Fortran 95: WRITE to screen changes output to WRITE to file
In summary, there is a program that calculates running medians for three columns of data and writes them to an output file. The program uses Numerical Recipe subroutines and functions to compute the medians. When a WRITE(*,*) statement is commented out in a DO loop, the output file repeats the median of the first column in the other two columns. This issue has been observed on multiple machines and a potential workaround is to use an actual format statement for the WRITE statement.
benacquista
I have a short code that calculates the running median for three columns of data in an input file and writes the running medians out to three columns of data in an output file. I use Numerical Recipe subroutines and functions to compute the running median. If I include a WRITE(*,*) directly after the computation of each running median and then write all three running medians to the output file using WRITE(UNIT=outputfile,FMT=*), then I get the expected result. If I comment out the WRITE(*,*) commands, then the output repeats the running median of the first column in the other two columns. I'm running Mac OS10.6, using gfortran to compile and I can reproduce the effect on three different machines. Has anyone seen this before? Is there a better workaround than writing to screen?
PROGRAM RunningMedianFinder
IMPLICIT NONE
INTEGER,PARAMETER :: inputfile=10, outputfile=20
INTEGER :: rint,i,k,ios
REAL :: f(1025),h1(1025),h2(1025),h3(1025), &
h1m,h2m,h3m,fm,selip,medians(3)
CHARACTER(LEN=100) :: inputname,outputname
! First we find the name of the input file (raw data) and
! the output file (running median), and then we open them.
WRITE(*,*) 'What is the name of the input file (raw data)?'
READ(*,*) inputname
WRITE(*,*) 'What is the name of the output file (running medians)?'
READ(*,*) outputname
OPEN(UNIT=inputfile,FILE=inputname,POSITION='REWIND')
OPEN(UNIT=outputfile,FILE=outputname,POSITION='REWIND')
! Here, we determine the length of the running median -- called rint
! -- for Running INTerval.
WRITE(*,*) 'What is the length of the interval for the running median?'
READ(*,*) rint
! First, initialize the arrays.
DO i=1,1025,1
f(i)=0
h1(i)=0
h2(i)=0
h3(i)=0
END DO
! Read in the first interval for the running meadian.
DO i=1,rint,1
READ(UNIT=inputfile,FMT=*) f(i),h1(i),h2(i),h3(i)
END DO
! Because we are finding a median, the value of k used in selip will
! be half the running interval.
k = rint/2
! We will assign the value of the median to be at the frequency in
! the middle of the running interval.
! Now we start the loop over the entire file and record the running
! medians. We use the ios variable to determine when we have reached
! the end of the inputfile
ios = 0
DO WHILE (ios.ge.0)
h1m = selip(k,rint,h1)
WRITE(*,*) h1m
h2m = selip(k,rint,h2)
WRITE(*,*) h2m
h3m = selip(k,rint,h3)
WRITE(*,*) h3m
fm = f(k)
WRITE(UNIT=outputfile,FMT=*) fm,h1m,h2m,h3m
DO i=2,rint,1
f(i-1)=f(i)
h1(i-1)=h1(i)
h2(i-1)=h2(i)
h3(i-1)=h3(i)
END DO
READ(UNIT=inputfile,FMT=*,IOSTAT=ios) f(rint),h1(rint),h2(rint),h3(rint)
END DO
CLOSE(UNIT=inputfile)
CLOSE(UNIT=outputfile)
END PROGRAM
!SUBROUTINES!
SUBROUTINE shell(n,s)
IMPLICIT NONE
INTEGER :: n
REAL :: s(n)
INTEGER :: i,j,inc
REAL :: v
inc=1
DO WHILE(inc.le.n)
inc=3*inc+1
END DO
DO WHILE(inc.gt.1)
inc=inc/3
DO i=inc+1,n
v=s(i)
j=i
DO WHILE(s(j-inc).gt.v.and.j.gt.inc)
s(j)=s(j-inc)
j=j-inc
END DO
s(j)=v
END DO
END DO
RETURN
END SUBROUTINE
!FUNCTIONS!
