Continuity of Electric Field at metal-dielectric interface in capacitor
In summary, it has been known for some time that the electric field inside metal electrodes is continuous, rather than discontinuous as believed by classical electrostatics. Recent ab initio simulation results seem to support this.
chuckschuldiner
Hello Guys
According to Classical electrostatics, when you apply a voltage across a capacitor, +Q and -Q charges are induced on a delta region at the interface of the dielectric and the metal electrode. The electric field inside the dielectric is finite and constant while the electric field in the metal is zero.
However, it has been known for quite some time that due to imperfect electronic screening in real metal electrodes, the charges +Q and -Q are not confined to a delta region at the metal-dielectric interface but are infact distributed in a finite region of space in the metal. This also results in electric field penetration inside the electrodes i.e. due to the distribution of charge inside the metal, electric fields exist inside the metal electrodes.
In addition to this, i have seen some recent ab initio simulation results which seems to show that the electric field is continuos at the metal-dielectric interface (Stengel and Spaldin, Nature 443, 679 (2006)). We know that the potential has to be continuos at the metal-dielectric interface but is it possible that the electric field stays at a nearly constant value inside most of the dielectric but has steep gradients at the metal-dielectric interface so that it also remains continuos at the metal-dielectric interface. Is there any physical argument for this?
When it comes right down to it, the discontinuous field of an 'ideal' capacitor is really just an approximation in the first place, since it requires that the charge on each plate be a true surface charge distribution; when, in point of fact the charge is in the form of discrete, point or point-like objects. So, in reality, even for an ideal capacitor with real charge-carriers, the field is continuous, with a rather large number of poles at the locations of the charges. It just happens that the changes in the field occur over so small a region that they can be approximated by a discontinuity.
In general, these sorts of behaviors can be best understood by looking at what is occurring microscopically to give a metal or dielectric its properties; then, ignoring those effects that are only relevant at very short distances.
Thank you for your reply!
1. What is the role of the metal-dielectric interface in a capacitor?
The metal-dielectric interface in a capacitor serves as the boundary between the two materials, creating a separation of charges and allowing for the accumulation of electric potential energy.
2. Why is continuity of electric field important at this interface?
The continuity of electric field is important at the metal-dielectric interface because it ensures that there are no abrupt changes in electric potential or charge density, which could cause electrical breakdown or affect the overall performance of the capacitor.
3. How is continuity of electric field maintained at the interface?
Continuity of electric field is maintained at the metal-dielectric interface through the presence of bound surface charges on the metal and dielectric surfaces, which create an electric dipole moment and maintain a smooth transition of electric field across the interface.
4. Can the continuity of electric field be disrupted at the interface?
Yes, the continuity of electric field can be disrupted at the interface due to factors such as surface roughness, impurities, or defects in the materials. These disruptions can lead to localized areas of high electric field, which can cause breakdown or failure of the capacitor.
5. Are there any practical applications for understanding continuity of electric field at the metal-dielectric interface in capacitors?
Yes, understanding continuity of electric field at the metal-dielectric interface is important for designing and optimizing the performance of capacitors in various electronic devices, such as computers, televisions, and mobile phones.
  • Electromagnetism
  • Electromagnetism
