Solve Dynamical Systems Homework: 20kg Spring/Damper System
In summary, a dynamical system is a mathematical model that describes how a system changes over time. It uses equations to represent the behavior of the system and predict future states based on current states. A 20kg spring/damper system refers to a physical system with a 20kg mass attached to a spring and a damper. To solve a dynamical system homework problem, one must use equations to determine variable values at different points in time. Key factors to consider when solving a dynamical system problem include initial conditions, forces, constraints, and appropriate methods for solving equations. Real-world applications of solving dynamical systems include modeling physical systems, studying complex systems, and analyzing various fields such as physics, engineering, economics, and biology.
Velcro7
A mass of 20kg is supported by a spring and damper as shown. The system is at rest for t<0. At t=0 a mass of 2kg is added to the 20kg mass as shown. The system vibrates as shown in the accompanying figure. Determine the spring constant k and the damping coefficient c for the system.
mx"+cx'+kx=0
c=2ζ√(2mk)
δ=ln(xn/(xn+1) and δ=(2πζ)/(√(1-ζ²) where π=symbol for pi
m=20+2=22kg
22x"+kx'+cx=0
xo=.02m
xf=.08m
δ=ln(xf/xo) = ln(.08/.02) = 1.386
δ=(2πζ)/(√(1-ζ²) which becomes
1.386√(1-ζ²)=2πζ which becomes 4πζ²=(1.386²)(1-ζ²) which becomes
ζ=√((1.386²)/((4π²)+(1.386²))) = 0.215 (ζ<1 so system is underdamped)
c=2ζ√(mk) = 2(0.215)√(22*k) = 2.017√(k) N-s/m
I am not sure if I found c correctly since I added the 2kg mass. Also I am unsure as how to find k.
Thank you for your post. It seems like you have made a good attempt at solving the problem. However, there are a few things that need to be addressed in order to find the correct values for k and c.
Firstly, when solving for the damping coefficient, you correctly used the formula c=2ζ√(mk). However, the value of ζ that you used (0.215) is incorrect. In the formula δ=ln(xf/xo), xf and xo should be the amplitudes for the first and second peaks, respectively. In this case, xf=0.08m, but xo should be the amplitude of the first peak, which is not given in the problem statement. Without knowing this value, we cannot accurately solve for ζ and therefore cannot find the correct value for c.
Similarly, when trying to solve for k, we need to know the value of the natural frequency ω. This can be found using the formula ω=√(k/m), where m is the total mass of the system (22kg in this case). However, we also need the value of ω in order to solve for k. This can be found by using the formula ω=2πf, where f is the frequency of the oscillations (given in the figure as 0.5 Hz). Therefore, we can solve for k by setting these two equations equal to each other and solving for k.
In summary, in order to accurately solve for k and c, we need to know the amplitude of the first peak and the natural frequency of the system. Once we have this information, we can use the equations you have listed to find the correct values for k and c.
I hope this helps. Let me know if you have any further questions or need clarification on any of the concepts discussed.
1. What is a dynamical system?
A dynamical system is a mathematical model that describes how a system changes over time. It is comprised of a set of equations that represent the behavior of the system, and can be used to predict the future state of the system based on its current state.
2. What is a 20kg spring/damper system?
A 20kg spring/damper system refers to a physical system that consists of a 20kg mass attached to a spring and a damper. The spring provides a restoring force that is proportional to the displacement of the mass, while the damper provides a dissipative force that is proportional to the velocity of the mass.
3. How do you solve a dynamical system homework problem?
To solve a dynamical system homework problem, you will need to use the equations that describe the system's behavior to determine the values of the variables at different points in time. This can be done analytically using mathematical techniques, or numerically using computer software.
4. What are the key factors to consider when solving a dynamical system problem?
When solving a dynamical system problem, it is important to consider the initial conditions of the system, the forces acting on the system, and any constraints or external influences that may affect the system's behavior. It is also important to carefully analyze the equations and choose appropriate methods for solving them.
5. What are the real-world applications of solving dynamical systems?
Dynamical systems have many practical applications in fields such as physics, engineering, economics, and biology. They can be used to model the behavior of physical systems such as mechanical systems, electrical circuits, and chemical reactions. They can also be used to study complex systems such as weather patterns, population dynamics, and financial markets.
  • Mechanical Engineering
