Could someone me solve for ε in terms of [itex]\delta[/itex] ?
  • Thread starter azal
  • Tags
    Terms
In summary, Azal is trying to solve for ε in terms of δ, but is not sure if there is a closed form solution.
azal
As part of my problem I need the following condition to hold:
[itex]\frac{2^{n(H+\epsilon)}}{\epsilon}:=\delta^{-\theta}[/itex] for some [itex]\epsilon, \delta[/itex] and [itex]\theta[/itex] all in (0,1).
Now, I would like to rearrange the equation (solve for [itex]\epsilon[itex/] in terms of the rest of the parameters) so as to have the condition be represented as:
[itex]\epsilon = ...[/itex]
So, I played around with it a little bit, to get:
[itex]\epsilon-\frac{1}{n}\log \epsilon = \frac{-t}{n}\log \delta-H[/itex]
I wonder if there is a closed form solution for [itex]\epsilon[/itex] now?
Thanks,
- A.
[itex]\displaystyle \frac{2^{n(H+\epsilon)}}{\epsilon}:=\delta^{-\theta}[/itex] for some [itex]\epsilon, \delta[/itex] and [itex]\theta[/itex] all in (0,1).
Now, I would like to rearrange the equation (solve for [itex]\epsilon[/itex] in terms of the rest of the parameters) so as to have the condition be represented as:
Thanks,
- A.
Hello azal. Welcome to PF.
I fixed a bad tag in the quoted post.
It's usual to solve for δ in terms of ε, not the other way around.
I'm pretty sure there's no way to solve for ε in closed form.
Hi Sammy,
Thanks for your response.
This is not an [itex]\epsilon,\delta[/itex] (limit) proof, although my notation may suggest it is.
I guess I'll have to change the conditions then.
Thanks again,
- Azal.
azal said:
Hi Sammy,
Thanks again,
- Azal.
In that case, the way to solve for ε is numerically.
Thanks.
1. How do I solve for ε in terms of δ?
To solve for ε in terms of δ, you can use the formula ε = δ/2. This equation shows the relationship between ε and δ, and allows you to solve for ε when given a value for δ.
2. What is the meaning of ε in terms of δ?
In this context, ε and δ are variables used in mathematics to represent values in an equation. ε typically represents a small change or error, while δ represents a small interval or difference.
3. Can you provide an example of solving for ε in terms of δ?
Sure! Let's say we have the equation ε = 2δ. To solve for ε, we divide both sides by 2, giving us ε = δ. This means that for every value of δ, ε will be half of that value.
4. Are there any other methods for solving for ε in terms of δ?
Yes, there are other methods such as substitution or using algebraic manipulation to solve for ε in terms of δ. It ultimately depends on the specific equation and the values given for δ.
5. How is solving for ε in terms of δ useful in science?
Solving for ε in terms of δ is useful in understanding the relationship between two variables. It can also help in predicting the effect of a small change or error (represented by ε) on the overall outcome of an experiment or equation.
  • Topology and Analysis
  • STEM Educators and Teaching