FUNCTION selip(k,n,arr)
IMPLICIT NONE
INTEGER,PARAMETER :: M=64
INTEGER :: k,n
REAL,PARAMETER :: BIG=1.e30
REAL :: selip,arr(n)
INTEGER :: i,j,jl,jm,ju,kk,mm,nlo,nxtmm,isel(M+2),a
REAL :: ahi,alo,sum,sel(M+2)
kk=k
ahi=BIG
alo=-BIG
DO WHILE(a.ne.1)
a=1
mm=0
nlo=0
sum=0.
nxtmm=M+1
DO i=1,n
IF(arr(i).ge.alo.and.arr(i).le.ahi) THEN
mm=mm+1
IF(arr(i).eq.alo) nlo=nlo+1
IF(mm.le.M) THEN
sel(mm)=arr(i)
ELSE IF(mm.eq.nxtmm) THEN
nxtmm=mm+mm/M
sel(1+mod(i+mm+kk,M))=arr(i)
END IF
sum=sum+arr(i)
END IF
END DO
IF(kk.le.nlo) THEN
selip=alo
RETURN
ELSE IF(mm.le.M) THEN
CALL shell(mm,sel)
selip=sel(kk)
RETURN
END IF
sel(M+1)=sum/mm
CALL shell(M+1,sel)
sel(M+2)=ahi
DO j=1,M+2
isel(j)=0
END DO
DO i=1,n
jl=0
ju=M+2
DO WHILE(ju-jl.gt.1)
jm=(ju+jl)/2
IF(arr(i).ge.sel(jm)) THEN
jl=jm
ELSE
ju=jm
END IF
END DO
isel(ju)=isel(ju)+1
END IF
END DO
j=1
DO WHILE(kk.gt.isel(j))
alo=sel(j)
kk=kk-isel(j)
j=j+1
END DO
ahi=sel(j)
a=0
END DO
END FUNCTION
Technology news on Phys.org
So are you saying that if you comment out the three WRITE (*,*) statements in this DO loop
Code:
DO WHILE (ios.ge.0)
WRITE(*,*) h1m
WRITE(*,*) h2m
WRITE(*,*) h3m
fm = f(k)
DO i=2,rint,1
f(i-1)=f(i)
h1(i-1)=h1(i)
h2(i-1)=h2(i)
h3(i-1)=h3(i)
END DO
END DO
then the WRITE(UNIT=outputfile, FMT=* ) statement produces the screwy results you described? If that's the case, you might consider using an actual format statement for that last WRITE statement.
Code:
DO WHILE (ios.ge.0)
WRITE(*,*) h1m
WRITE(*,*) h2m
WRITE(*,*) h3m
fm = f(k)
DO i=2,rint,1
f(i-1)=f(i)
h1(i-1)=h1(i)
h2(i-1)=h2(i)
h3(i-1)=h3(i)
END DO
END DO
Thanks for the suggestion. What you describe is precisely the problem. Unfortunately, I tried an actual format statement (using FMT='(E7.6)' ) and I still get the screwy results unless I comment out the three WRITE(*,*) statements. Perhaps this is a bug in the gfortan compiler?
Hi benacquista,
I believe your problem is in the selip function:
IMPLICIT NONE
READ(*,*) inputname
READ(*,*) rint
DO i=1,1025,1
f(i)=0
h1(i)=0
h2(i)=0
h3(i)=0
END DO
DO i=1,rint,1
END DO
k = rint/2
ios = 0
DO WHILE (ios.ge.0)
WRITE(*,*) h1m
WRITE(*,*) h2m
WRITE(*,*) h3m
fm = f(k)
DO i=2,rint,1
f(i-1)=f(i)
h1(i-1)=h1(i)
h2(i-1)=h2(i)
h3(i-1)=h3(i)
END DO
END DO
END PROGRAM
!SUBROUTINES!
IMPLICIT NONE
INTEGER :: n
REAL :: s(n)
INTEGER :: i,j,inc
REAL :: v
inc=1
DO WHILE(inc.le.n)
inc=3*inc+1
END DO
DO WHILE(inc.gt.1)
inc=inc/3
DO i=inc+1,n
v=s(i)
j=i
s(j)=s(j-inc)
j=j-inc
END DO
s(j)=v
END DO
END DO
RETURN
END SUBROUTINE
!FUNCTIONS!
IMPLICIT NONE
INTEGER :: k,n
kk=k
ahi=BIG
alo=-BIG
I believe your next line is the problem; you are using the variable a without it being initialized. If right here you will insert:
Code:
a=0.
I think that will fix your problem.
