New Reply
Finding the unknown cordinates of a point on a vector
Share Thread Thread Tools
Dec18-12, 09:55 AM   #1
Relative to the origin O, the position vectors of two points A and B are (1,4) and (7,1) respectively. Give that the point P (t,t+1) is on AB find
1) AP and BP in terms of t
2) Find the value of t and hence the ratio AP:PB
Solution:
1) AP= (-i - 4 j) + ti + (t+1)J = (t-1)i + (t-3)j
BP= -7i -j + ti + (t+1)j =(t-7)i + (t)j
2) I have no idea how to find t.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
Dec18-12, 10:43 AM   #2
Homework Helper 2012
Recognitions:
Homework Helper Homework Help
Quote by EmilyHopkins View Post
Solution:
1) AP= (-i - 4 j) + ti + (t+1)J = (1-t)i + (t-3)j
AP and PB are parallel vectors, since P is on AB, right? How do you express two vectors being parallel in algebra? BTW your expression for AP has a sign mistake.
Dec18-12, 11:02 AM   #3
Quote by Dick View Post
Well if AP and PB are parallel then their cross product is 0.
0 = AP X PB
0= ((t -1)i + (t-3)j) X (( T-7)i + tj)
0 = - (t-3)(t-7)k + (t-1)t k
0 = (3-t)(t-7) k + (t-1)tk
0= (3t -t^2-21+7t)k + (t-1)tk
0= (10t -t^2 -21)k + (t-1)tk
0= (10t -t^2 -21)k +(t^2 - t)k
0= (9t -21)k
9t-21=0
9t=21
t= 7/3
Dec18-12, 11:07 AM   #4
Recognitions:
That would be one way to go if you extend them to three dimensional vectors. It's also true that if they are parallel then they are multiples of each other. k*AP=PB for some constant k.
Dec18-12, 11:20 AM   #5
Wouldn't that just introduce another unknown variable which would require us to have 2 equations in order to solve. I thought this route already but didn't bother going this way since I don't know the ratio, and hence the value of k.
Dec18-12, 11:31 AM   #6
Recognitions:
0 = AP X PB
0= ((t -1)i + (t-3)j) X (( T-7)i + j)
0 = - (t-3)(t-7)k + (t-1) k
0 = (3-t)(t-7) k + (t-1)k
0= (3t -t^2-21+7t)k + (t-1)k
0= (10t -t^2 -21)k + (t-1)k
0= (11t - t^2 -22)k
11t - t^2 -22 =0
a= -1, b= 11, c=--22
t = -11 ± (121 -4(-1)(-22))1/2/2(-1)
t= -1.72 or t= 12.7 ???
You are being pretty sloppy here. (t-7)i + (t)j turned into (( T-7)i + j). Something missing. If you do this right the t^2 will cancel.
Dec18-12, 11:33 AM   #7
Recognitions:
Once you split into components it WILL turn into two equations in the two unknowns t and k. It's about the same amount of work to do it this way as to solve the cross product equation.
New Reply
Thread Tools
Similar Threads for: Finding the unknown cordinates of a point on a vector
Thread Forum Replies
Finding the unknown component of a vector that makes a particular angle with a known Calculus & Beyond Homework 2
finding unknown given vector a,b and parallel Precalculus Mathematics Homework 6
Finding a line passing through a known point/tangent to a curve at an unknown point Calculus & Beyond Homework 1
Finding an unknown charge in a system of discrete point charges. Introductory Physics Homework 1
finding the resultant and eq. for 3 vector on one point Introductory Physics Homework 3
