Register to reply
Solution of a Differential equation (Linear, 1st order). x=dependent variable
by coolhand
Tags: differential eqns
Share this thread:
coolhand
#1
Jun30-12, 09:13 PM
P: 15
the problem is as follows:
[1-(12*x*(y^2))]*(dy/dx)=y^3
we need to solve this equation such as x=5 & y=2 by regarding y as the independent variable.
Here is my work for the first attempt:
Step 1)separation & integration
Step 2)ln(x)= (-1/(2y^2))-12ln(y)+C
x=Ce^(-1/(2y^2)) +(1/(y^12))
x(y)=5.665
anyone know where I went wrong?
Phys.Org News Partner Science news on Phys.org
Bees able to spot which flowers offer best rewards before landing
Classic Lewis Carroll character inspires new ecological model
When cooperation counts: Researchers find sperm benefit from grouping together in mice
Simon Bridge
#2
Jun30-12, 09:36 PM
Homework
Sci Advisor
HW Helper
Thanks
Simon Bridge's Avatar
P: 12,475
I'll translate your text to atex and you tell me if I've understood you:
You started with the following to solve...
[tex]\left [ 1-12xy^2 \right ] \frac{dy}{dx} = y^3[/tex]...but you want the solution in the form [itex]x=f(y)[/itex]...you can solve for y=f(x) and change the variable or figure how dy/dx is related to dx/dy.
Anyway - you did it the first way and you are pretty sure of your solution:
[tex]\ln{(x)} = -\frac{1}{2y^2} - 12\ln{(y)} + c[/tex]
Taking the exponential of both sides gives me:
[itex]x = C \exp{ \big [-\frac{1}{2y^2} - 12\ln{(y)}\big ]}[/itex] which is:
[itex]x = C \exp{ [-\frac{1}{2y^2}]}\exp{[\ln{(y^{-12})}]}[/itex]... does this make sense?
coolhand
#3
Jun30-12, 10:20 PM
P: 15
Simon,
that makes sense, we essentially came to the same solution of the general equation. However, when I plug in for the given x & y values to solve for "C", I get a huge number on the order of 2*10^4
to interconvert between dy/dx, can you just simply invert (given that you invert the functions as well)?
Simon Bridge
#4
Jul1-12, 12:03 AM
Homework
Sci Advisor
HW Helper
Thanks
P: 12,475
What I got was different to your result of x=Ce^(-1/(2y^2)) +(1/(y^12)) which I read as:
[tex]x = C\exp{\left [ -\frac{1}{2y^2} + \frac{1}{y^{12}} \right ]}[/tex] which tells me that [tex]C=x\exp{\left [ \frac{1}{2y^2} - \frac{1}{y^{12}} \right ]}[/tex] ... when I put in x=5 and y=2, I get C=36.936.
Mine is different - it's the y^12 that throws it out ... and I get about C=30,000.
... always assuming the solution you got is correct. Any reason to suspect C is not big?
SammyS
#5
Jul1-12, 12:23 AM
Emeritus
Sci Advisor
HW Helper
PF Gold
P: 7,801
Quote Quote by coolhand View Post
x(y)=5.665
It looks like your solution to the differential equation is wrong.
Taking the derivative of both side of [itex]\displaystyle \ln{(x)} = -\frac{1}{2y^2} - 12\ln{(y)} + c[/itex] gives:
[itex]\displaystyle \frac{1}{x} = 2\frac{1}{2y^3}y' - 12\frac{1}{y}y' [/itex]
and finally [itex]\displaystyle y^3 = \left(x - 12xy^3\right)\frac{dy}{dx} [/itex]
It doesn't look like your D.E. is separable.
Find an integrating factor to make it exact.
Simon Bridge
#6
Jul1-12, 01:50 AM
Homework
Sci Advisor
HW Helper
Thanks
P: 12,475
I think the y^12 indicates that an integrating factor has been tried... but when I tried it I got a different solution. Advise to OP: revisit the differential equation. Check the algebra.
