Calculating longitude and latitude given the duration of sunset
In summary: At equinox , right? If at the equator then doesn't this mean that the arc/path of the Sun is perpendicular to the horizon? Or are you asking about the altitude of the Sun above the horizon?Yes, at the equinox. If at the equator then doesn't this mean that the arc/path of the Sun is perpendicular to the horizon? Yes, the arc of the Sun would be perpendicular to the horizon at the equinox.
andreea_a
Hello!
I've been trying to solve this problem for some time but I can't seem to find the answer.
Can you help me?
On the night of 5th april an observer watches the sunset(η = 3.5 minutes,η = correction of time). The solar disk touched the horizon at 20h 02 m 02 s and then the Sun's disk disappears below the horizon at 20h 05m 10s.
Given the distance Earth-Sun= 149,6 * 10 ^6 km and the solar radius = 696 000 km find the latitude and longitude of the place.
What I have tried so far was to write the formula for angular diameter θ = 206265d/D =>θ = 0.53 degrees.
I have thought about finding the hour angle so after that I can use this formula:
sin φ = tan(90 - H)*tan h,where φ=latitude of the observer,H = hour angle,h = altitude of the Sun which is 0 at sunset
Now my question is:how do I calculate the hour angle using that angular diameter?
Thanks in advance!
What is the kind of time given in the problem? Solar, mean solar, civil, etc?
It doesn't mention that in the problem but I am assuming it is civil time...
Draw a diagram showing the sun touching the horizon at point A (the top of the sun's disc being at point B here), and the last remnant disappearing below it at point C. ABC is a right angled triangle. Can you relate the hypotenuse to the elapsed time and determine its ratio to AB?
Since April 5th is 16 days after the equinox, you might have to make an adjustment for that.
So in that ABC triangle wouldn't AB be the diameter of the sun ? and AB/AC= sine C
The time elapsed between the moment when the Sun touched the horizon and the moment when it disappeared below it would be 20 h 05 m 10 s - 20 h 02 m 02 s = 03m 08 s.
where 'diameter' means angular diameter, the angle subtended at the observer, yes.
and AB/AC= sine C
The way I defined the points, the hypotenuse is BC.
Yes, but how does that relate to the angular 'distance' BC?
Well,then that distance BC would be the distance traveled in that 3m 8s. So should I divide that theta angle(angular diameter)by some rate of change in the altitude of the sun so I can get the time elapsed?Wouldn't that be angle C ? I thought as well about multiplying the duration of the sunset with the speed of light so I can get the side BC of the triangle.Is this a bad idea?
Yes, but compare that with the angular distance you know it would travel in 24 hours.
But how does this help me to find the latitude of the place?
You should now have the length of AB (as an angle subtended at the eye) and the length of BC (likewise). That tells you the angle ACB. How do you think that would be related to latitude at the equinox?
I guess that at equinox the side BC would be smaller but I don't know how to relate the latitude to that.What I know is that the declination is 0 and that it sets in the west. For angle ACB I've found 42,94degrees where AB=1919,25 arcseconds and BC=2817"Then what about using some cosine formula for spherical triangles with latitude and declination?
The triangle is sufficiently small that you don't need to worry about spherical effects - treat it as a planar triangle.
If at the equator, what angle would the apparent arc of the setting sun make with the horizon? What angle if at one of the poles?
At equinox , right? If at the equator then doesn't this mean that the arc/path of the Sun is perpendicular to the horizon? Or are you asking about the altitude of the Sun above the horizon? I am not sure if I understand correctly.
What about angle ACB in the right triangle ABC? Does this angle actually has to do with the rate of change in altitude of the Sun? Am I getting it wrong?
Yes, so ACB in this case is a right angle, yes?
It's the angle the apparent path of the sun makes to the horizon as it sets. Can you see how that relates to latitude? If not, consider how the plane of the equator relates to the apparent path of the sun.
At equinox,yes. The angle ACB which the Sun makes with the horizon would be 90 but that angle is actually 90-latitude so sin ACB=AB/BC becomes: cos latitude=AB/BC. But this happens at equinox. Shouldn't there be a general relation between declination,latitude and this angle ACB?
As I wrote in post #4, April 5th is 16 days after the equinox. That is not much, so it should be possible to make a relatively simple adjustment.
What angle will the setting sun's trajectory make at the equator at a solstice? What sort of function do you think will express how that angle varies over the year?
Suppose that at a particular time of year T, the setting sun makes an angle ##\phi## to the vertical at the equator. At latitude ##\theta## it makes an angle ##\theta## to the vertical at the equinox. What angle do you think it will make at latitude ##\theta## at time T?
After using some spherical trigonometry although you told me there's no need for that I've found this relationship between declination,latitude and the angle that the setting sun makes with the horizon: cos angle = sin latitude/cos declination. So at the equator at a solstice the angle is 90,right?
The Sun moves on the ecliptic 1 degree per day so I should multiply this angular velocity by the time(16 days) to find out how the declination angle changed from the equinox(0) to now (at time T) Is this correct?
Maybe - I'm not exactly sure what you're proposing. Can you put all that into actual equations?
Ok,so my idea was:ω = Δx/ΔT where ω = 0,98 degrees/per day and ΔT=16 days. From here I get the arc length made by the Sun in 16 days from the equinox. Then I calculated what fraction represents this number from the total 360) =>f = 4,35% Taking into consideration the fact that the maximum declination is 90 degrees I wrote:
f/100*90=3,92 degrees so I can deduce that from the equinox the declination changed from 0 to 3,92 degrees. Am I wrong? Please correct me if I am mistaken.
All that is saying is that 16 days is 4,35% of a year. The declination is not a linear function of that. It'll be a sine function, no? But maybe that small enough not to matter. So what do you now get for the answer?
1. How do you calculate longitude and latitude from the duration of sunset?
The process of calculating longitude and latitude from the duration of sunset involves using the formula: longitude = (duration of sunset/12) x 360 and latitude = 90 - (duration of sunset/24) x 360. This formula takes into account the fact that the Earth rotates 15 degrees per hour.
2. What is the significance of using the duration of sunset to calculate longitude and latitude?
The duration of sunset is useful in calculating longitude and latitude because it is a consistent and easily measurable parameter that reflects the Earth's rotation. By using this parameter, we can determine the position of a location on Earth without needing to measure the altitude of celestial bodies or use complex equipment.
3. Can the duration of sunset accurately determine longitude and latitude?
Yes, the duration of sunset can accurately determine longitude and latitude if the measurements are taken at the precise moment of sunset, and if the formula is used correctly. However, other factors such as atmospheric conditions and the location's position in relation to the Earth's tilt may affect the accuracy of the calculation.
4. What are some potential sources of error when using the duration of sunset to calculate longitude and latitude?
The duration of sunset can be affected by various factors such as atmospheric conditions, the location's position in relation to the Earth's tilt, and the precision of the measurement. Additionally, human error in measuring the duration of sunset or in using the formula can also lead to inaccuracies in the calculated longitude and latitude.
5. Is there a more precise method for calculating longitude and latitude?
While using the duration of sunset is a relatively simple and accessible method for calculating longitude and latitude, it may not be as precise as other techniques such as using GPS or complex astronomical calculations. However, for most practical purposes, calculating longitude and latitude from the duration of sunset can provide a reasonably accurate result.
  • Astronomy and Astrophysics
9K
