New Reply
Can't get references sorted alphabetically with BibTeX
Share Thread Thread Tools
Feb18-13, 03:08 AM   #1
Hi all,
Could you help me figure out what packages I should use to get all references sorted alphabetically?
These are the packages and settings I'm using... I've tested many without success:
\usepackage{natbib}
\bibpunct{(}{)}{;}{a}{,}{,}
\bibliographystyle{plainnat}
\renewcommand{\bibname}{Referências}
\bibliography{Referencias}
Thank you in advance
Márcio
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> 'Whodunnit' of Irish potato famine solved
>> The mammoth's lament: Study shows how cosmic impact sparked devastating climate change
>> Curiosity Mars rover drills second rock target
Feb18-13, 08:11 AM   #2
Recognitions:
Do have a look here:
http://amath.colorado.edu/documentat.../bibstyles.pdf
Feb18-13, 08:35 AM   #3
Quote by DrDu View Post
Do you know what package I must use in order to these styles work?
I tried 'biblatex' instead of 'natlib' with a few of those styles you showed me, none of them worked.
Very much appreciated
Márcio
Feb18-13, 09:17 AM   #4
Recognitions:
You don't need any package at all. I would try it out
using only
\bibliographystyle{plainnat} %or whatever style you chose
However it may be that you don't have all of the bibstyles installed on your computer although most of them should come with any modern tex-distribution.
Feb18-13, 09:32 AM   #5
using only
Hi DrDu,
I tried with 4 packages (abbrvnat, plainnat, unsrtnat and apasoft, but the later didn't work at al) which seemed to work for my PhD thesis. All of them showed the references like this:
[Zhu et al.(2005)Zhu, Zheng, Guo, and Zhu]
and not like this:
Zhu et al.(2005)
meaning they all put the names of all authors after they are cited.
Any help will be very much appreciated.
Feb19-13, 05:53 AM   #6
Recognitions:
Maybe you can show us a small example file and some information about what distribution you are using on which platform?
Feb19-13, 07:29 AM   #7
Recognitions:
I could reproduce this. The styles you tried require
\usepackage[sort]{natbib}
Feb19-13, 09:37 AM   #8
It worked like a charm after your suggestion of adding 'sort' and after I replaced 'plainnat' with 'ametsoc'.
I'm using MikTeX on Windows 8.
Thank you very much
Márcio
New Reply
Thread Tools
Similar Threads for: Can't get references sorted alphabetically with BibTeX
Thread Forum Replies
Algorithm Complexity: Sorted Arrays into Sorted Array Engineering, Comp Sci, & Technology Homework 12
How to sort a list alphabetically but ignore numbers? Computers 7
Sort fullnames alphabetically Programming & Comp Sci 1
Merging sorted lists Engineering, Comp Sci, & Technology Homework 0
mY photo isnt included, alphabetically General Discussion 13
