| New Reply |
Bernoulli's Equation |
Share Thread | Thread Tools |
| Nov3-12, 12:24 PM | #1 |
Hi all,
please i would like to know physically why when the pressure increase the speed decrease and vice-versa in a flow? Thanks |
| PhysOrg.com |
physics news on PhysOrg.com >> Promising doped zirconia >> New X-ray method shows how frog embryos could help thwart disease >> Bringing life into focus |
| Nov3-12, 12:55 PM | #2 |
Recognitions:
Think of this the other way around. Imagine you have a higher pressure zone and a lower pressure zone reasonably close to each other. The flow will accelerate away from the higher pressure zone towards the lower pressure zone. As long as there are no additional forces or work done on the flow other than the pressure zones, then Bernoulli applies and Bernoulli equation relates the increase in speed versus the decrease in pressure of the flow between the two pressure zones.
There would need to some external energy source in order to create and/or maintain those pressure zones, but Bernoulli isn't being applied to that process, only to the flow between the two pressure zones. |
| Nov3-12, 01:00 PM | #3 |
thank you.. so the pressure of the fluid is doing work(internal energy let's say) on the fluid right?
| Nov3-12, 01:08 PM | #4 |
Recognitions:
Bernoulli's EquationWhere Bernoulli doesn't apply is in the case where external work is done on a flow. For example, in the immediate vicinity of a propeller, there's a pressure jump with little or ideally, no change in speed. This the area where work is performed by the propeller, which violates Bernoulli. However Bernoulli does apply to the flow fore and aft of the propeller, assuming no other external forces are involved. |
| Nov3-12, 03:44 PM | #5 |
| Nov3-12, 06:42 PM | #6 |
they even have their uses. |
| Nov3-12, 07:19 PM | #7 |
Typically though, unless these specific forms are mentioned, bernoulli's equation means the form applied along a streamline, for steady state, imcompressible, and inviscid flow. |
| New Reply |
| Thread Tools | |
Similar Threads for: Bernoulli's Equation
| Thread | Forum | Replies | ||
| Continuity Equation and the Bernoulli's Equation | Advanced Physics Homework | 0 | ||
| Blood flow, Bernoulli's equation and Poiseuille's equation | General Physics | 3 | ||
| Differential Equation - Bernoulli Equation | Calculus & Beyond Homework | 5 | ||
| Deriving equation for ideal fluid flow problem (~bernoulli equation) | Introductory Physics Homework | 0 | ||
| Hagen–Poiseuille equation vs Bernoulli's equation Conflict | Mechanical Engineering | 9 | ||
