Register to reply
Different infinities problem
by sludger13
Tags: infinities
Share this thread:
sludger13
#19
Jun10-14, 04:21 PM
P: 75
I need some proof that division of two infinitesimal values in hyperreal numbers is a real value. That's what I can't see intuitively, but my theory is based on the opposite.
However, I thought there is such proof in [itex]\mathbb{R}[/itex] - that is probably false, just because there are no infinitesimal values in [itex]\mathbb{R}[/itex]. Also such operations like:
[itex]\frac{\varepsilon^{2}}{\varepsilon}[/itex] = infinitesimal, because = [itex]\varepsilon[/itex]
are only predicted from the behavior of real values (basically we don't know whether this relation works with infinitesimal values (and it's irrelevant) - those relations are postulated from [itex]\mathbb{R}[/itex]). No problem with that [itex]\mathbb{R}^{*}[/itex] definition, it is probably the easiest way. I can just define infinitesimals another way.
I can probably every value from different infinity ([itex]f(x)[/itex],[itex]\frac{\mathrm{d} f(x)}{\mathrm{d} x}[/itex],[itex]\frac{\mathrm{d^{2}} f(x)}{\mathrm{d} x^{2}}[/itex]...) consider on different [itex]\mathbb{R}[/itex] number axis. I just cannot make any comparisons of those axes (I cannot compare them as two real, equal axes). The assumption is that all values from one axis are just [itex]0[/itex] in higher axis.
As for [itex]\frac{\varepsilon^{2}}{\varepsilon}=\varepsilon[/itex], I'm doing exactly the same. I just postulate "miraculous transition" of [itex]\varepsilon[/itex] value to another number axis (let's say it's decreasing from higher axis). Then I divide real numbers. Also this theory is quite similar to [itex]\mathbb{R}^{*}[/itex] (if it is not the same).
The entire graph (like in my first post) corresponds to one real axis. All single values from other lower axes are then [itex]0[/itex] in that graph.
The advantage of this theory for me is, that I can nicely imagine the impossibility of transition from one number axis (from one infinity) to another number axis (to another infinity).
As for the slope of tangent in the graph - the problem would be solved if I defined the slope in the graph as [itex]\int (\frac{\mathrm{d} f(x_{1})}{\mathrm{d} x_{1}}=0)dx[/itex]. This integral expresses every tangent slope ([itex]C(int)\in \mathbb{R}[/itex] - some solution of integral expresses every tangent).
I haven't redefined much, much other stuff so far. I shall see later whether this theory would be sufficiently consistent and transparent for me.
WWGD
#20
Jun10-14, 04:47 PM
P: 597
Quote Quote by sludger13 View Post
Use the sequence definition of hyperreals, and the definition of division in it, applied to infinitesimals.
pwsnafu
#21
Jun10-14, 06:51 PM
Sci Advisor
P: 834
That is true. I never understood what math really is. I'm mainly trying to avoid an approach that math is something unreal. I'm trying to unify my view to "math" and "physics" to the one and only reality.
There are different ways in which something can be "real" in reality. A unicorn is not real because we don't have a living specimen. The concept of unicorns is real because we can define it with words. Mathematics, like "honor" or "congress", falls in the latter.
Ultimately, I have no problem with this. As every infinitesimal value can be expressed only as [itex]0[/itex] in [itex]\mathbb{R}[/itex], the definition with [itex]0[/itex] is correct.
Infinitesimals are defined as numbers which satisfy ##0<x<r## for every real number ##r>0##. You can't express (or represent) infinitesimals with 0 because it means ##0\neq0##.
There are two ways to obtain infinitesimals
  1. Add elements to the reals (hyperreal method)
  2. Strengthen the axioms of the reals in order to distinguish infinitesimals (Internal Set Theory method)
In neither case does 0 represent an infinitesimal.
Afterwards I don't see the meaning of limit in that definition.
Do you even know the epsilon-delta definition of limit?
Why isn't there just written zero changes, but is there used limit?
Because they are different.
After all, the subtraction of two, above all limits near values is always [itex]0[/itex] in [itex]\mathbb{R}[/itex].
If you mean the numerator in the definition of derivative, that is always non-zero for non-constant functions.
