Sensor fusion using extended kalman filter
In summary, the conversation is about implementing sensor fusion for state estimation using EKF. The person is asking for help in choosing a plant model and measurement model for using ADXL345 accelerometers. They are also seeking advice on how to fuse data from encoders and accelerometers for a mobile robot navigation system. The states are x, y, and theta, and the person is unsure if a gyroscope is necessary for this task. The overall request is for assistance, but with proper English and effort shown by the person.
SUDHEER87
25
hi all,
m trying to implement sensor fusion of two three axis accelerometers data.can anyone help me in modelling this sensor and fusing for state estimation using EKF?
thanks in advance.!
What are the states? Measurements? And what have you done so far?
thanx 4 your kind reply..,iam just a beginner.Right now iam surveying the literature regarding kalman filter.im using ADXL345 accelerometers..,kindly help me in choosing plant model and measurement model...!
thanq
can u pls help??
We can help, BUT
You need to drop the text speech. Try to use proper English. We don't expect perfect English, but we do want you to try.
You need to give us a little bit to work with. Show some work, answer problems when asked (e.g., post #2).
Do not ask us to do all of your work for you.
Do not ask us to write a book.
hi..!
Iam trying to implement a mobile robot navigation system based on extended kalman filter. I need to fuse the data from the encoders with the two accelerometer's data. The states are: Xk={x,y,theta} where x,y are the coordinates and theta is the heading angle.
Can anyone help me in fusing the data from encoders and accelerometers to get good estimate of the robot pose? And is gyroscope necessary in this??
Thanks in advance..!
What is sensor fusion using extended kalman filter?
Sensor fusion using extended kalman filter is a method used in robotics and control systems to combine data from multiple sensors to create a more accurate and reliable estimate of the system's state.
What is the difference between sensor fusion and extended kalman filter?
Sensor fusion is the process of combining data from multiple sensors, while the extended kalman filter is a specific algorithm used to perform sensor fusion and estimate the system's state.
What types of sensors are commonly used in sensor fusion using extended kalman filter?
The most commonly used sensors in sensor fusion using extended kalman filter are accelerometers, gyroscopes, and magnetometers. Other sensors such as cameras, lidar, and ultrasound can also be used depending on the application.
What are the advantages of using extended kalman filter for sensor fusion?
The extended kalman filter allows for nonlinear system models and noisy sensor data to be incorporated into the fusion process, resulting in a more accurate and robust estimation of the system's state.
What are some applications of sensor fusion using extended kalman filter?
Sensor fusion using extended kalman filter is commonly used in autonomous vehicles, robotics, navigation systems, and aerospace engineering. It can also be applied in various industrial and medical fields.
  • General Engineering
  • Materials and Chemical Engineering
