converting dt graph (and table) to velocity/time using two point
by celtics23
Tags: converting, graph, point, table, velocity or time
celtics23
celtics23 is offline
#1
Sep22-13, 08:38 AM
P: 2
How can we convert a distance/time graph (that also contains a table of info) into velocity/time, using the two point method?
Phys.Org News Partner Physics news on Phys.org
Physicists consider implications of recent revelations about the universe's first light
Vacuum ultraviolet lamp of the future created in Japan
Grasp of SQUIDs dynamics facilitates eavesdropping
ZapperZ
ZapperZ is offline
#2
Sep22-13, 08:39 AM
Mentor
ZapperZ's Avatar
P: 28,836
Quote Quote by celtics23 View Post
What is the relationship between "velocity" and "distance"?
Zz.
celtics23
#3
Sep22-13, 08:48 AM
P: 2
d=vt
namanjain
namanjain is offline
#4
Sep23-13, 03:10 AM
P: 49
d=vt
'd' is displacement 've
you'll learn it afterward perhaps i see
i am giving you graph of speed vs time
if d-t graph is straight line at an angle α with x axis then v-t graph is a line parallel to x axis
if d-t graph is parabolic then v-t graph is straight line at an angle θ with x axis
ZapperZ
ZapperZ is offline
#5
Sep23-13, 06:16 AM
Mentor
ZapperZ's Avatar
P: 28,836
d=vt
Not quite.
You need to know that velocity is the time rate of change of displacement/position. In graph form, it corresponds to the slope at a given point in the displacement-time graph.
You should have enough here to answer the question.
Note that you need to know the physical meaning of all of this. It is not enough to just know/memorize the equation without understanding what it means.
Zz.
Register to reply
Related Discussions
Position at any one point on Velocity-Time Graph Introductory Physics Homework 7
How to determine acceleration from one point to another on a velocity vs time graph Introductory Physics Homework 1
Converting Distance- Time Graph to Velocity- Time Introductory Physics Homework 5
how to do velocity-time graph to distance graph/acceleration to velocity graph? Classical Physics 1
Converting velocity/time graph to acceleration/time Introductory Physics Homework 2
