Whirlpool action in a tank created by inlet water
In summary: I can't find the episode right now, but they tested whether the direction of the whirlpool made any difference. There wasn't a huge difference, but they did find that the clockwise whirlpool was a bit more stable.Thank you for the information. It will be helpful in making a decision.
qlusa
I would like to determine what should be the size and number of pipes that are attached tangent to the cone of a tank. I will very much appreciate it that some one comment on how to approach and calculate it.
I am trying to create a whirlpool action with an angular velocity of 1 rpm in a tank with cone bottom. The tank is 6 meter in diameter and 2 meters in height. The cone height is 1 meter. Initially, the tank is filled with water. Water is, then, pumped into the tank through the pipes ( the size and number are to be determined) that are attached tangent to the cone with a constant flow of 0.6 cubic meter / minute. The over-flow water exits at the top of the tank.
Velocity divided by circumference...?
Thank you. but ..
Could you please elaborate it for me to understand?
The velocity of the water coming out of the pipe divided by the circumference is equal to the angular speed in rpm. Perhaps if you are trying to spin a large volume of water you'll want the jets to have somewhat higher speed, but it probably won't need to be much higher. There isn't much friction to slow the water down as it goes around the tank.
Thank you for explantion...
However, if I place the inlet pipes at two levels of the cone, the circumference at the lower level is smaller than that on the top level. Does this mean that the inlet pipes at the lower should have a lowered flow rate to match the same angular velocity of the whirlpool?
What will be the resultant angular velocity of the whirlpool if the incoming flow rate from the two levels is the same?
If the jets are the same speed, you'll have a whirlpool with a speed that varies with height. If, for example, the lower jet is halfway down the cone, the angular velocity is doubled at that level (because the diameter is cut in half)... except that water is viscous enough it'll want to spin at a constant rate. You'll end up closer to the higher rate than the lower one.
Is water also exiting the bottom of the cone? May I ask what the purpose of this is? It makes a difference, because as water travels up the cone, its angular velocity will decrease and if it travels down, its angular velocity will increase (due to conservation of angular momentum). Obviously, this gets to be a very complex problem very quickly, so it would be helpful to know what the constraints really are.
Thank you. If I understand correctly, the lower jet halfway down the cone; generates an angular velocity that is doubled. However, as water travels up the top of cone, its angular velocity decreases to the same velocity as that generated by the jet on the top of the cone.
In this system, water comes in from bottom and exits from top. The purpose of this design is to prevent clogging of the suspended solid in the tank. Since a uniform distribution of solid in the tank is not an issue and the density of the solid is only slightly higher than water, I try to save energy by using whirlpool action instead of an agitator. Do you think this is feasible system?
Does the direction of the whirlpool (clockwise or counter clockwise) make any differences?
There's a great Mythbusters episode on whirlpools -- they actually build a whirlpool tank and create rotation at various speeds. Maybe you could find it on YouTube?
1. What causes the formation of a whirlpool in a tank?
The formation of a whirlpool in a tank is caused by the movement of water entering the tank through an inlet. As the water enters, it creates a vortex or circular motion due to the Coriolis effect and the shape of the tank.
2. How does the speed of the inlet water affect the strength of the whirlpool?
The speed of the inlet water has a direct impact on the strength of the whirlpool. The faster the water enters the tank, the stronger the whirlpool will be. This is because a faster flow of water creates a stronger vortex and more force to keep the whirlpool in motion.
3. Can the direction of the whirlpool be controlled?
Yes, the direction of the whirlpool can be controlled by changing the direction of the inlet water. This can be done by adjusting the angle of the inlet or by using a diverter to redirect the flow of water.
4. How does the size and shape of the tank affect the whirlpool action?
The size and shape of the tank can affect the whirlpool action. A larger and wider tank will allow for a larger and stronger whirlpool to form. The shape of the tank can also impact the direction and stability of the whirlpool.
5. Are there any practical applications for studying whirlpool action in tanks?
Studying whirlpool action in tanks has practical applications in many industries, including fluid dynamics, hydraulics, and water treatment. Understanding how whirlpools form and behave can help engineers design more efficient and effective systems for various purposes.
  • Classical Physics
  • General Engineering
  • Electromagnetism
