| New Reply |
Fluid velocity vs pressure in taper. |
Share Thread |
| Feb13-13, 09:07 PM | #1 |
I have been running this question through my mind.
If you apply pressure to a fluid (with say a piston) through a straight hole then the faster you push it through with applied pressure then the more back pressure it builds. Until eventually it pretty much locks up. I understand that. Ok if you push fluid through a tapered hole then the fluid velocity should increase and pressure should decrease. My question is will the resistance to applied pressure stay consistent, decrease, or increase with increased applied speed of the piston? |
| Feb15-13, 01:18 PM | #2 |
Any ideas?
Does my question make sense? |
| Feb27-13, 09:01 PM | #3 |
I'm surprised I haven't seen the first response to this question.
I am going to assume that the flow will be at least linear with progressive speed. |
| New Reply |
Similar discussions for: Fluid velocity vs pressure in taper.
| Thread | Forum | Replies | ||
| Fluid Mechanics HW How pressure in a tank affects exit velocity of a fluid | Engineering, Comp Sci, & Technology Homework | 3 | ||
| Fluid dynamics - finding pressure for a rotating fluid | Calculus & Beyond Homework | 2 | ||
| Fluid mechanics: Pressure and Velocity of gas flow in a heated pipe | Engineering, Comp Sci, & Technology Homework | 0 | ||
| Pressure of a fluid from a velocity field | Introductory Physics Homework | 0 | ||
| Pressure and velocity of fluid | Introductory Physics Homework | 1 | ||
