Why Does the Sky Appear Blue? Why Can Stars See Us?
  • Thread starter xzardaz
  • Tags
    Sky Stars
In summary, the color of the sky is blue due to the way air particles scatter light, making it difficult to see stars during the day. However, stars are able to see us due to the reflected light from the Earth being brighter than the scattered light from the atmosphere. With the use of a telescope, it is possible to view stars during the day, but caution must be taken when using a telescope during daylight hours.
xzardaz
Hello,
I have a novice question.
I know that the sky color is blue (at noon, when there is no clouds), because the air particles (mostly N2 and a little O2 ...and other) scatter short-wavelength light more than longer wavelengths.
That is why we can't see the stars trought the atmosphere in daytime (the scattered light is with much more intensity then the light emmited from the brightest star).
The question is why the stars can see us? All the pictures taken from above the atmosphere show the landscape of Earth trought the atmosphere, where in the landscape is noon.
Astronomy news on Phys.org
When viewed from say, the moon, the eart is much, much brighter than any star.
So the reflected light from Earth is brighter then the scattered light from atmosphere?
Yes. Although when it comes to stars it is possible to view the brighter stars during the day even with just a amateur telescope due to how extended sources (the sky) and point sources (stars) behave with increased magnification.
Note: If you don't know what you are doing never use a telescope while the sun is up...
Compare Moon in daytime sky. It is clearly visible against blue sky - although not as bright as many objects on ground or in sky lit by the same sunlight.
In clear sky, the disc of Sun is easily visible against blue sky, too. Since stars are inherently as hot as Sun, or slightly hotter or cooler, you should be able to magnify stars even in daytime sky to be almost as bright and distinctive, or even brighter and more distinctive, than Sun. Provided you are applying magnification starting hundreds of thousands of times, and apertures matching this (i. e. over a kilometre).
The sky appears blue because of a phenomenon called Rayleigh scattering. The Earth's atmosphere is made up of tiny particles, such as nitrogen and oxygen molecules, that scatter sunlight in all directions. Blue light has a shorter wavelength than other colors, so it is scattered more easily and is therefore more visible to our eyes.
Stars can see us because they emit light and have the ability to reflect light from other sources. The stars that we see in the night sky are actually emitting their own light, which travels through the vast distances of space and reaches our planet. Additionally, stars can also reflect light from other objects, such as the moon or other planets, which allows them to "see" us on Earth.
Does the Sky Always Appear Blue?
No, the sky does not always appear blue. The color of the sky can change depending on various factors such as the time of day, the weather, and the amount of pollution in the air. For example, during sunrise and sunset, the sky may appear more orange or red due to the scattering of light at different angles. On cloudy or hazy days, the sky may appear a different shade of blue or even gray.
Why Do Stars Twinkle?
Stars appear to twinkle because of the Earth's atmosphere. As starlight passes through the atmosphere, it is refracted and distorted by the varying air temperatures and densities. This causes the star's light to appear to flicker and change in brightness. Stars closer to the horizon also appear to twinkle more than those directly overhead due to the longer path of light through the atmosphere.
Can We See Stars During the Day?
Yes, we can see stars during the day. However, they are often difficult to see due to the brightness of the sun and the scattering of light in the Earth's atmosphere. The best time to see stars during the day is when the sun is low on the horizon, such as during sunrise or sunset. In areas with less light pollution and clearer skies, it may also be possible to see stars during the day.
  • Astronomy and Astrophysics
