| New Reply |
Terminal Velocity of a Ball Given Velocity and Acceleration |
Share Thread | Thread Tools |
| Dec17-12, 12:05 AM | #1 |
1. The problem statement, all variables and given/known data
A steel ball is dropped from a great height. When its velocity is 20m/s its acceleration is 7.35 m/s^2. What is it's terminal velocity? 2. Relevant equations V - V_o = at F = ma (Air resistance isn't given, so I don't think drag force can be used.) 3. The attempt at a solution 1. I know the final net force must equal 0. 2. The answer is 40 m/s, but I am unsure of how to get this answer. 3. I tried calculating drag force and taking the limit as time approaches infinity, but I must be making an error. |
| PhysOrg.com |
science news on PhysOrg.com >> Hong Kong launches first electric taxis >> Morocco to harness the wind in energy hunt >> Galaxy's Ring of Fire |
| Dec17-12, 01:02 AM | #2 |
Mentor
| Dec17-12, 01:09 AM | #3 |
Well I know air resistance is proportional to velocity, but I don't see how I can find air resistance without knowing surface area, mass, density, temperature, etc.
| Dec17-12, 01:32 AM | #4 |
Mentor
Terminal Velocity of a Ball Given Velocity and AccelerationYou can find b/m for the given conditions. Then, what does v have to be if a = 0 ? BTW: Are you sure about the answer of 40 m/s ? If so, then I conclude that the air resistance follows a different law . |
| Dec17-12, 02:13 AM | #5 |
v = mg/b
1. What does b stand for? 2. I'm sure it is 40 m/s. I came up with multiple answers, but they were all smaller than 40 m/s. 3. They don't give a value for mass. (If I understand what b stands for, I may be able to figure it out.) |
| Dec17-12, 02:28 AM | #6 |
Recognitions:
The forces acting on the falling ball are gravity and air resistance, which is proportional to velocity and opposite to it.
Writing up Newton's second law, F=ma=mg-kv. The acceleration is a=g-(k/m) v. You know that a=7.35 m/s2 when v=20 m/s. Plug in: you will find k/m. The ball will reach the terminal velocity when the two forces - gravity and air resistance - cancel, that is, the acceleration is zero: g-(k/m) v=0. You know k/m, how big is v? If the given result is 40 m/s then the air resistance is taken proportional to v2. Do the same procedure, replacing v by v2. |
| Dec17-12, 02:31 AM | #7 |
Mentor
If you assume that the drag force (air resistance) is proportional to v2, you will get 40 m/s for your answer. This whole thing is essentially just working with proportiona. |
| Dec17-12, 03:57 AM | #8 |
Thank you so much! I forgot that air resistance can be proportional to v and v^2.
| Dec17-12, 09:55 AM | #9 |
a=g-kv, a is a function of veolcity(assumption) k is a constant and then we can find k, by using given data.
then find a=0, which kv=g, you can find out v which is terminal veolcity. |
| Dec17-12, 01:30 PM | #10 |
Mentor
In the given problem it appears that acceleration, as well as force, is proportional to v2 . |
| New Reply |
| Tags |
| acceleration, ball, steel, terminal, velocity |
| Thread Tools | |
Similar Threads for: Terminal Velocity of a Ball Given Velocity and Acceleration
| Thread | Forum | Replies | ||
| Terminal Velocity & Acceleration Question | Introductory Physics Homework | 12 | ||
| Terminal velocity of 20 lb bowling ball at 40,000 feet | General Physics | 7 | ||
| A reliable source for the terminal velocity of a tennis ball. | Classical Physics | 2 | ||
| Terminal velocity of a ping pong ball | General Physics | 3 | ||
| variable acceleration terminal velocity | General Physics | 11 | ||
