Register to reply
Confusion about force
by Miraj Kayastha
Tags: acccelerating, confusion, force
Share this thread:
Miraj Kayastha
#1
Nov23-13, 08:30 PM
P: 56
I have a confusion:
If we push an object of 10 kg with force of 60N once, does it accelerate constantly with 6m/s/s forever neglecting any resistance ?
So, does this mean if this moving object collides with something the maximum force it applies is 60N?
Phys.Org News Partner Physics news on Phys.org
New study refines biological evolution model
Fiber optic light pipes in the retina do much more than simple image transfer
Production phase for LSST camera sensors nears
JayJohn85
#2
Nov23-13, 08:40 PM
P: 44
I probably shouldn't be answering stuff because I am new too. But I'll have a crack at it anyway.
P=mv where p is momentum and momentum is conserved. However you said it was only pushed once with 60N which makes me wonder if it would have a constant acceleration of 6m/s/s. I would have thought it would require a force acting on it to achieve constant acceleration. Otherwise it may have uniform motion of 6 m/s meaning 10kg multiplied by 6 which equals 60N.
In that case yes it would hit something with 60N of force. But I am assuming this is a object in space with no resistance or opposing forces acting on it.
Nugatory
#3
Nov23-13, 10:08 PM
Sci Advisor
Thanks
P: 3,406
Quote Quote by Miraj Kayastha View Post
I have a confusion:
No, it accelerates at that rate for as long as the force is applied, and when the force is no longer applied it stops accelerating and coasts along at whatever speed it reached while the force was being applied. In your example, the acceleration is ##\frac{6m}{sec^2}##, so if the force is applied for five seconds, the object will be moving at 30 m/sec.
No. The force applied in the collision depends on the deceleration. If our object collides with something very hard and immobile, it might only compress the target by .1 mm before being brought to rest. If our object is moving at 20 meters/sec when it hits and it's stopped cold after covering .1 mm, its average speed during the collision is 10 meters/sec (average of 20 and 0), it takes .00001 seconds to cover that .0001 meters, the deceleration is 2000000 ##\frac{m}{sec^2}##, and the force (which isn't applied for very long - think hammer blow) is 12000000 N.
Repeat this calculation with something soft and squishy, so that it compresses by 10 centimeters, and you'll get a much smaller force.
MHR-Love
#4
Nov24-13, 08:10 PM
P: 15
For your first question, the answer is yes. It will constantly increase its speed but the rate of change of the speed is constant (acceleration is constant).
Jimmy
#5
Nov24-13, 08:35 PM
P: 655
Quote Quote by MHR-Love View Post
You should read the post immediately before yours.
MHR-Love
#6
Nov24-13, 08:39 PM
P: 15
Yes you are right. I've just read it again. It's a bad thing from me not to read the word "once". In this case, Nugatory's answer is correct.
ajayguhan
#7
Nov25-13, 11:40 AM
ajayguhan's Avatar
P: 126
@Nugatory , isn't the force applied is 20000000 and not 12000000 because the mass is 10kg not 6 kg......!
Nugatory
#8
Nov25-13, 12:15 PM
Sci Advisor
Thanks
P: 3,406
Quote Quote by ajayguhan View Post
thanks - good catch.
adjacent
#9
Nov26-13, 06:35 AM
PF Gold
adjacent's Avatar
P: 1,456
Collision force is given by the formula
##F=\frac{mv-mu}{t}##
-Where u=Initial velocity ,v= final velocity
For example,Object was traveling at a constant velocity and has the same.
It gets in contact with a wall or something,the force exerted is determined by the time taken for it to stop.
Register to reply
Related Discussions
Extreme Confusion of centripetal acceleration force and normal force Introductory Physics Homework 1
G-force equation confusion Classical Physics 2
Centripetal force confusion Classical Physics 22
My confusion regarding Force Introductory Physics Homework 42
Normal force confusion Introductory Physics Homework 7
