Questions about conservation of momentum
by sgstudent
Tags: conservation, momentum
sgstudent
sgstudent is offline
#1
Jan30-13, 09:05 PM
P: 636
What does having no external force on a closed system mean? For example if I have 2 objects colliding. One travels at a constant speed while the other travels with a constant acceleration. In this case is an external force being applied on the system?
If so, only the m1u1+m2u2=m1v1+m2v2 can be used if the two objects have a constant velocity?
Also, during the collision won't there be a force being applied on the object? So how would momentum be conserved? During the collision the formula F=change in mv/time is used. So is the conservation only after this collision?
Thanks for the help
Phys.Org News Partner Physics news on Phys.org
Physicists consider implications of recent revelations about the universe's first light
Vacuum ultraviolet lamp of the future created in Japan
Grasp of SQUIDs dynamics facilitates eavesdropping
Khashishi
Khashishi is offline
#2
Jan30-13, 09:16 PM
P: 833
An object can't accelerate without some applied force. Momentum isn't conserved if you have an external force on the system. Actually, the change in total momentum is equal to the external force.
sgstudent
#3
Jan30-13, 09:27 PM
P: 636
Quote Quote by Khashishi View Post
Oh, you mean the change in momentum is equal to the external force multiplied by the duration of it?
So if there is an external force, how will the collision be like? Or are we unable to solve for the final velocities.
stevendaryl
stevendaryl is offline
#4
Jan30-13, 09:33 PM
P: 1,657
Quote Quote by sgstudent View Post
Thanks for the help
If the only interactions that you are considering are collisions, then "no external force" means that all objects travel at constant velocity between collisions.
During the collision, you're certainly right that there are forces involved. But Newton's third law implies that the total change in momentum due to a collision is zero. So the vectorial sum of the momenta of all the objects is the same before and after the collision. (Assuming once again that the only interaction is collisions).
Register to reply
Related Discussions
questions about conservation of momentum and energy Introductory Physics Homework 0
Conservation of Momentum Conceptual Questions Introductory Physics Homework 1
Linear momentum conservation vs angular momentum conservation Classical Physics 2
Conservation momentum questions help Introductory Physics Homework 1
Law of the Conservation of Angular Momentum > Principle of Conservation of Momentum General Engineering 0
