Temperature is base on the average kinetic motion of all atoms
In summary, The formula v= \sqrt{\frac{3RT}{\mu}} calculates the root mean square velocity of a gas particle in an ideal gas, but it does not apply to situations involving a box filled with air and then closed quickly. In the latter case, the temperature inside the box is different from the outside due to the equipartition of energy among the air molecules.
ntc2019
Sorry for this silly question , I am still high school student . I know that temperature is base on the average kinetic motion of all atoms. But kinetic motion is not absolute so in what case should we use this formula: v= [tex]\sqrt{\frac{3RT}{\mu}}[/tex] . Should it be the velocity in respect to the center of mass? In that case , two objects have the same average velocity may have different temperature like that when we open a box fill with vacuum and close it fast enough when the temperature inside that box is different from outside because the air only go in the box in one way . Thank you for reading my question .
Science news on Phys.org
The formula you have given is for the root mean square (RMS) velocity of a gas particle in an ideal gas. It does not apply to the situation you describe with a box filled with air and then closed quickly. The temperature inside the box would be different from the outside because the air molecules inside the box are colliding with each other, transferring energy from one to another, which increases the temperature. This process is known as the equipartition of energy.
What does "temperature is based on the average kinetic motion of all atoms" mean?
This statement means that the temperature of a substance is determined by the average speed at which its atoms are moving. The faster the atoms are moving, the higher the temperature will be.
How is temperature related to the movement of atoms?
The movement, or kinetic energy, of atoms is directly related to the temperature of a substance. As the temperature increases, the atoms move faster, and as the temperature decreases, the atoms move slower.
Why is the average kinetic motion of all atoms a good measure of temperature?
The average kinetic motion of all atoms is a good measure of temperature because it takes into account the movement of all particles in a substance. This provides a more accurate representation of the overall energy of the substance.
How does temperature affect the behavior of atoms?
Temperature affects the behavior of atoms by influencing their movement and collisions with other atoms. At higher temperatures, atoms have more kinetic energy and move more quickly, increasing the chances of collisions and chemical reactions.
What units are used to measure temperature based on the average kinetic motion of all atoms?
The most common unit used to measure temperature based on the average kinetic motion of all atoms is Kelvin (K). However, other units such as Celsius (°C) and Fahrenheit (°F) can also be used and can be converted to Kelvin using specific formulas.
  • Thermodynamics
20K
  • Thermodynamics
