- #36
rcgldr
Homework Helper
- 8,854
- 630
Thrust speed is the speed of the air through the propeller. Advance ratio is the ratio of speed of the air through the propeller divided by the speed of the ground (relative to the cart). Another way to look at this is the distance the prop would move forward for every revolution of the driving wheel, this is equal to effective prop pitch / (gear ratio x wheel circumference).Phrak said:What are thrust speed and advance ratio?
Prop pitch is 6 inches per revolution, wheel circumference is 10.5 inches. Advance ratio would be < (6 / 10.5) < .57 depending on the ratio of effective pitch / physical pitch. The prop also has an advance ratio, (actual air speed) / (prop surface speed), and the effective pitch is the (actual air speed) / (rate of rotation of the prop). The physical pitch of the prop advances 6 inches per revolution, but the air flow through the prop will be less than 6 inches per revolution.swerdna said:The wheel is 8.5cm diameter. The prop is 12 x 6 slow air
I've simplified the prop advance ratio description, as the real thing is a bit more complex. The prop operates in it's own induced wash, and in the imediate vicinity of a typical propeller, there's little change in air speed, mostly just an increase in pressure. Normal prop wash pressure is higher than ambient, so the air continues to accelerate aft of the propeller until it's pressure returns to ambient. The speed of the air at the point when it's pressure returns to ambient is called the exit velocity. For a typical propeller, the air speed through the prop is the 1/2(ambient speed + exit speed). I not sure how much difference there is between effective pitch and actual pitch for the DDWFTTW models, other than it's probably small.
