expanding a gas through a valve or through a turbine !
by charlie95
Tags: expanding, turbine, valve
charlie95
charlie95 is offline
#1
Dec27-12, 06:17 PM
P: 30
Can somebody explain to me why the temperature gets colder when expanding through a turbine versus expanding through a valve.
Please explain with equations.
Phys.Org News Partner Physics news on Phys.org
Better thermal-imaging lens from waste sulfur
Scientists observe quantum superconductor-metal transition and superconducting glass
New technique detects microscopic diabetes-related eye damage
charlie95
#2
Dec28-12, 03:16 AM
P: 30
somebody must know this...
Nugatory
Nugatory is offline
#3
Dec28-12, 09:53 AM
Sci Advisor
Thanks
P: 2,951
Quote Quote by charlie95 View Post
Hot gas under pressure stores some potential energy, rather like a compressed spring. This energy is released when the gas expands. If you let the gas out through a valve, almost all of the potential energy goes to speeding up the escaping stream of gas, and this ends up as random kinetic energy of the gas molecules as they bounce around. If the gas expands through a turbine, some of the potential energy ends up as kinetic energy in the rotating turbine, so less ends up as random kinetic energy in the gas molecules.
Less random kinetic energy in the same (after expansion) volume of gas means a lower temperature.
charlie95
#4
Dec28-12, 04:00 PM
P: 30
thank u Nugatory:)
But I think somebody once explained to me somethng about dQ=dU+dW.
And that when we expand throgh a turbine, work(dW) is done and therefore we get a much colder gas instead of just expand through a valve.
Is this just ********??? :):)
If there is some logic in this, can someone please explain to me what dQ,dU and dW means??
SteamKing
SteamKing is offline
#5
Dec28-12, 07:52 PM
HW Helper
Thanks
P: 5,532
dQ is the change in heat energy or enthalpy of a substance
dU is the change in internal energy of a substance
dW is the change in energy due to the work of a substance.
It's not BS. It's the First Law of Thermodynamics.
Register to reply
Related Discussions
Steam Turbine / Tesla Turbine - bladless rotor in steam turbine? Classical Physics 4
Why water turbine have higher efficiency then steam turbine? General Physics 22
Francis Turbine And Kaplan Turbine Doubt Mechanical Engineering 11
Since the universe is expanding does this mean Quantum Particles are expanding too? Quantum Physics 5
PROBLEM: Turbine connected via adiabatic valve to air supply Introductory Physics Homework 0