DO WHILE(a.ne.1)
a=1
mm=0
nlo=0
sum=0.
nxtmm=M+1
DO i=1,n
mm=mm+1
IF(mm.le.M) THEN
sel(mm)=arr(i)
nxtmm=mm+mm/M
END IF
sum=sum+arr(i)
END IF
END DO
IF(kk.le.nlo) THEN
selip=alo
RETURN
CALL shell(mm,sel)
selip=sel(kk)
RETURN
END IF
sel(M+1)=sum/mm
CALL shell(M+1,sel)
sel(M+2)=ahi
DO j=1,M+2
isel(j)=0
END DO
DO i=1,n
jl=0
ju=M+2
jm=(ju+jl)/2
jl=jm
ELSE
ju=jm
END IF
END DO
isel(ju)=isel(ju)+1
END IF
END DO
j=1
alo=sel(j)
kk=kk-isel(j)
j=j+1
END DO
ahi=sel(j)
a=0
END DO
END FUNCTION
This is the opposite of what you said earlier.
In the first quote above, you're now saying that you don't get the screwy results if you comment out the three WRITE statements.
alphysicist, I agree that the selip function should initialize a before testing it in the DO WHILE loop, but I don't see how selip returning a bogus value would affect the formatting of a WRITE statement.
Sorry! This has got me so confused, I'm confusing others. My first statement is correct. If the WRITE statements are there, then it works. If I comment out the WRITE statements, then I get weird results.
I tried alphysicist's suggestion and it worked. I'm trying to figure out why, and my only guess is that the WRITE statement causes the stored value of 'a' to change ... otherwise, it remains equal to 1 (it's value when selip returns a number). If it remains equal to 1, then the following calls to selip do nothing and simply return the previous value of selip.
Thank you very much!
I don't know anything about compilers, so I can't say I know "why" it works. However, years of painful experience has taught me that when something weird is happening, it quite often is an unitialized variable using whatever garbage happens to be at the memory location.
That's the right idea, but remember there is not really a "stored value" for a between calls to selip. After the first call to selip is over, the memory location for a had a value of 1. On the second call to selip (when the function calls are immediately after each other), a is apparently assigned the identical memory location, which has not been disturbed. Since you have not initialized a, it uses whatever garbage is already there, which happens to be your previous value.
And when you output something between calls, my guess is that a is assigned a different memory location, and now the garbage there is not equal to 1, and your function works again. (But as I said above, I don't know anything about the executables created by the fortran compiler; if anyone knows more details about this I would like to hear it.)
This problem sounds all to familiar to me. Is there any compiler option to warn about un-initialized variables?
Hi DrDu,
I don't use gfortran, but with g95 you can use the -Wall switch to catch these simple cases of uninitialized variables. gfortran might use the same option.
I tried this by commenting out the place where I initialized the variable, and compiled with gfortran using -Wall. It didn't catch the uninitalized variable, but it flagged every one of my tabs as a "Nonconforming tab character". I'm not quite sure what that means, but since I tab liberally in order to make it easy for me to follow the code structure, it flagged every line in the code. Probably the best solution is simply to be diligent about initializing variables, and targeting that as the most likely problem when debugging.
You can stop the warning about tabs by adding -Wtabs as an extra compiler option (in addition to the -Wall).
But was -Wall catching uninitialized variables for gfortran? I've recently installed Ubuntu on one of my machines and was planning on using gfortran.
Thanks, after using -Wtabs (and commenting out the initialization of the variable) I could see the one other warning. Unfortunately, gfortran did not catch the uninitialized variable. It did catch an unused variable in the declarations of the main program.
What is Fortran 95?
Fortran 95 is a high-level programming language used for scientific and numerical computing. It is an updated version of the original Fortran language, with added features and improvements.
What is the difference between WRITE to screen and WRITE to file in Fortran 95?
WRITE to screen is used to display output on the computer screen, while WRITE to file is used to write output to a file on the computer's hard drive. The main difference is the destination of the output.
Why does the output change when using WRITE to screen and WRITE to file in Fortran 95?
The output changes because the destination of the output is different. When using WRITE to screen, the output is displayed on the screen in real-time. When using WRITE to file, the output is saved in a file and can be accessed later.
Can I use WRITE to screen and WRITE to file in the same program?
Yes, you can use both WRITE to screen and WRITE to file in the same program. This can be useful for displaying output to the user while also saving the output to a file for later use.
Are there any limitations to using WRITE to screen and WRITE to file in Fortran 95?
Yes, there are some limitations to using these commands. For example, the maximum number of characters that can be displayed on the screen may vary depending on the computer's hardware and operating system. Additionally, the file size for WRITE to file may be limited by the available storage space on the computer.
