Calculating torque of peristaltic pump
by inacio89
Tags: force, peristaltic, pump, torque
inacio89
inacio89 is offline
#1
Mar21-13, 10:33 PM
P: 1
Please see the attached drawing. I am attempting to create a force diagram of a peristaltic pump with three rollers. I would like to be able to form an equation that will allow me to calculate the torque that the motor needs to overcome in order to begin rotating. Each roller is compressed between the motors shaft and the tube. This compression causes the roller to pinch the tube. I understand that statically there is a force that is directed inwards from the pinch point to the motor shaft. I do not know how to calculate the tangential force though. The force which occurs when the rollers are rotating about the shaft is what I need to calculate in order to determine the torque which the motor must overcome in order to go from a static position to a dynamic one.
Any help or suggestions are greatly appreciated. If more clarification is needed please let me know.
Phys.Org News Partner Physics news on Phys.org
Physicists consider implications of recent revelations about the universe's first light
Vacuum ultraviolet lamp of the future created in Japan
Grasp of SQUIDs dynamics facilitates eavesdropping
Register to reply
Related Discussions
Designing a Peristaltic Pump Mechanical Engineering 0
Peristaltic pump as control valve? Mechanical Engineering 0
How to estimate the Startup torque of a pump motor Mechanical Engineering 3
Torque for a radial vane water pump Classical Physics 0
About calculating a set of hydraulic pump and motor General Engineering 0