Serious question, when your teacher showed you the definition, didn't you do any exercises where you calculate the derivative using first principles?
The definition with limit is correct, but why cannot be the definition simply with [itex]0[/itex] changes?
Taking the limit to zero is not the same thing as substituting in zero.
This forum is not the place for original research.
More to the point, you have severe misunderstandings about what is going on.
If there are no infinitesimal values, I would answer that the number axis is not differentiable.
That the number axis is continuous - so the limit derivation definition can be applied.
An axis is a line which we use to orient the Cartesian coordinate system. It has nothing to do with calculus.
If you want to know why we use the reals to do calculus with, it is because the reals are Dedekind-complete (that means: any subset of the reals which is bounded above has a least upper bound).
sludger13
#22
Jun11-14, 06:37 AM
P: 75
Quote Quote by pwsnafu View Post
Because there exists such an arrangement of matter that creates a statue of unicorn, or a movie with moving unicorn, or a brain structure that can somehow imagine unicorn. The concept of unicorn is real because there exists an arrangement of matter that we can define as unicorn.
Yes, I know that. I have no problem with limit derivation definition.
In neither case does 0 represent an infinitesimal... Because they are different... If you mean the numerator in the definition of derivative, that is always non-zero for non-constant functions.
Because it's defined so. I'm suggesting that in physical reality there is no meaning that e.g.:
##\varepsilon =infinitesimal,\frac{\varepsilon^{2} }{\varepsilon}=\varepsilon##
What definition do you mean? You mean the limit derivation definition? What exercises do you mean?
I thought that we use reals because real numbers have meaning in physical reality.
jbriggs444
#23
Jun11-14, 07:10 AM
P: 957
It's just a name. The "real" numbers are not real in the ordinary sense of the word. The "natural" numbers are not natural in the ordinary sense of the word. The "imaginary" numbers are not any more imaginary than any other class of numbers. The "rational" numbers are not rational in the sense of rational thought. The "irrational" numbers are not irrational in the sense of rational thought.
The real numbers are convenient to use in our models because they have enough range and precision to match any conceivable measurement and because as a number system they are closed under the kinds of calculations that we want to perform with them.
[In practice, we may actually use IEEE floating point because we can then fit descriptions of the model numbers into a computer and because we have an entire discipline within mathematics that can deal with the quantization errors that result from this departure from the ideal models]
sludger13
#24
Jun11-14, 07:37 AM
P: 75
The "real" numbers are not real in the ordinary sense of the word...
There is an abstract meaning (either created in my brain or even "deeper" existing in physical reality) that those apples are - what we call - two. I consider that meaning as some feeling, or intuition in my brain.
micromass
#25
Jun11-14, 07:42 AM
Mentor
micromass's Avatar
P: 18,299
There is an abstract meaning (either created in my brain or even "deeper" existing in physical reality) that those apples are - what we call - two. I consider a meaning as some feeling, or intuition in my brain.
First of all, "two" is a natural number. One could indeed argue that those have a special significance. But the real numbers consist out of way more numbers than the natural numbers. In fact, most real numbers can't even be defined or described. They just exist to make our mathematical theory more beautiful. There is no reason to expect that those numbers have a special significance in the real world, much unlike numbers like two which are special.
Second, one could even argue that the natural numbers aren't so special. There are some "primitive" tribes which only recognize the numbers 1,2,3, many. Something like 4 and 6 are not distinguished. This is very much like animals see numbers.
Also, this is getting dangerously in the realm of philosophy, something that this not permitted in the math sections. But I will allow the discussion for now.
pwsnafu
#26
Jun11-14, 06:50 PM
Sci Advisor
P: 834
Almost You are getting close.
Take "honor". There is no arrangement of matter that lets you define precisely what honor is, and yet, (people claim) it is real. The key is the ability to communicate what honor is, i.e. you can define it with words, signs, logic, whatever.
This concept will come back below.
As for the "rearrange matter" definition, that's horrible when dealing with math. How do you represent the infinite dimensional vector spaces? You only have 3 dimensions to work with. What about the Banach-Taski theorem?
Because it's defined so. I'm suggesting that in physical reality there is no meaning that e.g.:##\varepsilon =infinitesimal,\frac{\varepsilon^{2} }{\varepsilon}=\varepsilon##
Real numbers don't have physical meaning either. I'll get to this in more depth below.
