What is the mechanism behind the heating of the Earth's core?
Another idea is the gravitational pressure on other elements, but as someone pointed out this may not be a big enough effect to explain the heat.Originally posted by Jonathan I thought I heard at some point that they modeled those type of things and that the heat coming from the core was anomalous. IMO, russ should have the benefit of the doubt in expertise and for all intents and purposes he's an expert on most things, unless of course he humbly denies it.So where dooes the heat come from?So far we have seen three ideas I think. Residual compression heat from the original formation of the Earth. However I have read somewhere that it would have taken only a few (2-
  • #71
It is building very gradually just a bit in analogy like this:
http://www.astronomynotes.com/gravappl/s10.htm
The differential gravity pull of Earth and Moon as in the third figure shows an example of exchange of momentum. Similar to the process of the moon, the assymetric gravity on the previous equatorial bulge of Venus pulls the planet ahead of its orbit, resulting in a slow spiral outwards. As the radius of the orbit increases the angular momentum of its spin transfers to the orbit of the planet.
Parameters are quite different of course and the process with Venus was likely more complicated. A tidal bulge is much smaller than a planets equatorial bulge.
I propose the next process:
In case of precession, the angular momentum vector is changing direction. Looking at the vector compounds in two dimensions, transfer of momentum takes place in both dimension and back when a precession cycle is completed. The sun in the Earth precession cycle gravity interactions "takes"a proportional part of the momentum in the first stage of the precession cycle in one dimension and "gives it back" in the final stage, transferring it between the two dimensions. However it is possible that a part of the momentum vector, that of the core, is getting misaligned. Then this process of transferring momentum between the dimensions is only taking place on the mantle part of the angular momentum. With diverging vectors the numerical vector is always less than that of the components. When the core and mantle realign in a chaotic process, dissipating a lot of energy, then the momentum at that moment is fixed at a lesser value and when the gravity interaction "gives" momentum back, it is still proportional, to the lesser value. So not all spinning momentum is retransferred. An this went on for millions perhaps billions of years repeating the process about every 100,000 years.
  • #72
Well, as I had said, the article I had read told of the precession acting in a manner as to Cool the Earth, the (suspected) 'plating' being evidence of a cooling process occurring at present.
Slowing that down would simply slow down the Cooling, but does not generate enough heat to melt out the surface, not to the best of my knowledge.
As for your invocation of a need of 'dimensionality', matter is in 3 D, acts in 3 D, unless you can demonstrate your 'dimensional crossing' as a realistic method of what, "energy transfer" you said?
Sound like you have it all worked out in your head, if it is the right answer, others will recognize it/that, otherwise you'll probably find lots of people telling you you need to learn 'this' 'that' 'something else'...
  • #73
FYI
I had seen this article published May 8th somewhere else,
http://www.nature.com/nsu/030505/030505-5.html
Potassium heated Earth's core
"The iron-rich core contains lots of radioactive potassium, which generates heat as it decays, say V. Rama Murthy, of the University of Minnesota in Minneapolis, and colleagues. This supplements the heat still in the Earth's bowels from its fiery formation 4.5 billion years ago."
Now I see a new article, 10 December 2003:
http://www.berkeley.edu/news/media/releases/2003/12/10_heat.shtml
Radioactive potassium may be major heat source in Earth's core
excerpt
"Balancing the heat generated in the core with the known concentrations of radiogenic isotopes has been difficult, however, and the missing potassium has been a big part of the problem. One researcher proposed earlier this year that sulfur could help potassium associate with iron and provide a means by which potassium could reach the core.
The experiment by Lee and Jeanloz shows that sulfur is not necessary. Lee combined pure iron and pure potassium in a diamond anvil cell and squeezed the small sample to 26 gigapascals of pressure while heating the sample with a laser above 2,500 Kelvin (4,000 degrees Fahrenheit), which is above the melting points of both potassium and iron. She conducted this experiment six times in the high-intensity X-ray beams of two different accelerators - Lawrence Berkeley National Laboratory's Advanced Light Source and the Stanford Synchrotron Radiation Laboratory - to obtain X-ray diffraction images of the samples' internal structure. The images confirmed that potassium and iron had mixed evenly to form an alloy, much as iron and carbon mix to form steel alloy.
In the theoretical magma ocean of a proto-Earth, the pressure at a depth of 400-1,000 kilometers (270-670 miles) would be between 15 and 35 gigapascals and the temperature would be 2,200-3,000 Kelvin, Jeanloz said.
"At these temperatures and pressures, the underlying physics changes and the electron density shifts, making potassium look more like iron," Jeanloz said. "At high pressure, the periodic table looks totally different."
