Force required to pull loop from magnetic field
In summary, the conversation discusses the calculation of the force required to pull a rectangular loop of wire from a uniform magnetic field at a constant velocity. The formula for calculating induced EMF is used to determine the current, which is then used in the formula for magnetic force to calculate the force exerted by the magnetic field on the wire. The negative sign indicates that the force is in the opposite direction of the velocity, which aligns with Lenz's law. It is also noted that the force exerted on the horizontal portions of the wire would cancel out due to the current traveling in opposite directions.
t_n_p
595
Part of a single rectangular loop of wire with dimensions shown is situated inside a region of uniform magnetic field of 0.55T. The total resistance of the loop of 0.230ohms. Calculate the force required to pull the loop from the field (to the right) at a constant velocity of 3.4m/s. Neglect gravity.
http://img508.imageshack.us/img508/8268/asdfdr5.jpg
Really don't know where to start! I'm not sure which equations are relevant as F=nBIL will not work because I don't know the current!
Consider the induced emf in the loop...:wink:
I only know to formulas involving EMF.
ε=NBAωsing(ωt) and
ε= -N {ΔΦb/Δt}
neither of which seems to help!
Review the usage of the second equation. :wink:
t_n_p said:
ε= -N {ΔΦb/Δt}
This should be helpful :wink:. Now, the magentic field is constant, so how else can the flux be changing?
Edit: Dammit jt!
ahh, ok
N=1, B=0.55T, ΔA=(0.35*0.75)=0.2625.
I'm unsure as to the value of Δt. My understanding is that it is the value of time for which the coil is fully immersed. The length is 0.75m and it is moving right at 3.4m/s. So is Δt simply 0.75/3.4=0.22 seconds?
Careful;
[tex]\xi = -B\frac{dA}{dt}[/tex]
Now, for constant height;
[tex]\xi = -B\cdot0.35\frac{dl}{dt} = -B\cdot0.35\cdot v[/tex]
Hootenanny said:
Careful;
:eek: Never was taught that formula. Is there any way to come to the same conclusion using the second of the formulas I provided or is this the only way?
Even a similar example (constant height) I have seen utilises the second formula I provided.
This follows directly from Faraday's law and is not something you should learn. Taking Faraday's law and assuming single coil;
[tex]\xi = -\frac{d\Phi}{dt} = -\frac{d}{dt}(B\cdot A)[/tex]
Now, since the magnetic field is constant we can take it oit of the differential;
[tex]\xi = -B\frac{dA}{dt} = -B\frac{d}{dt}(h\cdot l)[/tex]
Now, the height of the coil (h) in the magnetic field doesn't change, it is only the length that changes. Hence;
[tex]\xi = -B\cdot h\frac{dl}{dt}[/tex]
Now, noting that the velocity (v) is in the same direction as the legnth of the coil (l) we can write;
[tex]\xi = -B\cdot h\cdot v[/tex]
Do you follow? As I said before, this is not something you should learn, it is simply an application of Faraday's law.
Ok, got you!
Now I've got emf I find I from V/R
So I=(-0.55*0.35*3.4)/0.23
I=-2.845652174A
Then I use F=nBIL
F=1*0.55*-2.85*L
Just double checking, L is the length of the loop of wire correct (i.e. 0.75m)?
t_n_p said:
Ok, got you!
I=-2.845652174A
Looks good to me
t_n_p said:
Then I use F=nBIL
F=1*0.55*-2.85*L
Careful! L is not 0.75m (or L in my notation above). L in this case is the height, recall that F = q(v x B) and F = i(L x B). The force is perpendicular to the current and legnth of the wire. So, for the force we wish to calculate we must take L= h, if that makes sense?
Bit confusing, but the above statement is very helpful! :cool:
so then F=1*0.55*-2.845652174*0.35
F=-0.5477880435N
negative Newtons, is that possible?
F=-0.5477880435N
Indeed it is. Remember you have calculated the force exterted by the magnetic field on the wire. All the negative sign indicates is that the force exterted by the magnetic field on the wire is opposite in direction to the velocity. And that's what would would expect according to Lenz's law.
You could if you wished, calculate the force exerted by the magnetic field on the horizontal portions of the wire. However, note that in these sections of wire the current would be traveling in opposite directions, therefore the two forces would be in the opposite directions and since the lengths are equal the forces would cancel. I hope that makes a little more sense :smile:
Finally finished!
Thanks so much again!
t_n_p said:
Finally finished!
It was a pleasure :smile: I hope I didn't confuse you too much ...:rolleyes:
This was very helpful. Thanks hoot.
1. What is the force required to pull a loop from a magnetic field?
The force required to pull a loop from a magnetic field depends on several factors, including the strength of the magnetic field, the size and shape of the loop, and the material the loop is made of.
2. How can I calculate the force required to pull a loop from a magnetic field?
The force can be calculated using the formula F = BIl, where B is the magnetic field strength, I is the current flowing through the loop, and l is the length of the loop.
3. What happens to the force required if the magnetic field strength increases?
If the magnetic field strength increases, the force required to pull the loop from the field will also increase. This is because the magnetic field exerts a stronger force on the loop.
4. Does the size of the loop affect the force required to pull it from a magnetic field?
Yes, the size of the loop does affect the force required. A larger loop will experience a greater force from the magnetic field, so it will require more force to pull it from the field.
5. How does the material of the loop affect the force required to pull it from a magnetic field?
The material of the loop can affect the force required in two ways. Firstly, if the material is magnetic, it will experience a stronger force from the magnetic field and therefore require more force to pull it from the field. Secondly, the resistivity of the material can also affect the force, as a higher resistivity material will experience a greater force due to the induced current in the loop.
