How do I find the forward resistance of a diode using diode law?
In summary, the conversation discusses finding the resistance of a diode using the Diode Law equation, given variables such as VD, Is, and VT. Two measures of resistance are mentioned: the operating point resistance, which is calculated by dividing voltage by current, and the small signal resistance, which is found by taking the derivative of the Diode Law equation with respect to voltage. The poster is seeking help in understanding how to find the small signal resistance in this particular case.
lilmul123
40
I must find the resistance of a diode inside the piecewise model using the diode law equation.
I am given variables VD = .75V, Is = 5*10^-13 A, and VT = .026 A. n = 1
The Diode Law equation: ID = IS(e(VD/nVT) - 1)
We were told that to find the resistance, we are to find the derivative of this equation to find the conductance, and then the inverse of this would be the resistance. I'm not sure what to derive with respect to or if even this explanation is correct. Can anyone help explain how to find resistance using this equation?
One measure of resistance is the one that describes the operating point of the device: operating voltage divided by operating current. So if you're given the voltage across the device and can calculate the resulting current, then R = V/I.
A second measure of resistance is the 'small signal resistance', which describes how a change in voltage across the device (at the operating point) affects the current: r = Δv/ΔI. This one you might find by taking the derivative of your diode law w.r.t. voltage to find di/dv, and hence dv/di.
It looks like it's the first version of resistance you're after in this case.
Poster needs to find the small signal resistance. (Probably what you meant to say.)
The variables are ID and VD, being the diode current and voltage, all other terms are constants.
You're probably right! :approve:
Thanks for he catch.
Firstly, it is important to note that the term "resistance" is not typically used when discussing diodes. Instead, the concept of resistive behavior in a diode is often referred to as "dynamic resistance" or "incremental resistance." This is because the resistance of a diode is not constant like a typical resistor, but instead varies with the applied voltage.
To find the dynamic resistance of a diode using the diode law equation, we can rearrange the equation to solve for the dynamic resistance (RD):
RD = (1/ID)*(dVD/dID)
Where dVD/dID is the derivative of the forward voltage (VD) with respect to the forward current (ID). This can be found by taking the derivative of the diode law equation:
dVD/dID = (nVT/ID)
Plugging this back into the equation for RD, we get:
RD = (1/ID)*(nVT/ID) = nVT/ID^2
Therefore, to find the dynamic resistance of a diode, we can substitute the given values for VD, IS, VT, and n into this equation. Keep in mind that the diode law equation is an approximation and the actual dynamic resistance may vary slightly.
1. What is the diode law and how does it relate to forward resistance?
The diode law is a mathematical equation that describes the current-voltage relationship in a diode. It states that the current through a diode is exponentially related to the voltage across it. The forward resistance of a diode is simply the reciprocal of the slope of this exponential curve.
2. How do I measure the forward resistance of a diode using diode law?
To measure the forward resistance of a diode using diode law, you will need a power supply, a multimeter, and a diode. Connect the diode in series with the power supply and multimeter. Vary the voltage across the diode and record the corresponding current. Plot the data on a graph and find the slope of the linear portion of the curve. The inverse of this slope will give you the forward resistance.
3. Can I use diode law to find the forward resistance of any type of diode?
Yes, diode law can be used to find the forward resistance of any type of diode, as long as the diode is in its forward biased state. This means that the voltage across the diode is positive and greater than the diode's threshold voltage.
4. Is the forward resistance of a diode a constant value?
No, the forward resistance of a diode is not a constant value. It depends on factors such as temperature, current, and the material the diode is made of. However, it can be approximated as a constant value in many practical applications.
5. What is the significance of knowing the forward resistance of a diode?
The forward resistance of a diode is an important parameter in many electronic circuits. It helps determine the amount of current that can flow through a diode and its voltage drop. It is also used in analyzing the performance and efficiency of diode-based circuits.
16K
  • Electrical Engineering
