Magnetic field-determine the plane of coil makes with verticle
In summary: A)(0.0100T)(0.100m)^2}\right)$Calculating, we get $\theta \approx 4.0^\circ$.(b) The torque acting on the coil due to the magnetic force at equilibrium is given by $\tau = IBS\sin\theta$, where $\theta$ is the angle the coil makes with the vertical. Substituting in the given values, we have$\tau = (3.40A)(0.0100T)(0.100m)\sin(4.0^\circ) \approx 3.4m(mN)$In summary, a 0.100kg wire with
yanyin
a long piece of wire with a mass of 0.100kg and a total length of 4.00m is used to make a square coil with a side of 0.100m. the coil is hinged along a horizontal side, carries a 3.40-A current, and is placed in a vertical magnetic field with a magnitude of 0.0100T. (a) determine the angle that the place of the coil makes with the vertical when the coil is in equilibrium. (b) find the torque acting on the coil due to the magnetic force at equilibrium.
please show steps, the correct answers are (a) 4.0 degree and (b) 3.4m(mN)
(a) The angle of the coil in equilibrium is determined by the torque due to the magnetic force. The torque due to the magnetic force on a current loop in a magnetic field is given by $\tau = IBA$, where $I$ is the current, $B$ is the magnitude of the magnetic field, and $A$ is the area of the loop. Since the area of the loop is given by $A=s^2$, where $s$ is the length of one side of the loop, we can rewrite the expression for the torque as $\tau = IBS^2$. We can set this equal to the torque due to gravity, which is given by $\tau_g = mgL/2$, where $m$ is the mass of the wire, $g$ is the acceleration due to gravity, and $L$ is the total length of the wire. Thus, we have
$IBS^2 = mgL/2$
Solving for the angle $\theta$ that the coil makes with the vertical, we have
$\theta = \tan^{-1}\left(\frac{mgL}{2IBs^2}\right)$
$\theta = \tan^{-1}\left(\frac{(0.100kg)(9.8m/s^2
(a) To determine the angle that the plane of the coil makes with the vertical, we can use the formula:
θ = tan^-1 (mg/ILB)
Where θ is the angle, m is the mass, g is the acceleration due to gravity, I is the current, L is the length of the wire, and B is the magnetic field.
Substituting the given values, we get:
θ = tan^-1 ((0.100kg)(9.8m/s^2)/(4.00m)(3.40A)(0.0100T))
θ = 4.0 degrees
Therefore, the angle that the plane of the coil makes with the vertical is 4.0 degrees.
(b) To find the torque acting on the coil, we can use the formula:
τ = IABsinθ
Where τ is the torque, I is the current, A is the area of the coil, B is the magnetic field, and θ is the angle between the magnetic field and the normal to the plane of the coil.
τ = (3.40A)(0.100m^2)(0.0100T)sin(4.0 degrees)
τ = 3.4m(mN)
Therefore, the torque acting on the coil due to the magnetic force at equilibrium is 3.4m(mN).
1. What is a magnetic field?
A magnetic field is an invisible force that surrounds a magnet or electric current and exerts a force on other magnets or moving electric charges.
2. How is the strength of a magnetic field measured?
The strength of a magnetic field is measured in units called tesla (T) or gauss (G), which represent the amount of force exerted on a charged particle or other magnet.
3. How is the plane of a coil determined in relation to a vertical magnetic field?
The plane of a coil can be determined by using a compass and observing the direction of the needle when placed near the coil. The direction of the needle will be perpendicular to the plane of the coil.
4. Why is it important to determine the plane of a coil in relation to a magnetic field?
Determining the plane of a coil in relation to a magnetic field is important because it allows us to understand the direction and strength of the magnetic force acting on the coil. This information is essential in many applications, such as electric motors and generators.
5. How does the angle between the coil and the magnetic field affect the strength of the magnetic force?
The strength of the magnetic force is directly proportional to the angle between the coil and the magnetic field. When the coil is parallel to the magnetic field, the force will be at its maximum. As the angle between the coil and the magnetic field increases, the force decreases.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
12K
