Water Triple Point 273.1598?
by Diego Saravia
Tags: point, triple, water
Borek
Borek is offline
#2
Apr5-12, 05:26 PM
Admin
Borek's Avatar
P: 22,691
Perhaps a historical artifact? Original definition of deg C used melting and boiling temperatures of water, perhaps 273.1598 is a triple point measured using these old degrees. In 1954, after Kelvin was defined as exactly ##\frac 1 {273.16}## both Celsius and Kelvin slightly changed. But I am just guessing.
ErolDynamics
ErolDynamics is offline
#3
Apr5-12, 05:26 PM
P: 16
they are so closed numbers not to to much go through that :D
256bits
256bits is online now
#4
Apr5-12, 06:39 PM
P: 1,263
The first site you reference states
La única combinación de presión y temperatura a la que el agua, hielo y vapor de agua pueden coexistir en un equilibrio estable se produce exactamente a una temperatura de 273.1598 K (0.0098 ° C) y a una presión parcial de vapor de agua de 611,73 pascales (6,1173 milibares, 0,0060373057 atm).
which I take that the one temperature is exact.
I think Borus is correct. The defining of the Kelvin scale left the Celcius scale to be redefined as the triple and boiling point of water and that was "assumed" to be 273.16 K. Experimentation afterwards found the actual triple point was not 0.01 C and therin lies the descrepancy.
nasu
nasu is offline
#5
Apr5-12, 07:44 PM
P: 1,904
Quote Quote by Diego Saravia View Post
It seems that the question is "what is the source of the 272.16 value" that you show here.
I looked at the first link indicated in the post. I did not read it all, it's a long pdf. However it refers several times to the triple point temperature as 273.15..
The second link does not work for me.
It is somehow interesting that the triple point of the ionic liquid 1-Methylimidazole is reported as 272.16. Is it possible that you confused some values?
The link is here:
http://www.chemie1.uni-rostock.de/pc...cations/62.pdf
For water it is about 273.16K
http://physics.nist.gov/cuu/Units/kelvin.html
Register to reply
Related Discussions
What in heaven's name is the "'Water Triple Point"'? Classical Physics 9
C60 Triple Point? Chemistry 8
Temperature change of water at triple point in a constant-volume gas thermometer Advanced Physics Homework 0
Why triple point of water is higher than freezing point Classical Physics 7
Basic question regarding triple point of water and physical properties of water Introductory Physics Homework 9
