- #1
John1397
- 186
- 18
Does introducing small amount of hydrogen and oxygen with gasoline into an internal combustion engine make the sensor read lean and and just enter more gasoline?
John
John
John1397 said:Sounds like if you put hydrogen or gasoline into a motor the o2 sensor will send back a signal depending if you add to much fuel or to little it would send back a to rich or to lean signal regardless of kind of fuel is added. If you run a motor on 14:1 ratio of either hydrogen, gasoline, or even propane the o2 sensor will send back the same reading if I understand correctly?
The chemical formula for water is H2O, which indicates that it is composed of two hydrogen atoms and one oxygen atom.
Oxygen and hydrogen can be introduced into a chemical reaction by combining them in the presence of a catalyst, such as a metal catalyst or heat.
Oxygen and hydrogen are essential components of cellular respiration, which is the process by which cells produce energy. Oxygen is used to break down glucose molecules, while hydrogen is used to form water as a byproduct.
Oxygen is a colorless, odorless gas that is essential for life and highly reactive. Hydrogen is also a colorless, odorless gas and is the most abundant element in the universe.
Oxygen and hydrogen are used in various industries, such as in the production of ammonia for fertilizers, in the refining of petroleum, and in the manufacture of plastics and other chemical compounds.
