Magnetic fields of infinite solenoid and infinite current carrying plane
In summary: What this shows is that the electric field at a distance r from the line charge is given by: E_{r} = \frac{1}{2\pi\epsilon_{0}}\frac{\lambda}{s} .
s.gautam
I am following the book 'Introduction to Electrodynamics' by Griffith. In that book,the magnetic field outside an infinite solenoid has been found as follows:
First of all,it is proved that the magnetic field is along the axis. (I have no problems with that proof).
Then,a rectangular loop is taken outside the loop,and since the current passing the loop is 0,it can be said that the magnetic fields along the two sides of the loop parallel to the axes are same.
By this,it can be inferred that magnetic field outside the solenoid is constant.
Now,the problem I have is with the next argument which says that since the magnetic field will decrease to 0 at very large distances from the solenoid,and since the magnetic field outside the solenoid is constant,that means the magnetic field everywhere outside the solenoid is 0.
Now why can't we make the same assumption in case of an infinite current carrying plane (that is,the magnetic field at infinite height from the plane will decrease to 0) ?
(This assumption is wrong because using this we get the wrong answer.)
Gautam, what page are you looking at? I own the Griffiths textbook, so I can take a look at it and provide an explanation.
For the third edition,Pg 228. The line "But we know that it goes to zero for large s".
I had the same issue when reading it, when I asked my prof about it, he didn't give a straight answer. If anyone can give a better reason that the field should be 0 outside, that would be awesome.
OK, I checked it out. Basically it's an argument by symmetry. The system has symmetry along a single axis, and we can intuitively tell that the B field must go down as you get further away from the axis of symmetry. That's why it goes to zero for large s.
Here's a qualitative explanation. Solenoids have the property of containing magnetic fields entirely within their boundaries. For a finite solenoid, the B field will come out of the ends, and so there will be a small magnetic field outside the solenoid. But if you wrap the solenoid into a toroid (=doughnut), the field will stay completely inside. An infinite solenoid can be thought of as a toroid of infinite radius.
...hope that makes sense.
But why should it go to zero for large s? Especially since it's right after the example where it doesn't go to zero (infinite plane current).
I'm not arguing with the result, just the logic used to get there. It seems silly to me that right after doing an example where the field doesn't go to zero at infinity, he assumes that for a given configuration (which also extends to infinity) the field must go to zero.
Yes, I can see the cause of your confusion. The logic here has to do with the symmetry of the problem. The solenoid is essentially a surface current going around a cylinder; thus the problem has symmetry along the axis of the cylinder. But a plane current has an entire plane of symmetry. Furthermore, the cylinder is a three dimensional object, whereas the current sheet is two dimensional. No matter how far you get away from an infinite sheet, the sheet still looks the same size. But a cylinder gets smaller as you go away from it. That's why the magnetic field needs to reduce as you get further away from the cylinder, but not the current sheet.
Make sense this time?
It makes sense, I just don't think it's very rigorous.
As a relation to electrostatics,
Consider an infinitely long and wide charged plane. Clearly (by Gauss's law) the electric field is: [tex] \frac{\sigma}{2\epsilon_{0}} [/tex]. A result that tells us that E is independent of distance from the plane (the reason of which was explained by arunma.)
Now the infinite line charge (similar to say the solenoid now,) has a field given as: [tex] \frac{1}{2\pi\epsilon_{0}}\frac{\lambda}{s} [/tex]. A 1/s dependence that causes it to go to zero as it approaches infinite. This is again explained by arunma's argument that as you approach infinite you'll no longer "see" the line charge.
Yes,I agree with NeoDavin. It makes sense,but its not that rigorous.
I arrive late in this thread.
I do not see why the magnetic field outside an infinite solenoid would be zero. In fact, is it?
If you see from a distance an infinite solenoid, you see an infinite straight wire (you do not see the wire turning). The symmetry is that of an infinite wire and the magnetic field is the same as that of an infinite wire... and different from zero.
As I write his post I see a way to obtain a zero field. You use a solenoid made of two layers of wire. One going and the other coming. Then the net current seen from far away is zero.
In this case, symmetry is respected and you can use Ampere's law. To find B=0 outside the solenoid.
As stated in precedent posts, you cannot argue that "at infinity you don't see an object of infinite dimensions". This is only true for localized charges or currents.
