New Reply
Gravitation potential and gravitational binding energy
Share Thread Thread Tools
Jan5-13, 04:20 PM   #1
Hello,
The gravitational binding energy of a system is equal to the negative of the total gravitational potential energy.
Is this given by the equation:
U=-alphaGM^2/R
where alpha=3/5 and the equation stands as:
U=-3/5GM^2/R?
Kindly correct me if I am wrong?
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> New analysis yields improvements in a classic 3D imaging technique
>> Research effort deep underground could sort out cosmic-scale mysteries
Jan6-13, 02:50 AM   #2
Where did you get the factor of 3/5 from? There is no [itex]\alpha[/itex] = 3/5 in gravitational potential
The gravitational potential energy is:
[itex]\frac{-GMm}{r^2}[/itex]
The gravitational binding energy can be thought of as an internal potential energy. How much grav potential is stored in an object? You must compute the gravitational potential for every particle in the object relative to all the rest of them which simply yields
[itex] \frac{-GM^2}{r^2}[/itex]
Because m is now M. Both values are negative, by convention.
Jan6-13, 03:12 AM   #3
For a spherical mass of uniform density, the gravitational binding energy U is given by the formula
u=3GM^2/5r. The derivation follows from the volume of the sphere, 4 pi r^3 and area of the sphere 4 pi r^2.
In Faber Jackson relation the gravitational potential of a mass distribution of radius R and mass M is given by the expression:
U=-alphaGM^2/R
U=-3/5GM^2/R
So I asked you the above question.
Jan6-13, 07:48 AM   #4
Recognitions:
Gold Membership Gold Member
Retired Staff Staff Emeritus
Quote by soothsayer View Post
Was this a typo? The gravitational force varies as [itex]1/r^2[/itex] but the gravitational potential energy as 1/r, the integral of [itex]1/r^2[/itex].
Jan6-13, 10:20 AM   #5
If you can please look into the following:
http://en.wikipedia.org/wiki/Faber%E...ckson_relation
and correct me, what mistake I am making.
Jan6-13, 07:06 PM   #6
Ah, right. I forgot about the factor for the sphere. And yes, the r^-2 factor was a typo.
Jan7-13, 06:27 AM   #7
So,
My question still stands:
U=-alphaGM^2/R
U=-3/5GM^2/R?
Thanks.
Jan7-13, 09:14 AM   #8
Mentor
Yes, this is true if the mass is uniformly distributed in a sphere. This is analogous to the electrostatic potential energy of a sphere with uniform charge density, which also has a factor of 3/5:
http://farside.ph.utexas.edu/teachin...es/node56.html
(in particular equation 601 and the derivation preceding it)
Jan7-13, 01:16 PM   #9
Sorry, I was confused at to what the question was. Were you asking if your equation was correct? Because yes, it is.
Except, it's not equal to the NEGATIVE of the total gravitational potential energy, because gravitational potential is also negative. Both quantities are negative, it's just the gravitational binding the the total internal gravitational potential of the object.
Jan8-13, 12:34 PM   #10
Reading over Wikipedia I found that:
U=3GM^2/5R
Again it states that for a uniform sphere the gravitational binding energy of the sphere is the negative of the gravitational potential energy, which is:
U=-3GM^2/5R
Are they referring to the same equation? How can one equation have different results?
Jan8-13, 01:48 PM   #11
Mentor
Binding energy is the energy that we must add to a bound system in order to separate it completely into its constituents. It is always positive. If it were negative, the system could fly apart by itself, releasing energy. For a gravitationally bound sphere with uniform density, it is Eb = 3GM2/5R.
When we add energy to a system, we increase its (potential + kinetic) energy. If the kinetic energy of the "pieces" is zero before and after, then only the potential energy changes. Ubound + Eb = Useparated. In the situation that we're dealing with here, we define the potential energy to be zero when the system is completely separated, that is, Useparated = 0.
This leads to Ubound = -Eb = -3GM2/5R.
Jan8-13, 03:55 PM   #12
The negative signs are more a thing of convention than anything...
I think what jtbell wrote is useful. Often, an object in a bound state, like an atom in a ground state, or a spherical planet, must be at a minimum of potential energy.
The easiest way to do this is to say that a potential energy of zero means the system is totally unbound (imagine an ionized atom), and obviously, the bound state would have to have a negative energy, -3GM2/5R, for a planet, star, etc.
You can also think of the positive of this as being the energy required to unbind the system, so the energy needed to ionize an atom, or the energy required by the Death Star to disintegrate Aldreraan ;)
There is an arbirarity to potential energy. You can set the zero point energy to be anything as long as you are consistent. There are standard conventions for some systems like gravitational binding energy that make everything much nicer, however.
I'm guessing this is the wiki page you're referencing?
http://en.wikipedia.org/wiki/Gravita...binding_energy
I see that they use the positive and negative version of the equation. It makes little difference. It only matters the convention. The top equation is essentially saying that this is the energy stored in the gravitational binding of the object, and the second equation is saying that this is the total binding potential of the spherical object , which is negative if we say that the potential zero point is when the system is completely unbound.
Jan8-13, 04:16 PM   #13
How do you deal with the gravitational self-energy of a point mass? Renormalization?
Jan9-13, 01:18 AM   #14
Thank you jtbell, for your wonderful reply. It just cleared out all my confusions.
Thank you soothsayer. Yes, you are very right. I was referring to the wikipedia article only. Thanks for the detailed reply on the topic. Thanks.
Thank you all.
Jan13-13, 02:03 PM   #15
Quote by Khashishi View Post
It's just GM2/R, I believe. Integrating over a sphere gives 3GM2/5R.
Jan14-13, 09:47 PM   #16
point mass has no R
New Reply
Thread Tools
Similar Threads for: Gravitation potential and gravitational binding energy
Thread Forum Replies
Gravitational potential energy, orbital speed, binding energy. Introductory Physics Homework 3
EM and Gravitational binding energy for quarks High Energy, Nuclear, Particle Physics 2
Gravitational Binding Energy Astrophysics 1
Gravitational binding energy of the sun? General Physics 0
Newton's Law of Gravitation vs. Gravitational Potential Energy Introductory Physics Homework 2
