 Quote by A Troubled Man
Again, as asked above, would a test particle follow the same path? As well, considering that the difference in time dilation between one's head and feet is infinitesimally small, how can it account for such a major role in the path followed?
Yes, a test particle would follow the same path, but the analogy starts to break down. At the level of a single test particle I don't know an analogy any more and all I can do is explain the actual math.
So the actual math describes spacetime around the earth as curved. In a curved space any coordinate system you draw is going to have to have curved lines. The way that you physically see if your timelike coordinate is curved is to place accelerometers at rest in your coordinates. If the accelerometer is at rest in your coordinate and reads something other than 0 then it means that your time coordinate is curving. So, in the case of the usual (Schwarzschild) coordinates outside the earth you find that the time coordinate is curving outward at a rate of g.
A free-falling test particle travels in a straight line known as a geodesic. We know that it is a straight line because an accelerometer attached to a free-falling particle reads 0. In the frame of the curved coordinates the geodesics appear to curve.
But, in relativity, it is the surface that is accelerated upwards and not the object exerting a force on the surface.
In relativity both happen. The surface is accelerated upwards, it runs into the object and exerts a contact force on the object to make it accelerate upwards also, and by Newton's 3rd law the object also exerts a force on the object.
