Let f be a continuous real function on a metric space X. Let
In summary, we are trying to prove that the set of all points in a metric space X where a continuous real function f is equal to 0 is a closed set. We attempt to show that the complement of this set, which consists of all points where f is not equal to 0, is open. Using the definition of continuity on a metric space, we choose a point p in this complement and show that it is an interior point. However, the author of the conversation was unable to finish the proof due to a brain hemorrhage. Another approach is suggested, which involves using the fact that the inverse image of an open set is open and the inverse image of a closed set is closed, and noting that {0} is closed
Jamin2112
986
Let f be a continuous real function on a metric space X. Let Z(f) be the set of all p in X at which f(p) = 0. Prove that Z(f) is closed.
Definition of continuity on a metric space.
Proof. We'll show that X/Z(f) = {p in X s.t. f(p) ≠ 0} is open. Choose p in X/Z(f). Since f is continuous, for every ε > 0 there exists a ∂ > 0 such that d(f(x),f(p)) < ε whenever d(x, p) < ∂.
... Unfortunately, I suffered a brain hemorrhage before I could finish this. I think I was trying to show that p is an interior point of X/Z(f). Thoughts?
I'd look into getting the brain hemorrhage treated. What might be confusing you is that you are using 'd' for the metric on R as well as on X. How about writing the metric on R as |f(x)-f(p)|<epsilon. Now pick epsilon=|f(p)|/2. Can f(x) be zero?
Another approach: if f is continuous the inverse image of an open set is open, and the inverse image of a closed set is ..., and the subset {0} of the real numbers is ... in the reals.
Hold on a sec ... Could you take a quick look at the solution on this UCLA Math website? http://www.math.ucla.edu/~elewis/Math230PDFs/Math%20230b%20HW1.pdf It's only 3 lines long and seems sketchy. How do we know that {0} is closed in our space X? If X = ℝ, then it would work out; but we're not given that.
It does not say {0} is closed in X. It's says {0} is closed in R. Therefore f^(-1)({0}) is closed in X.
1. What is a metric space?
A metric space is a set X equipped with a metric d that satisfies certain properties. These properties include non-negativity, symmetry, and the triangle inequality. The metric d measures the distance between two points in the set X, and allows for the definition of continuity and convergence of sequences in the space.
2. What is continuity?
Continuity is a fundamental concept in analysis that describes the behavior of a function at a specific point. A function f is said to be continuous at a point x if the limit of f(x) as x approaches a exists and is equal to f(x).
3. How is continuity related to metric spaces?
In metric spaces, continuity is defined in terms of open sets. A function f is continuous on a metric space X if for any open set U in the codomain, the pre-image of U under f, denoted by f-1(U), is an open set in the domain X. Intuitively, this means that small changes in the input lead to small changes in the output.
4. What are some examples of continuous functions on a metric space?
Some common examples of continuous functions on a metric space include polynomials, rational functions, and trigonometric functions. Additionally, any composition or combination of continuous functions will also be continuous.
5. What is the importance of continuity in mathematics?
Continuity is an essential concept in mathematics as it allows us to define and study important properties of functions, such as differentiability and integrability. It also plays a crucial role in the development of advanced mathematical theories and their applications in fields such as physics, engineering, and economics.
