Why Does Gravity Exist? Exploring the Phenomenon of Gravitational Attraction
  • Thread starter gkangelexa
  • Tags
    Gravity
In summary: Thanks Steve, for the reminder.So, in summary, Newton believed that the gravitational force is due to the force of attraction between objects, and that it is not an explanation for the underlying cause.
gkangelexa
81
so, I know the gravitational force is F = (Gm1m2)/r2... but what makes objects attract each other?
what is it about a big body such as the Earth that makes it have gravity?
Are you looking for WHY, or for HOW?
it is due to "graviton particles".
No, it is not. We have seen no evidence for a graviton yet.
abhishekpant said:
ya you are right graviton is a hypothetical elementary particle , but we can't deny it.
see this link,
http://en.wikipedia.org/wiki/Graviton
thanks
Yes we can. And we must deny it until sufficient evidence is gathered to prove it's existence. If you want to ask specifically about how a graviton is thought to work, then feel free. But we cannot say that gravitons are the carrier of gravity if we have don't have sufficient reason to say they exist yet. Note that I am talking about answering the question "How does gravity work" with the claim that it is because of gravitons. It simply is not the accepted way of how it works.
I don't think I explained it very well, but I hope you understand what I'm saying.
Isaac Newton was asked the very same question in 1676. He said, famously: "I frame no hypotheses." Meaning, that Newton well understood that his theory of gravity was descriptive, not explanatory. Newton was providing an equation that would allow one to calculate the gravitational attraction between two bodies; but he was not putting forth any explanation of the underlying cause.
The fuller quote is:
Hitherto I have not been able to discover the cause of those properties of gravity from the phenomena, and I frame no hypothesis; for whatever is not deduced from the phenomena is to be called an hypothesis; and hypotheses, whether metaphysical or physical, whether of occult qualities or mechanical, have no place in experimental philosophy.
http://www.thenagain.info/Classes/Sources/Newton.html
I think it's well to keep Newton's wisdom in mind. If tomorrow morning they discover the Higgs particle, and the newspapers go on about the "God particle" and announce that now, finally, the physicists have unlocked the secret of the universe; the truth is that they would have done nothing of the kind. We would know that there is a Higgs particle. But we would not know why there is a Higgs particle.
All science can do is describe nature. The underlying causes -- the "why?" -- are beyond science, by definition. Newton knew this. I believe it's still true.
Just my humble perspective on this ... science describes, it doesn't explain.
Fundamentally, I agree.
Although Iam a rookie when it comes to these philosophical arguements, I would like to quote a famous physicist here:
The purpose of theoretical physics is not just to describe the world as we find it,but to explain -in terms of few fundamental principles- why is the world the way it is.
Steven Weinberg
Comparing the following two quotes, highlights Newton's real genius. The comparison should be extended even further. So much of what we think we know today would fall into the same category, of describing rather than explaining. We have a great deal of knowledge about how things interact (the how here being descriptive of the interaction) and very little about the underlying how and why (the how and why here representing the fundamental cause, reason and origin).
Steven Weinberg
Just to clarify something lurking in the OP's post... There's nothing special about the Earth that gives it gravity -- the bigness does not come into it. Of course, any object will produce a gravitational field, however big or small.
I generally agree with the sentiment that science cannot answer the why question. Newton posited no hypothesis for why gravity behaved as it did. Einstein came along and said "Mass warps the geometry of spacetime", but he didn't really answer why this is the case (He produced an equation which perfectly describes how it works, but as to why, who knows?). Maybe in the future someone will come and say "Well obviously mass warps the geometry of spacetime because of X", but then naturally we'll ask "well why does X do that?". At some point you have to just accept some axiom as true and work your way up from there, otherwise there is no ground to stand on, so to speak.
This isn't a Philosophy, but a Physics forum.
Agreed. But there are two types of 'why' question. One is the philosophical' why' as in what is the purpose or meaning. But the physics one is simply 'what causes this? What is the deeper phenomenon?'
(Why does water fall over a cliff? Because of gravity's action. Why does a rainbow have colours. Becuae of diffraction.)
So, while science is meant to describe, really what the OP may be asking is for us to merely describe gravity on a deeper level. 'What property of matter results in it manifesting gravity?'