I don't remember seeing a calculus for an infinite solenoid. The catch has been to compute the field inside a toroidal solenoid and, then to say that the field inside is the same if you open and straighten the solenoid.
What's the magnetic field of an infinite line charge moving at a speed v? A quick calculation by Ampère's law tell us that it has a 1/s dependence. So what does a solenoid look like out at infinite? Definitely something similar to a moving line charge at infinite.. we could easily guess that at the very least for the solenoid, that it also has a 1/s dependence.
So let's assume then that the magnetic field has a 1/s dependence for the solenoid, well at infinite if it's similar to a moving line charge, it should be zero due to the 1/s dependence. But Ampere's law for a solenoid tells us that the magnetic field at a point a away from the solenoid has to be the same as the magnetic field at a point b away from the solenoid, so the logical progression is 0 everywhere.
Your statement:
"The symmetry is that of an infinite wire and the magnetic field is the same as that of an infinite wire... and different from zero." (i.e. is non zero with a 1/s dependence) is correct, but incomplete.
This is the exact argument used in the textbook.
EDIT: One last thing as a conceptual question. What do you see if you go out a distance infinite from an infinitely long cylinder? The answer is not an infinite line as you suggested.
Would you please tell me what is "s". I do not have the book.
s is the radial component in cylindrical coordinates. It's a convention that Griffith's seems to use in all his books.
Thanks for "s".
Maybe I am stupid, but I still see an infinite line. Will you please tell me what should I see?
Since the cylinder is finite radially (in cylindrical coordinates) as you leave it the infinitely long cylinder looks like an infinitely long line, but as you keep moving away, the thickness of the cylinder continues to get smaller and smaller (i.e. the radius of the cylinder continues to "shrink" from your perspective) until at infinite you no longer see the the radial component at all. In other words, the perspective on the cylinder will make it seem like the radius of the cylinder approaches 0 as you approach infinite. If radius = 0 for a cylinder, you have no cylinder, you won't see anything. An infinite plane is different in that it spreads in all directions so that if you're perpindicular to the plane, the "radial component" no longer shrinks to 0.
Sorry, but I still just see a line. A cylinder of radius zero has the same "radius" as a line. By convention we accept that we can see a line, even if its width is zero.
Yes, I agree and so I wrote. When you have things that span to infinity, you can't assume that their influence vanishes with distance.
Hmm. I thought about it, lpfr, today and I agree with you. I've always set the quick justification in my mind of field going to zero at infinite for an infinite line charge first by Gauss's/Ampere's 1/s dependence relation, and secondly because it seemed to me logical that if that were the case, at some point later the 'cylinder' would cease to be seen as the radius-->0.
As a strengthening of the argument that you still see the line itself, it's just that the field is extremely weak at extremely distant points, occurs if you calculate potential at infinite for an infinite line charge (potential being relative to some finite point). You'll get infinite.. which would make sense if you continually saw the line charge since you'll continually move in its field, increasing your potential.
Sorry for the stubborness.. I've never had to fully justify the image of it dissappearing.
EDIT: Sorry for the late reply, I just finished up my last exam for the semester this morning.
What is a solenoid?
A solenoid is a long, cylindrical coil of wire that produces a magnetic field when an electric current is passed through it.
What is an infinite solenoid?
An infinite solenoid is a theoretical concept where the length of the solenoid is considered to be infinite. This means that the magnetic field produced by the solenoid is uniform throughout its length and does not weaken as distance from the solenoid increases.
How is the magnetic field of an infinite solenoid calculated?
The magnetic field of an infinite solenoid is calculated using the equation B = μ₀nI, where B is the magnetic field strength, μ₀ is the permeability of free space, n is the number of turns per unit length, and I is the current passing through the solenoid.
What is an infinite current carrying plane?
An infinite current carrying plane is a theoretical concept where an infinite surface is uniformly charged and has a constant current passing through it. This creates a constant magnetic field in the surrounding space.
How is the magnetic field of an infinite current carrying plane calculated?
The magnetic field of an infinite current carrying plane is calculated using the equation B = μ₀I/2πr, where B is the magnetic field strength, μ₀ is the permeability of free space, I is the current passing through the plane, and r is the distance from the plane.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Sticky
  • Electromagnetism
