What was the motive of michelson morley experiment
In summary, the purpose of the Michelson Morley experiment was to reconcile Maxwell's equations with Newtonian physics by finding the one true inertial frame in which the speed of light is c. However, the experiment failed to detect the aether or the one true frame, leading to the development of special relativity by Einstein. This theory, based on the constant speed of light as axiomatic, ultimately replaced the concept of a luminiferous aether and one true inertial frame. Therefore, Einstein deserves full credit for special relativity.
abhi-iitb
what was the real motive of MM experiment
to measure the speed of light or to measure the orbital speed (or speed of ether) of Earth with respect to stationary ether?
plss anyone reply
The MM experiment could not measure a value for the speed of light, due to the way it was setup.
It used an interferometer, so only could measure a relative change in either the speed of light or length along one arm of the interferometer compared to the other.
If it wasn't for length contraction in SR, maxwell's equations predicted we should be able to detect the Earth's speed through the aether as it orbits the sun. They of course didn't detect anything. It is one of the most celebrated "null results" ever measured.
They expected to measure the speed of the Earth relative to the aether. When it didn't work, they were very disappointed, and they tried very hard to "fix" their experiment. As late as the 1930's, people were still trying to do experiments that would succeed in detecting the aether wind. For instance, they repeated the MM experiment in a tent on top of a mountain, hoping to get rid of problems with the Earth dragging the aether along with it.
The inherent irreconcilability between Maxwell's equations and Newtonian physics at the end of the 19th century was much, much deeper than the conundrum of today, reconciling general relativity with quantum mechanics. Newtonian physics assumes Galilean relativity. Velocities are of course additive in Galilean relativity, and this does not jibe well with Maxwell's equations, which say that electromagnetic radiation travels at c in vacuum.
The purpose of the Michelson Morley experiment was to reconcile Maxwell's equations with Newtonian physics. The two could be reconciled if the one true inertial frame in which the speed of light truly is c could be found. This is the frame in which the luminiferous aether (the medium through which EM waves propagated) is at rest. Many physicists, including some great ones, clung to the concept of a luminiferous aether and the concept of one true inertial frame long after the Michelson Morley experiment failed to show the existence of either.
There has long been some debate over whether Einstein deserves full credit for special relativity. The work of Poincaré, Lorentz, and Fitzgerald in particular are often raised as objections to granting Einstein sole credit. Lorentz and Poincaré developed the Lorentz Ether Theory, which is mathematically indistinguishable from special relativity. The two theories (LET and special relativity) differ in their axioms but not in their predictions. LET, as the name implies, maintained the concepts of an ether and one true inertial frame -- except now the ether was completely unobservable and the one true inertial frame completely unknowable. The Lorentz contraction (axiomatic in LET) hid the ether and the one true inertial frame from view.
Einstein instead took Maxwell's equations at their face value. There is nothing in Maxwell's equations that says a luminiferous aether has to exist, or that the speed of light in vacuum is c (but only if observed from a frame at rest with respect to luminiferous aether). Maxwell's equations quite clearly say that the speed of light is the same to all observers, period. Einstein threw out all that non-essential stuff and started with the speed of light being constant (period) as axiomatic. That move was a huge game changer compared to the LET patchover. In my mind Einstein does indeed deserve full and sole credit for special relativity.
den that means Maxwell's equations came later than relativity
No. How did you read that into what I wrote?
i thot sinc conceptt of aethr exists and at that time it was thought dat even electromagnetic waves require medium 2 travel n maxwel proposd oposite of that so i gues maxwel came later
1. What was the purpose of the Michelson Morley experiment?
The purpose of the Michelson Morley experiment was to detect the presence and properties of a hypothetical medium called the luminiferous ether, which was believed to be the medium through which light waves traveled.
2. Why was the Michelson Morley experiment important?
The Michelson Morley experiment was important because it provided evidence against the existence of the luminiferous ether, which was a widely accepted concept in the scientific community at the time. This experiment also paved the way for the development of Albert Einstein's theory of special relativity.
3. What did the Michelson Morley experiment prove?
The Michelson Morley experiment proved that the speed of light is constant and does not change depending on the motion of the observer or the source of light. This contradicted the predictions of the luminiferous ether theory.
4. How did the Michelson Morley experiment work?
The Michelson Morley experiment used an interferometer, which split a beam of light into two perpendicular paths and then recombined them. If the light was affected by the motion of the Earth through the ether, the interference pattern would shift. However, no such shift was observed, indicating that the Earth was not moving through the ether.
5. Did the Michelson Morley experiment have any limitations?
Yes, the Michelson Morley experiment had limitations. It could only detect the ether wind in one direction, and it assumed that the Earth was moving through a stationary ether. Later experiments, such as the Kennedy-Thorndike experiment, provided further evidence for the constancy of the speed of light and the absence of an ether.
