Why cant an object travel faster than the speed of light?
In summary: You've reached the speed of light.In summary, it is a fundamental part of the theory of special relativity that it takes an infinite amount of energy to accelerate anything with mass to the speed of light. One simple part is that it takes an infinite amount of energy to do so. This is because if you were to accelerate an object to the speed of light, its mass would increase and it would become harder and harder to do so. Time also slows down for objects as they reach the speed of light, so even if you were to reach the speed of light, you would still only be traveling at a fraction of the actual speed.
homeylova223
104
What is the reason for this?
It is a fundamental part of the theory of special relativity. One simple part is that it takes an infinite amount of energy to accelerate anything with mass to the speed of light.
it would need infinite energy to do so.
Why would it take infinite energy?
I mean the speed of light is a fixed number so is there not a fixed number of energy unit that can reach this speed.
Do you understand and believe that every observer, no matter how much they have accelerated in the past will still measure the speed of light to be that same fixed number? So let's say that you have an infinite amount of energy in your rocket and you turn it on for a certain period of time and change your speed by one-half the speed of light. When you make another measurement of the speed of light, it's the same as it was before. You can repeat this process as many times as you wish and you will be no closer to achieving the speed of light than you were before you started. Do you understand this? If this were not the case, then there would be some states of rest that are different than others making them preferred.
But why would you go one half the speed of light If I want to go 100 percent the speed of light?
Most people can see the difference between 1/2 and 100 percent.
I mean light goes 365,000 km/s according to observations.
Force is mass times acceleration
Therefore
acceleration is Force/mass
If a strong enough force is applied an object could accelerate faster than the speed of light.
It's hard to understand because it doesn't match anything that a human being can experience in everyday life. But there a are a few reasons why you can't reach the speed of light. For one, as you go faster and faster, your mass increases (weird, but that's just how it works)...making it harder to go faster and faster. The result it that you can keep getting closer to the speed of light, but the harder you try the harder it gets...and you will NEVER actually reach it. Not even if god himself pushed your spaceship.
Another thing that stops you is that as you go faster, time slows down for you. Again, weird, but it just does. Literally...your watch will show one hour has passed, while on Earth perhaps a year or century has passed. The result is that you can be close to the speed of light and hit the gas and feel a huge surge of acceleration...BUT, in fact if someone on Earth measured your acceleration it might be close to zero, because what was a second for you might be a thousand years on earth.
So then you might try to measure your speed, perhaps against a light beam. Well...that's useless, because light ALWAYS travels at the speed of light away from you. Even if you yourself are going at 99.9999% the speed of light. Again, doesn't make sense but that's how it is. Trying to catch a light beam would be like trying to reach the horizon.
So basically, the universe doesn't allow you to reach this speed. Your mass rises, your energy rises, your time slows, bunch of other things happen. In order for you to get to the speed of light, your mass would have to be infinity, your energy infinity, and time would be zero. Not even the mathematics allow you to do this, as you'd end up multiplying by infinity and dividing by zero and, well, good luck with that...
Therefore
Well, perhaps the easiest way to explain is that it turns out that equation is wrong. It works pretty well at low speed, but fails at high speed. Newton didn't have access to a particle accelerator, so he didn't know.
How can this instrument "particle accelerator" provide evidence an object cannot accelerate to the speed of light?
According to Newton, today's particle accelerators are so powerful that they should be able to F=ma the hell out of a particle waaaaaaaaaay past the speed of light, but yet they still can't reach it.
We keep making particle accelerators multiple times more powerful than the ones before them, and yet all they can do is add another 9 to the 99.9...9% the speed of light that the particles actually reach.
All we have to do is to somehow convert a material object to light, then send the light to a destination. Problem solved. :) Then convert back to the material object.
It still won't be faster than the speed of light.
Therefore
With low velocities, the formula for calculating the velocity, v, after an acceleration, a, for a time, t, is:
[tex]v = a t[/tex]
So this says you could apply any acceleration for a long enough time and get v to exceed c. Or if you had a high enough acceleration, for a shorter time, it says you could get v to exceed c.
But this formula is only an approximation where the velocities end up being very small compared to c.
The correct formula is:
[tex]v = \frac{a t}{\sqrt{1+(a t/c)^2}} [/tex]
If you look carefully at this formula you will see that when [tex]a t[/tex] is very small, the formula approximates to:
[tex]v < \frac{a t}{\sqrt{1}} [/tex]
[tex]v < a t [/tex]
This is similar to the original formula.
But when [tex]a t[/tex] is very large, the formula approximates to:
[tex]v < \frac{a t}{\sqrt{(a t/c)^2}} [/tex]
[tex]v < \frac{a t}{(a t/c)} [/tex]
[tex]v < \frac{1}{(1/c)} [/tex]
[tex]v < c [/tex]
So in reality, no matter how much you accelerate, or how long you accelerate, you can never reach c.
Now to answer your other question about going one half the speed of light, I was trying to show you that since it is possible to accelerate to that speed, then you should be able to get to 100%c in two accelerations and even faster in three, correct? The only problem is that after each step, if you measured the speed of light, you will still measure it as c and you will be no closer than you were before you started. You could repeat this as many times as you wished and still not get any closer to the speed of light.
its all in the details! :cool: The required energy to move an object to the speed of light becomes infinity as you get near the speed of light with Einsteins' field equations. And if you think that's weird, check out Time Dilation and Length Contraction. Try those out for fun! Happy Travels!
1. Why is the speed of light considered the maximum speed an object can travel?
The speed of light, also known as c, is considered the maximum speed an object can travel because it is the fundamental constant of the universe. It is a physical constant that is present in the equations that describe the behavior of light and other electromagnetic radiation. This constant is the ultimate speed limit in the universe and is a fundamental part of the fabric of space and time.
2. What happens if an object travels faster than the speed of light?
If an object were to travel faster than the speed of light, it would violate the laws of physics as we know them. This would mean that the object would have to travel back in time, which is not possible according to our current understanding of the universe. Additionally, as an object approaches the speed of light, its mass and energy would increase infinitely, making it impossible for it to reach or exceed the speed of light.
3. Can anything in the universe travel faster than the speed of light?
According to our current understanding of physics, nothing can travel faster than the speed of light. This includes both matter and information. While there have been some experiments that have shown particles appearing to travel faster than the speed of light, these have been later disproven or explained by other phenomena.
4. Why is it difficult for objects to travel at the speed of light?
As an object approaches the speed of light, it would require an infinite amount of energy to accelerate it further. This is because the object's mass and energy increase as it approaches the speed of light, making it more and more difficult to accelerate. Additionally, time would appear to slow down for the object, making it difficult for it to reach the speed of light in a finite amount of time.
5. Is it possible for the speed of light to change?
According to our current understanding of physics, the speed of light is a fundamental constant of the universe and cannot be changed. It is a property of the fabric of space and time and is not affected by external factors. However, some theories, such as string theory, suggest that the speed of light may not be constant in other dimensions or universes, but this has not been proven.
