Explain why the divergence of each of the functions must be zero
In summary, the conversation discusses the divergence of three functions (A1, A2, and A3) and explains why it must be zero without performing any calculations. The speaker argues that the electric field for A1 is a constant plane, making the divergence zero. For A2 and A3, the speaker suggests that the flux through some area is equal to the amount of "stuff" flowing in and out, leading to a zero divergence. They also question whether the vectors rho and r represent spherical and cylindrical coordinates, but it is not clear how they relate to the argument.
brad sue
281
the question is:
Without doing any calculations, explain why the divergence of each of the functions must be zero(Hint: consider what electric field these functions physically correspond to)
P.S: I make the unit vectors in bold.
A1=x
A2=ρ(1/ρ) with ρ>0
A3=r(1/r2) with r>0
I think we need to argue about the charge
for A1 , the electric field of A! is a plane, which constant, so divergence is zero.
for A2, it seems to be a line of charge but I don know how to argue for the divergence to be zero.
Same for A3
Can someone see what is going on?
B
Divergence shows the flux through some kind of area, so it indicates how much "stuff" flows in compared to out. This is basically going to be your argument for every single one, is that somehow as much stuff flows in as out.
Are the vectors rho and r supposed to represent spherical and cylindrical coordinates?
ecause these functions represent electric fields, which are conservative vector fields, their divergence must be zero. This is a consequence of the fundamental theorem of calculus, which states that for a conservative vector field, the line integral of the field over a closed loop is equal to zero. In other words, the net flow of the field into or out of a closed surface is zero. This is true for all three functions given, as they represent electric fields that are constant or decrease with distance. Additionally, since the functions are defined in terms of a single variable (x, ρ, or r), there is no variation in the field in the other dimensions, further supporting the idea that the divergence must be zero.
What is divergence?
Divergence is a mathematical concept that describes the extent to which a vector field flows away from a given point. It is a measure of the outflow or inflow of a vector field at a specific point.
Why must the divergence of a function be zero?
The divergence of a function represents the net flow of the vector field out of a given point. If the divergence is zero, it means there is no net flow, which indicates that the vector field is not spreading out or converging towards that point.
What does a non-zero divergence value indicate?
A non-zero divergence value indicates that the vector field is either spreading out or converging towards a given point. This can be visualized as a source or sink in the vector field, respectively.
How is divergence calculated?
Divergence is calculated using the dot product of the vector field with the del operator (represented as ∇). This can be written as ∇ · F, where F is the vector field. The result is a scalar value representing the divergence of the vector field at a particular point.
What are some real-world applications of divergence?
Divergence has applications in fluid dynamics, electromagnetism, and other fields where vector fields are present. In fluid dynamics, divergence can be used to study the flow of fluids, while in electromagnetism, it can be used to analyze electric and magnetic fields. It also has applications in computer graphics and image processing.
