Some questions on properties of superconductors
In summary, the conversation is about superconductors and their interactions with magnetic and electric fields. The participants discuss the attraction between superconductors and ferromagnetic or paramagnetic materials, the induction of eddy currents in superconductors, and the effects of heating a superconducting disk with induced eddy currents. They also recommend searching for videos on YouTube for more information on these topics.
Crusoe
Hi all,
I was wondering if someone can explain to me whether:
1) Superconductors are attracted to originally unmagnetised ferromagnetic or paramagnetic materials?
AIUI superconductors are perfect diamagnets due to the Meisnner Effect, and magnetic attraction is due to the creation of induced magnetic moments in the above materials, which in turn produce magnetic fields which mutually attract.
2) Following on from 1, what happens if you bring a superconductor in proximity to iron filings?
3) Whether very large eddy currents can be induced in a superconductor by a changing EM field, e.g. brushing a permanent magnet past a superconductor or the superconductor being in close proximity to an AC power cable.
4) Is there a way of determining the current density and direction of eddy currents induced in a superconductor?
5) If a superconducting disk had induced eddy currents in it, and a part of it was changed to a non-superconducting state (e.g. heated up), what will happen?
Thanks.
Doc Crusoe
Search for "superconductor" on "www.youtube.com". Those videos will explain most of your questions.
Hi Doc Crusoe,
1) Superconductors are attracted to originally unmagnetised ferromagnetic or paramagnetic materials due to the Meissner Effect, which is the expulsion of magnetic fields from the interior of a superconductor. This creates a repulsive force between the superconductor and the magnetic material, causing the superconductor to be attracted to it.
2) If you bring a superconductor in proximity to iron filings, the filings will be attracted to the superconductor due to the Meissner Effect. However, if the superconductor is cooled below its critical temperature, the magnetic field will be expelled and the filings will no longer be attracted to it.
3) Very large eddy currents can be induced in a superconductor by a changing EM field. This is because superconductors have zero resistance, so they can conduct electricity without any energy loss. This allows for a large amount of current to be induced by a changing magnetic field.
4) The current density and direction of eddy currents induced in a superconductor can be determined by measuring the magnetic field around the superconductor. The direction of the magnetic field will be opposite to the direction of the induced current, and the strength of the field can be used to calculate the current density.
5) If a superconducting disk had induced eddy currents in it and a part of it was changed to a non-superconducting state, the eddy currents would decrease in strength as the resistance of the disk increases. This is because the non-superconducting part of the disk would act as a barrier to the flow of current, causing a decrease in the induced eddy currents.
I hope this helps! Let me know if you have any further questions.
1. What is superconductivity and how does it work?
Superconductivity is a phenomenon in which certain materials can conduct electricity with no resistance when cooled below a certain temperature. This is due to the formation of Cooper pairs, which are pairs of electrons that act as one unit and can move through the material without any resistance.
2. What are the properties of superconductors?
Superconductors have several key properties, including zero electrical resistance, perfect diamagnetism (repelling of magnetic fields), and the Meissner effect (expulsion of magnetic fields from the interior of the material). They also have a critical temperature at which they become superconducting and a critical magnetic field at which they lose their superconducting properties.
3. What are the types of superconductors?
There are two main types of superconductors: Type I and Type II. Type I superconductors are typically elemental metals and have a single critical temperature and magnetic field. Type II superconductors are typically alloys or compounds and have multiple critical temperatures and magnetic fields, allowing them to exhibit superconductivity in a wider range of conditions.
4. What are some real-world applications of superconductors?
Superconductors have several practical applications, such as in high-speed trains (maglev), MRI machines, particle accelerators, and sensitive scientific instruments. They also have potential uses in energy storage and transmission, as well as in quantum computing and other advanced technologies.
5. What are the challenges in utilizing superconductors?
One of the main challenges in utilizing superconductors is the need for extremely low temperatures to maintain their superconducting properties. This requires costly and complex cooling systems. Another challenge is the brittleness of many superconducting materials, which can limit their practical applications. There is also ongoing research to find new superconducting materials that can operate at higher temperatures and make them more accessible for everyday use.
  • Other Physics Topics
  • Atomic and Condensed Matter