SammyS
#7
Jul1-12, 01:50 PM
Emeritus
Sci Advisor
HW Helper
PF Gold
P: 7,801
Rewrite [itex]\displaystyle \left [ 1-12xy^2 \right ] \frac{dy}{dx} = y^3[/itex]
as [itex]\displaystyle \frac{dy}{dx}=y^3+12xy^2\,\frac{dy}{dx}\,.[/itex]
Multiply through by [itex]y^9\,.[/itex]
[itex]\displaystyle \frac{d}{dx}\left(x\cdot f(x)\right)=f(x)+x\cdot\frac{d}{dx}\left(f(x) \right)[/itex]
coolhand
#8
Jul1-12, 05:38 PM
P: 15
So I just tried reworking through my algebra, starting with Sammy's suggest of rewriting the function as :
(dy/dx)=y3+12xy2(dy/dx)
However, I had some confusion about multiplying through using y9. Is that step generating an integrating factor such that:
y= [([itex]\int[/itex]Q(x)*M(x)dx)]/(M(x))
then, P(x)= [M(x)']/M(x)
then the integrating factor would be e^([itex]\int[/itex]P(x))?
If so, I was confused as to which function would be the appropriate Q(x), in the form that you re-wrote it in, it seemed to be y^3. However, I could be completely mistaken.
Using y^3 as Q(x), I calculated P(x)=e^([itex]\int[/itex](9/y))
The integrating factor was then:
C(e9)+y
That doesn't seem right
Simon Bridge
#9
Jul1-12, 06:55 PM
Homework
Sci Advisor
HW Helper
Thanks
P: 12,475
Aside: Get into the habit: what is it about the function that leads you to think "that doesn't seem right"? You get a gut reaction: "ugh - somefink rong - tell brain", try investigating to figure what triggered the reaction.
[itex]y^9[/itex] is the integrating factor. Multiply through to give:
[tex]y^9 \frac{dy}{dx} = y^{12} + 12xy^{11} \frac{dy}{dx}[/tex]... then identify P(x,y) and Q(x,y).
Hint: Try rearranging so that it has form: P(x,y)+Q(x,y)y' = 0
HallsofIvy
#10
Jul1-12, 07:15 PM
Math
Emeritus
Sci Advisor
Thanks
PF Gold
P: 39,353
You are missing the most important point if you want us to point out a mistake: how did you separate? This looks to me like it is not a separable equation.
x(y)=5.665
As you said in your title, this is a linear equation. Writing it as a function x, in terms of variable y, it is [itex]dx/dy+ 12y^2x= 1/y[/itex]. There is a standard formula for the integrating factor of a linear equation.
SammyS
#11
Jul1-12, 11:02 PM
Emeritus
Sci Advisor
HW Helper
PF Gold
P: 7,801
Quote Quote by HallsofIvy View Post
I get [itex]\displaystyle \left(y^3\right)\frac{dx}{dy}+ 12y^2x= 1\ .[/itex]
This is equivalent to [itex]\displaystyle \frac{dx}{dy}+ 12\frac{x}{y}= \frac{1}{y^3}\ .[/itex]
coolhand
#12
Jul3-12, 12:08 AM
P: 15
Ok, so after reworking this problem a few more times, I think I'm finally close the right solution:
using y12 as the integrating factor, and Q(x)=1/y3:
=[itex]\int[/itex]Q(y)P(y)
=[itex]\int[/itex]y9+C
5=(1/10)(210)+C
C=(-487/5)
x(y)=(1/P(y))Q(y)P(y)+C]
x(y)=(y-12) [itex]\int[/itex][((1/10)y10)-(487/5)]
x(y)=(1/(10y2))-(487/(5y12))
however when I input this as an answer it was wrong. Should I have solved for C later in the problem (i.e. right before my final answer)?
Register to reply
Related Discussions
Second order differential equation with variable coefficients Differential Equations 0
Firs-order linear equation with reversed role of independent and dependent variable Differential Equations 11
General Solution to Linear, Homogenius, Second-Order Differential Equation Differential Equations 3
Second Order homogeneous linear differential equation solution Calculus 7
