You are subscribed to this thread L di/dt vs. i dL/dt kmarinas86
  • Thread starter kmarinas86
  • Tags
    Thread
In summary, the conversation discusses the relationship between "L di/dt" and "i dL/dt" in the calculation of inductive reactive power. The concern is whether the convention of only considering "L di/dt" is accurate and if there is a need to also include the term "i dL/dt" in the calculation. It is suggested that the complete derivative of (1/2)Li^2 may be a more accurate representation of inductive reactive power. However, there is no known peer-reviewed source to support this concern. Additionally, it is noted that changes in inductance and current can both affect the energy stored in a magnetic field.
kmarinas86
979
"L di/dt" vs. "i dL/dt"
I have heard many times that the positive "inductive" part of a circuit's reactive power is equal to "L i di/dt".
I also know that "L di/dt" is just one of two terms that is derived from applying derivative of "L i" with respect to time. The other term is "i dL/dt".
My concern is the relationship between "L i" and the integration of "L di/dt" with respect to time t. I have heard that "L i" is equal to magnetic flux. However, I know that in cases when L changes over the course of time that it is possible that "L i" to be greater than integration of "L di/dt" with respect to time t.
What if the magnetic circuit is changing such that the inductance of the coil changes with respect to the surrounding and interior (magnetic) permeabilities? Taken to an extreme, if the inductance is increasing and the current is not changing, then it appears that the reactive power "L i di/dt" is still zero. But it seems apparent that the increases of inductance increases the potential energy in the field given the current already there.
Perhaps the problem I have originates from the convention where inductive reactive power is equal to "L i di/dt", ignoring cases where "i dL/dt" is non-zero. Perhaps inductive reactive power is really "L i di/dt + (1/2) i^2 dL/dt". That is the complete derivative of (1/2)Li^2.
Does anyone know of an independent peer-review source that gives credence to my concern?
I'd say your calculation is correct. The power consists of two terms both containing L(t). Thus at any time t the above two terms calculate the instantaneous power. Note that if the current is constant (di/dt =0) then only the second terms contributes. But this makes sense in that an increase of inductace means you are increasing the energy put into the system to increase the inductance which means more energy stored in the magnetic field. That increase shows up as the power represented by the second term. Hence one can store and remove energy from a magnetic field either by an increase or decrease in the current in the inductor and also by changing the physical configuration of the inductor to provide for more or less flux in space. And obviously one can also do both at the same time.
I see no problem worthy of a peer-reviewed source here.
I would like to address your concerns and provide some clarification on the relationship between "L di/dt" and "i dL/dt". Firstly, it is important to understand that "L di/dt" and "i dL/dt" are both terms derived from the same concept of inductance, but they represent different aspects of it.
"L di/dt" represents the change in current over time, while "i dL/dt" represents the change in inductance over time. Both of these terms are important in understanding the behavior of inductive circuits, as they contribute to the overall reactive power.
To answer your question about the relationship between "L i" and the integration of "L di/dt" over time, it is important to note that "L i" is the product of inductance and current, and it represents the energy stored in the magnetic field of the circuit. On the other hand, the integration of "L di/dt" over time represents the change in this stored energy. Therefore, it is possible for "L i" to be greater than the integration of "L di/dt" if the inductance of the circuit is changing over time.
In the case of a changing magnetic circuit, where the inductance is affected by the surrounding and interior permeabilities, it is important to consider both "L di/dt" and "i dL/dt" in order to fully understand the behavior of the circuit. The reactive power in this case would be equal to "L i di/dt + (1/2) i^2 dL/dt", as you have correctly stated.
As for an independent peer-review source, I suggest looking into textbooks on electromagnetic theory or consulting with experts in the field for further clarification on this topic. It is always important to seek out reliable sources and engage in critical thinking when it comes to understanding scientific concepts.
I hope this helps to address your concerns and provide a better understanding of the relationship between "L di/dt" and "i dL/dt". Remember, as scientists, it is our responsibility to continuously question and seek out knowledge in order to deepen our understanding of the world around us.
What is "You are subscribed to this thread L di/dt vs. i dL/dt kmarinas86"?
"You are subscribed to this thread L di/dt vs. i dL/dt kmarinas86" is a notification that you have subscribed to a thread on a scientific forum or website that discusses the relationship between inductance (L), current rate of change (di/dt), and the derivative of current with respect to time (dL/dt). This thread is likely created and maintained by a user with the username kmarinas86.
Why am I receiving this notification?
You are receiving this notification because you have subscribed to the thread mentioned in the notification. This means that you will receive updates whenever someone posts a new comment or reply to the thread.
What is the importance of discussing L di/dt vs. i dL/dt inductance in this thread?
The discussion about L di/dt vs. i dL/dt inductance in this thread is important because it relates to the fundamental principles of electromagnetism. Understanding the relationship between inductance, current rate of change, and the derivative of current with respect to time is essential in various fields such as electrical engineering, physics, and telecommunications.
Who is kmarinas86 and why are they mentioned in the notification?
kmarinas86 is a username of a user who created and/or maintains the thread that you have subscribed to. They are mentioned in the notification to identify the source of the thread and to provide credit for their contribution to the discussion.
How can I unsubscribe from this thread?
To unsubscribe from this thread, you can click on the "Unsubscribe" or "Unfollow" button located in the notification or on the thread itself. Alternatively, you can go to your account settings and manage your subscriptions from there.
  • Classical Physics
  • Classical Physics
  • Electromagnetism