"The work by Lee and Jeanloz provides the first proof that potassium is indeed miscible in iron at high pressures and, perhaps as significantly, it further vindicates the computational physics that underlies the original prediction," Bukowinski said. "If it can be further demonstrated that potassium would enter iron in significant amounts in the presence of silicate minerals, conditions representative of likely core formation processes, then potassium could provide the extra heat needed to explain why the Earth's inner core hasn't frozen to as large a size as the thermal history of the core suggests it should."
Jeanloz is excited by the fact that theoretical calculations are now not only explaining experimental findings at high pressure, but also predicting structures.
"We need theorists to identify interesting problems, not only check our results after the experiment," he said. "That's happening now. In the past half a dozen years, theorists have been making predictions that experimentalists are willing to spend a few years to demonstrate." "
  • #74
I have read that the usual "leap second" correction that has been added almost yearly for the last 20 years to make up for the difference in the Earth's rotation versus the atomic clock standard has not been required in the last five years.
Would this imply that the Earth's rotation has increased? Could this be due to a contraction of the Earth's core? If so would this cause tension along tectonic plates and an increase in earthquake activity?
I would be pleased to read the groups thoughts about the questions posed here.
  • #75
Perhaps you should start a new thread on it??
  • #76
The Earth's solid core is supposed to be spinning a bit faster than the crust/mantle daily 2/3 second x 365 days in a year means the inner core is gaining on the outer part of the planet about 4 minutes!
http://www.columbia.edu/cu/1996/0830/d.html
"The inner core rotates in the same direction as the Earth and slightly faster, completing its once-a-day rotation about two-thirds of a second faster than the entire Earth. Over the past 100 years that extra speed has gained the core a quarter-turn on the planet as a whole, the scientists found. Such motion is remarkably fast for geological movements -- some 100,000 times faster than the drift of continents, they noted. The scientists made their finding by measuring changes in the speed of earthquake-generated seismic waves that pass through the inner core. "
  • #77
Thanks for the backup of what was said, on the previous page (7)
  • #79
Originally posted by Nereid
This question (or something very similar) was also raised in the Astronomy board:
https://www.physicsforums.com/showthread.php?s=&threadid=11993
Followed the links nice articles, but not really about the "heating of the Earth's core", now is it, it is about time, and there is another thread somewheres on the same subject...time...
  • #80
Mr Parsons wrote: but not really about the "heating of the Earth's core", now is it, it is about time, and there is another thread somewheres on the same subject...time...
However, the topic of the 'leap seconds', and their possible relationship to the Earth's rotation rate, plate tectonics, etc was the subject of several posts just a little earlier ...
  • #81
Yup, one rotation more, about every 400 years, no doubt there are friction forces there, but the addition to the heating, from that, well, we would need "do the Math" to know better just how accountable that factor is...
As for the rest...?
(Hint..."Fuse Ball")
  • #82
Livermore scientists unveil melting point of iron
http://www.eurekalert.org/pub_releases/2004-01/dlnl-lsu012104.php
LIVERMORE, Calif. -- Two scientists at Lawrence Livermore National Laboratory have discovered that iron in Earth-core conditions melts at a pressure of 225 GPa (or 32 million pounds per square inch) or about 5,100 kelvins (8,720 degrees Fahrenheit).
Determining the melting point of iron is essential to determine the temperatures at core boundaries and the crystal structure of the Earth's solid inner core. To date, the properties of iron at high pressure have been investigated experimentally through laser-heated diamond anvil cells, shock compression techniques and theoretical calculations...
  • #83
Very late into this topic. But I have another theory concerning the presence issue of heat at the Earth's core.
The Moon.
That is because the Moon's tidal influence on the Earth does not end at the ocean floors. For just as the Moon orbits around the Earth, the Earth in its turn is effectively wobbled on its axis by the moon.
I do not have the exact figures regarding the Earth's rotational displacement, but like water that rolls around the inside of a glass when you give it a little circular momentum, so too the Moon causes the Earth's liquid interior to wobble and occilate in line with the Moon's passing.
I have never seen a model for this interaction, but I would be pretty sure that such an effect generates side-real friction tides inside the Earth's core, which in turn generate heat between the zones.
As for comparison to Venus and Mars, well we should include Mercury in this scenario, because then we can note that only the Earth has such a sizable moon in orbit around it.
So, maybe just maybe the Moon is the hidden factor in all of this.
Aqua
  • #84
I also add this link to some interesting stuff about the Moon.
http://www.enviroliteracy.org/subcategory.php/242.html
Aqua :smile:
  • Classical Physics
  • Earth Sciences
  • Astronomy and Astrophysics
  • Other Physics Topics
9K
  • Mechanical Engineering