This:
Question: Find the derivative at x=1 of the function ##f(x) = x^2## using first principles.
Answer: Let ##h## be a real number satisfying ##h\neq0##. Then
[tex]f(1+h)-f(1) = (1+h)^2-1^2 = 1 + 2h + h^2 - 1 = 2h+h^2[/tex]
[tex]\frac{f(1+h)-f(1)}{h} = \frac{2h+h^2}{h} = 2+h[/tex]
Then taking the limit
[tex]\lim_{h\to0} \frac{f(1+h)-f(1)}{h} = \lim_{h\to0}2+h = 2.[/tex]
QED
Notice there are no infinitesimals anywhere.
Hardly. As others have said, we use it because it is convenient.
Quote Quote by micromass View Post
This is what I want to get to.
π is an irrational number. This means that it's decimal (or binary or any radix you want) representation cannot be written using finite symbols. But that's not a problem, because we can calculate the decimal representation to any degree of precision we want. In fact with hexadecimal representation the BBP formula allows us to calculate the nth digit without calculating the first n-1 digits.
Real numbers that have an algorithm to calculate the their representation are called computable real numbers. And now we have Chaitin's constant. It's real but doesn't have such an algorithm. No problem we can still define this constant using a finite string of logical symbols. This set of real numbers are the definable real numbers.
Here's the kicker: the definable reals are countable. I'm assuming you know that reals are uncountable, hence the majority of real number cannot be defined. We know they exist, somehow, but no formula, equation, sentence, paragraph, arrangement of matter, or whatever will allow us to say "this is what this number is".
And that's why physical reality is bad justification for the real numbers.
sludger13
#27
Jul18-14, 11:31 AM
P: 75
Obviously there is an arrangement of matter that represents an honor. Strictly, there has to be some brain structure representing the meaning of honor. Human's brain is probably encoded by its evolution that it recognizes some specific arrangement of matter in timespace (also that is some specific people behavior) so we consider that behavior as honorable. Brain can also store those memories (= another arrangement of brain matter) so I can recall latter, what honor is. And finally, the brain structure can also be arranged so I can slightly remember the abstract meaning of honor without any specific conscious (situation, memory) of honor.
Also an honor, like everything else, can be precisely defined by some brain structure. However I do not claim people can make that definition at this time.
There has to be brain structure representing some set of finite-dimensional vectors (i.e. when you imagine some set of numbers), never mind you can 'compare' just ##\mathbb{R}^{3}## with the universe around us.
As for infinite-dimensional vectors, man can not obviously do that. In my opinion, the point is whether one feels that IDVS is sufficiently defined. Then it's clear what am I thinking of, although it cannot be directly imagined (unlike finite-dimensional vectors). Man can define IDVS using his (intuition, logical thinking...). By that definition, the concept of IDVS is uniquely specified. Also that definition represents the abstract meaning of IDVS. When I recall that definition = another brain structure... So far I couldn't think of better answer.
Assumption:
with differentiable function, ##0## has always meaning of (what I call) lower infinity (it represents lower inf. in higher inf.). It never has the meaning of nothing.
Then this is for me the proof, that I can express the derivatives in higher infinities. That corresponds to the real slope of tangent in graph. Also just one real number axis describes the graph. In differential equations, I consider all derivatives in their highest infinity, that infinity I consider as real.
...And that's why physical reality is bad justification for the real numbers.
Nothing against it. Also part of real numbers :)
There is an abstract meaning (either created in my brain or even "deeper" existing in physical reality)...
I refer to the fact that elementary physical laws 'behaves mathematically'. Take Coulomb's law. The charged matter bahaves (= moves) according to that relation. Also does that relation exist in physical reality... or doesn't it???
micromass
#28
Jul18-14, 11:44 AM
Mentor
micromass's Avatar
P: 18,299
I think it's time to lock this thread since it's getting too close to philosophy.
Register to reply
Related Discussions
Comparing infinities General Math 1
Is the problem with dividing by zero recognizing different infinities? General Math 8
Comparing Infinities General Math 16
Why NO infinities in LQG ? Beyond the Standard Model 5
A question on infinities.... Linear & Abstract Algebra 2
