of a process in a meaningful way.
Reminds me of a surefire way to make some money. You get yourself the names and email addresses of 1024 well-heeled stock market investors. You send half of them an email saying the market will go up tomorrow, and you tell the other half the market will go down.
You'll be right with 512 of the investors. Forget the other ones. You send half of the remaining 512 an email saying the market will go up tomorrow, etc.
Eventually you'll have made ten accurate market predictions in a row to one investor. You send that investor an email saying, "Ok I proved myself to you. I just sent you ten accurate predictions in a row. Would you like to subscribe to my private mailing list? Only cost you $100k."
He sends you the money and from now on you send him predictions that are right by chance only half the time.
It's really not difficult to make correct predictions of random events ... if you can make a simultaneous strings of predictions to many different people.
Not exactly relevant, but still entertaining to read :p Thanks for the idea. I'm going to try that on a forum in the near future.
Also thanks for the input Chiro.
1. What is the definition of "paranormal"?
Paranormal refers to phenomena or experiences that are beyond the scope of scientific explanation or understanding. These may include ghosts, psychic abilities, and other supernatural occurrences.
2. What is the difference between paranormal and pseudoscience?
The main difference between paranormal and pseudoscience is that paranormal phenomena are not able to be explained by current scientific theories and methods, while pseudoscience is based on claims or beliefs that appear to be scientific but lack evidence or cannot be tested.
3. Can paranormal explanations be considered rational?
The rationality of paranormal explanations is often debated, as they are not supported by scientific evidence. Some individuals may believe in paranormal phenomena based on personal experiences or cultural beliefs, but from a scientific standpoint, they are not considered rational.
4. At what probability does something become considered "paranormal"?
There is no set probability at which something becomes considered paranormal. Generally, if an event or phenomenon cannot be explained by natural or scientific means, it may be considered paranormal.
5. What should be taken into consideration when evaluating the rationality of paranormal explanations?
When evaluating the rationality of paranormal explanations, it is important to consider the evidence and scientific principles. This includes looking at the reliability of reported experiences, the plausibility of alternative explanations, and the lack of scientific evidence supporting paranormal claims.
  • Math Proof Training and Practice
15K
15K
