Normal and shear stress distribution due to shear force and bending
In summary, the conversation discusses a student seeking help with a repeat exam and their attempts at solving questions related to bending moments and shear stress distribution. They share their attempts and ask for guidance, with one person pointing out mistakes and offering advice while another suggests using a tabular form for calculations. The student mentions getting help from someone on Fiverr and expresses gratitude for the support.
beamsandthangs
Hi guys, I have a repeat exam in 10 days and I have a couple of things which I would appreciate if you would help me with.
I have attached the mock exam and my attempt at question 2. I will describe where I have issues below.
For the FIRST question, I have the equation: Sigmaz= N/A + MxY/Ix - MyX/Iy.
I understand how to proceed with the question if the bending moment were to point at one direction (x or y axis), but when it is at an angle I get confused and I'm unable to proceed. Can anyone lead me to the right directions with this?
For the SECOND question, I have attached a file of my attempt at it. I understand that the units are messy, but I believe everything is correct, until the I get stuck at calculating the shear stress distribution below the Neutral Axis. I believe the diagram should curve back down and go back to zero at ''GH'', but when sum all the areas ABOVE 'GH' I do not go back to zero and the diagram does not look right. Can anyone help me proceed after this?
I am yet to attempt the THIRD question.
Attempt of question 2 is attached.
Any help will be greatly appreciated, thanks.
  • CN133- mock TEST3-2012-2013.pdf
  • question 2 .pdf
1. You are given a bending moment magnitude and told that it acts at angle β to the horizontal axis. Decompose the bending moment into its horizontal and vertical components, just like it was a force. You will have a bending moment acting about the horizontal axis and another moment acting about the vertical axis. For the stress at a particular point, use the appropriate bending stress formula for each bending moment component. Don't forget to add the two bending stresses together after these calculations (both stresses will be normal to the cross section, but may act in different directions depending on location w.r.t. the N.A. of the beam and the direction of the moment.
2. This problem is tricky because the diagram shows Vy = 400 kN, but the question text asks to calculate the shear stress distribution if Vy = 300 kN.
2. Your calculation of the Q values is incorrect. Q is the FIRST moment of area of the cross-section above the shear plane, w.r.t. the N.A. of the whole cross-section of the beam. I don't know where you got Q = A * x^2 from, and the units (cm^2 * cm^2) certainly are not cm^3.
Thank you StreamKing. I will will split the moment into vertical and bending moments and attempt the question and will post it hear if I get stuck.
In question 2, I just recalled that my lecturer made a mistake when writing out the problem. The Vy is 400Kn not 300. Also, I realized I made a mistake when calculating Q. Q= Sum of AY above the point, not AY^2... I guess I got a little confused when solving the problem.
So I've attached my attempts at questions 1 and 2.
At the first question, I've found the vertical and horizontal components (Mx, My) and put them into the equation and the answer is what I got on the bottom of the attached page, in terms of X and Y. If I put x=0, y will also be zero and vice-versa.
I've tried using values of x=1, then I get y... and then y=1, then I get x. Then I draw the x,y reference where the neutral axis is the origin. I then get a slope, draw a line across the two points and I guess that is where the normal will be equal to zero, but I'm not sure how to finish the question and I have no clue if what I'm doing is right.
At the second question, I've redone it and you will see where my issue is at the end.
I believe that the shear should be equal to zero at the top and bottom of the beam, but after the neutral axis, the Q value will increase and so and so will the shear stress along the beam, rather than go back down.
As far as I know, Q is the sum of the areas x distance from center of the individual part to the whole beam, above a certain point.
Any help please?
Thanks
  • attempt.pdf
On p. 3 of your calculations, the bottom shear stress distribution is the correct one. The shear stress is zero at the top an bottom flanges of the beam. The shear stress jumps where the flanges connect to the web, and the shear stress is a maximum at the N.A. In calculating Q, you always start at the outermost fiber and work back toward the N.A. and stop there.
On p. 1 you have made a bonehead mistake: 500 kNm = 500,000 Nm, not 50,000 Nm
Also, at the bottom of the page, your moment units are indicated as 'kNm' when clearly they should be 'Nm'
500kNm= 50,000 kNcm (kiloNewton CENTImeters). Not the most used units but I guess they are still correct.
It would help you to use a tabular form to calculate section properties:
Code:
Section properties for Problem 2:
Note:  measurements in cm
Item     A   y-bar   A*y    A*y^2        I
U-Flg   20   9.00   180.0   1620        6.667
Web      7   4.50    31.5    141.75    28.583
L-Flg   10   0.50     5.0      2.50     1.667
Total   37   5.85   216.5   1764.25    36.917
INA = 1764.25 + 36.917 - 216.5^2/37 = 534.35 cm^4
[Note:  A*y^2 = (ƩA*y)^2 / ƩA]
y-bar = 5.85 cm abv. bottom of btm. flg.
Qcd = 20*(9-5.85) = 63 cm^3
In problem 1, shouldn't you be looking for points where the combined stresses are a maximum and not zero?
Thanks steamking, the tabular form is a helpful technique!
I have paid a person on fiverr do to the questions for me in detail, he will hopefully do it tomorrow, so I guess I'm done here.
Thanks for the support :)
1. What is the difference between normal and shear stress?
Normal stress is the force per unit area that acts perpendicular to the surface of an object, while shear stress is the force per unit area that acts parallel to the surface. In other words, normal stress is the stress that squeezes or stretches an object, while shear stress is the stress that causes one layer of an object to slide past another layer.
2. How does shear force and bending affect the distribution of normal and shear stress?
Shear force and bending both cause a distribution of normal and shear stress within a material. Shear force creates shear stress, which is highest at the point of application and decreases towards the edges. Bending creates normal stress, which is highest at the edges and decreases towards the center.
3. What factors influence the distribution of normal and shear stress due to shear force and bending?
The distribution of normal and shear stress is influenced by the magnitude and direction of the applied forces, the geometry and material properties of the object, and the location and orientation of the cross-section being analyzed.
4. How can we calculate the distribution of normal and shear stress due to shear force and bending?
The distribution of normal and shear stress can be calculated using equations such as the Mohr's circle method or the Navier's method. These methods take into account the factors mentioned above and provide a visual representation of the stress distribution at different points along the object's cross-section.
5. What are some practical applications of understanding normal and shear stress distribution due to shear force and bending?
Understanding normal and shear stress distribution is crucial in designing and analyzing structures and materials, such as bridges, buildings, and aircraft. It helps engineers determine the strength and stability of these structures and make necessary modifications to ensure their safety and functionality.
