Entropy of a rubber-band (force determined by entropy or energy)?
In summary, the force equation states that the slope is (-\frac{\partial f}{\partial T})_l=-(\frac{\partial S}{\partial l})_T and the intercept is (\frac{\partial U}{\partial l})_T. The entropy term makes a much bigger contribution to the force than the energy term.
sdnnet3
The resultant of a experimental run of a force (N) vs temperature (K) gives me a slope of 0.0039x - 1.0929. The slope has a (∂f/∂T)l = (∂S/∂l)T
Equation (11) attached as PNG file
We can obtain all the quantities of the right side of Eq. (11) by studying the force at difference temperatures for given extensions. A plot of f versus T has a slope (∂f/∂T)l and the intercept gives the energy change with length at a given T. As we have seen, the term -(∂f/∂T)l = (∂S/∂l)T gives the entropy change with length at a given T. It is thus possible to investigate whether f is determined principally by (∂U/∂l)T or (∂S/∂l)T
My issue is really just trying to figure out what wins. the intercept I'm assuming is the ∂U of energy they are talking about, and that the slope at a given temperature that overcomes the intercept energy and that would be the tipping point where force is determined by one and not the other. I'm assuming that the negative intercept is our restoring force.
So am I correct in this line of thinking, or am I way off?
According to Eqn. 11, the slope is [itex](\frac{\partial f}{\partial T})_l=-(\frac{\partial S}{\partial l})_T[/itex] and the intercept is [itex](\frac{\partial U}{\partial l})_T[/itex]. The question is: which makes a bigger contribution to the force f, [itex](\frac{\partial U}{\partial l})_T[/itex] or [itex]T(\frac{\partial f}{\partial T})_l=-T(\frac{\partial S}{\partial l})_T[/itex]?
I think what you will find is that the entropy term makes a much bigger contribution to the force than the energy term. This is because the configurational entropy change associated with the extension of the polymer molecules when the rubber is deformed relates to the molecules acting like microscopic springs.
ahhh, makes a lot more sense when you think of it like little springs. many thanks, entropy has been a bit tough to wrap my head around it seems. Thanks for the help.
What is entropy?
Entropy is a measure of the disorder or randomness in a system. It is a thermodynamic property that describes the amount of energy that is unavailable to do work.
How does entropy relate to a rubber-band?
In the case of a rubber-band, entropy relates to the disorder or randomness of the molecular structure of the rubber. When the rubber-band is stretched, the molecules become more disordered, increasing the entropy.
Is the force of a rubber-band determined by entropy or energy?
The force of a rubber-band is determined by a combination of both entropy and energy. The stretching of the rubber-band increases the entropy, while the elastic energy stored in the band also contributes to the force.
Why does a stretched rubber-band return to its original shape?
When a rubber-band is stretched, the molecules become more disordered, increasing the entropy. However, when the rubber-band is released, the molecules are able to return to their original, more ordered state, releasing the stored elastic energy and causing the rubber-band to return to its original shape.
How does temperature affect the entropy of a rubber-band?
Temperature affects the entropy of a rubber-band by changing the molecular motion and therefore the disorder of the molecules. An increase in temperature can increase the entropy, making the rubber-band more stretchy and reducing its force.