I know i wanted a physics answer...
Then, why don't you try asking questions in the domain of interest of physics?
This is a physics forum. gravity pertains to physics. I can ask what i want as long as it pertains to physics. I did not know if the explanation to my question would be philosophical or mathematical.
And how is this not in the "domain of interest of physics"?
The best explanation of that is probably the one given by the field equations of general relativity which post #2 gave a Wikipedia link to so you could start there. Yours was a perfectly valid physics question.
Don't get too worked up. Your question was fine; it just needed a little clarification. Has it been answered already?
Steven Weinberg
Sure, but the fundamental principles are only described, not explained. There is always a last layer that is simply experimentally observed and has no theoretical justification.
Yes, this is not your fault.
IMO, science-minded people (read: PFers) often interpret "why" too literally.
See my clarification, post 15.
Personally, I think this should be the default assumption, to-wit: "Hi gkangelexa, I'm going to assume when you say why, you really mean how..."
You mean refraction, me thinks...
This is a little like my question "is gravity an emergent phenomenon?" (and, of course, I had to correct myself and ask if gravity is an "emergent property".
Check out my thread...
https://www.physicsforums.com/showthread.php?t=474303
https://www.youtube.com/watch?v=wMFPe-DwULM​
Yes! and a nice example with the waterfall. We might ask ourselves why, and with physics we end up answering 'how', only you put it much better.
To ask gkangelexa's question in another way, "How is displacement inextricably linked to energy density?"
This is something that shows up in like fashion in quantum mechanics. E,p :: omega,k.
Modern physics (free from philosophy or models of the unseen), has not yet found an answer on that question. However, physics does traditionally include not only mathematics but also models or concepts of the unseen ("philosophy"). For example, "atoms" were for many centuries the object of philosophical debate.
As several "philosophical" physics suggestions have been given already, here's one more by Einstein (see in particular p.19-21):
http://en.wikisource.org/wiki/Ether_and_the_Theory_of_Relativity
Cheers,
Harald
Doh. Too much typing too fast. Thx.
I'll try to answer.
Special relativity came about because Einstein thought that all inertial frames where physically indistinguishable and equivalent. This was successful and has had much experimental support.
Next, general relativity came about because Einstein thought that all frames, in any state of relative motion, were equivalent. This includes frames of reference accelerating with respect to one another. This idea is called general covariance.
We could say that gravity exists because the laws of nature are independent of an imposed coordinate system.
  • #31
I am wondering what would go against gravity? I was thinking, if gravity pulls us down, how could we get an object to pull against gravity to make it stand straight up. Like for someone in a wheel chair. Could it be possible to make something that would pull that person up in an upright position?
  • #32
I love how everyone seems to know so much, you ask a question and they throw you a rule of this or according to this it has to be this. This simple question needs to be used by everyone to keep in mind that we just don't know. We have been wrong fare more times then right about most things. At one point in our history we thought the world was flat, that the Earth was the center of all things. Almost nothing is truly known for a fact and can be proven when compared to the almost infinite unknowns. I just spent a lot money on a software program that was suppose to simulate how gravity works as NASA sees it, its suppose to be a copy of the program NASA uses to project orbits with some tweaks. I ran the pre loaded version of are solar system and let it run with in 3 years Venus was flying past Saturn with the latest RK4 (Runge Katta) calculations. I have been in my free time trying to find a simple formula or formulas to show how energy is transferred from different bodies in motion. If conservation of energy is right that means every time Earth orbits the sun energy has to be moved from Earth to the sun and to the surrounding starts and Milky way galaxy and to the local cluster and then back to Earth to keep it in a stable orbit because of its change velocity. What carries this energy? Look at the theory of expansion (assuming that the red shift we use is right) what we know about gravity tells us the universe should be slowing down not speeding up. If that is right where is all this energy coming from to expand everything. Sorry for being long winded.
In short I don't have a freaking clue why there is gravity, but I can come up with a lot of reasons there should be gravity.
  • #33
No it doesn't. What would make you say that.
  • #34
As a TA in 127 calculus, your attitude towards students and others who wish to learn and inquire about physics does not belong on these forums.
  • #35
How do you know if I am a TA in '127 calculus'?
  • Other Physics Topics
  • Classical Physics
