Understanding Heisenberg Hamiltonian Notation for 4-Site Chain
In summary, the notation for the Heisenberg Hamiltonian is given by H_{exch}=-\sum_{i<j}2J_{i,j}\vec{S}_i \cdot \vec{S}_j where the summation extends over all spin pairs of the crystal lattice. However, for a chain with four sites and periodic boundary conditions, the Hamiltonian is written as H_{exch}=-J_{1,2}\vec{S}_1 \cdot \vec{S}_2-J_{2,3}\vec{S}_2 \cdot \vec{S}_3-J_{3,4}\vec{S}_3 \cdot \vec{S}_4-J_{4,1}\
LagrangeEuler
717
Notation for Heisenberg Hamiltonian
## H_{exch}=-\sum_{i<j}2J_{i,j}\vec{S}_i \cdot \vec{S}_j ##
where the sumation extends over all spins pair of the crystal lattice. Suppose we have chain with four sites and periodic boundary condition
## H_{exch}=-J_{1,2}\vec{S}_1 \cdot \vec{S}_2-J_{2,3}\vec{S}_2 \cdot \vec{S}_3-J_{3,4}\vec{S}_3 \cdot \vec{S}_4-J_{4,1}\vec{S}_4 \cdot \vec{S}_1 ##
I can't see that this is the same.
So what do you get if you write out the first sum?
Hint: Your second Hamiltonian only has nearest neighbors.
Is this all the information you have? It seems like if this is all given to you, there is an obvious language issue and a potential notational issue.
First "the sumation extends over all spins pair of the crystal lattice." is not correct English. Does "spins pair" mean all nearest neighbors? If it were a nearest-neighbor Hamiltonian (which is what you would expect for an Ising or Heisenberg model), then I would write it as:
[tex]H=\sum_{\left \langle i,j \right \rangle}-J_{ij}\vec{S}_i\cdot\vec{S}_j [/tex]
where the notation [itex]\left \langle i,j \right \rangle [/itex] generically means "nearest neighbors." The notation is useful because the indexing of lattice sites might be tricky when you deal with higher dimension. [Note that the way you have it written above would include an interaction between i=1 and j=3, which would not be nearest neighbors in a circular chain. The fact that i=4 and j=1 appears is because in a 4-element circular chain, 4 would be a nearest neighbor with 1.]
Factors of 2 or 1/2 are usually included in Hamiltonians with symmetric interactions so that you can make sure to remember that if spin i interacts with spin j, then both i and j contribute their interaction to the hamiltonian, or conversely, so that you do not double-count a single interaction. But this only works for symmetric interactions, i.e. Jij = Jji, which is typically but not always the case.
Condensed matter hamiltonians are usually written with intuitive notation that can be confusing if you try and write it down like a mathematician with no idea of what the actual "neighbor" structure is. You'll find that the explanation in words, like "The Hamiltonian consists of pairwise interactions between nearest-neighbors" is often a more specific description than physicist notation like Ʃ<i,j>.
Yes just that. Strange. And how to write ##\sum_{i<j}## if you have vectors ##\vec{i},\vec{j}##? Notation ##\sum_{\langle i,j \rangle}## looks also confusing for me sometimes. Because I'm never sure
##-\sum_{\langle i,j \rangle}J_{i,j}\vec{S}_i \cdot \vec{S}_j## or ##-\frac{1}{2}\sum_{\langle i,j \rangle}J_{i,j}\vec{S}_i \cdot \vec{S}_j##?
Yeah, it doesn't make sense if you think of i,j as vectors. The upshot is that you don't have to - the indices are just supposed to label all sites. As long as your system has finite length, width, height (and so on, if you want to) - all you need is one number. It doesn't need to have anything to do with the structure of the lattice or your intuition. See this example for a rectangular grid:
1 2 3 4
5 6 7 8
Every site is characterized by the number [itex]i=x+4*(y-1)[/itex], where x=1,2,3,4 and y=1,2,...
Then, if the actual positions are interesting, we can form the vector [itex]\mathbf{r}_i = x \hat{x} + y \hat{y}[/itex] using modulus operations and the basis vectors of the lattice. Actually, the position vectors are often not that interesting for spin chain systems as the positions are usually fixed, i.e. not dynamical.
Are you confused about that factor of 1/2? It only changes the definition of [itex]J_{ij}[/itex], so it's not that important physically. You can just pick either convention at the start of your calculations.
However, it can be important if you want to relate two sums. The factor of 1/2 is then used to avoid double counting. I.e.
[tex]\sum_{ij} \mathbf{S}_i \cdot \mathbf{S}_j = 2 \sum_{i<j} \mathbf{S}_i \cdot \mathbf{S}_j[/tex]
since the first notation contains both [itex]\mathbf{S}_1 \cdot \mathbf{S}_2[/itex] and [itex]\mathbf{S}_2 \cdot \mathbf{S}_1=\mathbf{S}_1 \cdot \mathbf{S}_2[/itex] while the second sum only contains one instance of [itex]\mathbf{S}_1 \cdot \mathbf{S}_2[/itex].
When using the [itex]\sum_{\langle i,j\rangle}[/itex] notation that Jolb described, it generically contains both the ij and the ji terms, so you are in fact counting all symmetric terms twice. In that case using the Hamiltonian
[tex]H = -\frac{1}{2} \sum_{\langle i,j \rangle} J_{ij} \mathbf{S}_i \cdot \mathbf{S}_j [/tex]
makes sense, but again, it's only a scale factor in the end.
Yes but you know authors very often didn't write what they mean by
[tex]H = \sum_{\langle i,j \rangle} J_{ij} \mathbf{S}_i \cdot \mathbf{S}_j [/tex]
for me this is correct way to write it
know its all explicit. Because if they calculate critical temperature or any other parameter I wish to know what is exact form of Hamiltonian and what is ##J## in Hamiltonian. Because ##J## you can measure.
1. What is the Heisenberg Hamiltonian notation for a 4-site chain?
The Heisenberg Hamiltonian notation for a 4-site chain is a mathematical representation of the interactions between particles in a one-dimensional chain. It is represented by the symbol H and includes terms for the kinetic energy, potential energy, and spin interactions of the particles.
2. How is the Heisenberg Hamiltonian notation used in quantum mechanics?
The Heisenberg Hamiltonian notation is used in quantum mechanics to describe the behavior of particles in a system. It is used to calculate the energy levels, dynamics, and other properties of the system.
3. What are the main components of the Heisenberg Hamiltonian notation?
The main components of the Heisenberg Hamiltonian notation are the kinetic energy term, the potential energy term, and the spin interaction term. These terms represent the different types of interactions between particles in the system.
4. How is the Heisenberg Hamiltonian notation different from other notations?
The Heisenberg Hamiltonian notation is different from other notations in that it takes into account both the kinetic and potential energy of the particles, as well as their spin interactions. Other notations may only consider one or two of these factors.
5. What is the significance of the Heisenberg Hamiltonian notation in physics?
The Heisenberg Hamiltonian notation is significant in physics because it allows for the calculation and prediction of the behavior of particles in a system. It is a fundamental tool in the study of quantum mechanics and has been used to understand and explain various phenomena in the field of physics.
  • Atomic and Condensed Matter
  • High Energy, Nuclear, Particle Physics
  • Math Proof Training and Practice
20K
