Geometric difference between a homotopy equivalance and a homeomorphism
In summary: Two homotopy equivalent compact manifolds without boundary that are not homeomorphic to each other.There are many such examples. The simplest is probably the sphere and the torus (which is a product of two circles). They are both compact, without boundary, and have the same homotopy type (they are both simply connected), but they are not homeomorphic.Another example is the Klein bottle and the real projective plane. They are both non-orientable compact manifolds without boundary and have the same homotopy type, but they are not homeomorphic. In summary, a homotopy equivalence between two spaces means that they can be continuously deformed into each other, but it does not necessarily mean they are
Flying_Goat
Geometrically, what is the difference between saying 'X is homotopic equivalent to Y' and 'X is homeomorphic to Y'? I know that a homeomorphism is a homotopy equivalence, but I can't seem to visualise the difference between them. It seems to me that both of these terms are about deforming spaces continuously and I don't see why(intuitively) homotopy equivalance is a weaker notion than a homeomorphism.
Quoting from wikipedia, "A solid disk is not homeomorphic to a single point, although the disk and the point are homotopy equivalent". There does not exist a continuous bijection between a point and a solid disk which stops them from being homeomorphic. Does that mean you can't 'continously shrink' a solid disk into a point? If not, then geometrically what does the fact that those two are homotopic equivalent tell us?
I am in a situation where I know the definitions, but can't see the 'picture'.
Any help would be appreciated.
Actually, the fact that there is not an isomorphism between a solid disk and a
point--by cardinality reasons, for one-- precisely shows that the two are not
homeomorphic. The fact that the solid disk (embedded in R^2, I assume) is
contractible precisely means that it _can_ be shrunk to a point within the space. Homotopy equivalent here (within R^2) does have a nice geometric interpretation:
Draw a cylinder ; fill the bottom circle into a disk, and draw a single point {p} in the
top circle. Then you can see how the solid disk can be "continuously massaged" into
the point {p}; say by shrinking the disk gradually into a point. You can think
maybe of a movie where you start with the disk and end with the point {p}, where
there are no surprises in-between.
A homotopy within an abstract topological space does not have as nice of a
geometric interpretation that I know off.
Here are two surfaces that are homotopy equivalent but not homeomorphic.
The Mobius band and the cylinder. Each can be smoothly shrunk by a homotopy to their equatorial circles. Yet one is an orientable surface and the other is not.
Similarly a solid Klein bottle is homotopy equivalent to a solid torus.
Here is a wilder example as an exercise.
Remove the z-axis and the circle of radius 1 in the xy-plane from Euclidean 3 space. Show that this is homotopy equivalent to a torus.
cute example. just visualizing it mentally, it appears that the given subspace of R^3 is homeomorphic to the normal bundle to the torus, "hence" homotopy equivalent to the torus.
note homotopy allows squashing, while homeomorphisms are bijective.
the simpler examples are also vector bundles, but on the circle. It seems any vector bundle on a space is homotopy equivalent to that space. This is just an extension of the fact that R^n for any n, is homotopy equivalent to a point.
in particular homotopy equivalent spaces need not have the same dimension, but homeomorphic ones do.
(I am just tossing this off the top of my head, and not checking the definition of homotopy carefully, but it seems ok.)
Thanks for your replies. That made a lot of sense. So a homotopy equivalence allows collapsing a bunch of points into one, such as that of a disk to a point. Homeomorphism is 'stronger' in the sense that the deformation is 'bijective'.
Deformation retractions are easier to visualize. There's a theorem that says that two spaces are homotopy equivalent if and only if they are both deformation retracts of some other space (possibly, maybe some extra hypotheses are needed here).
I think it's not too hard to see this for CW complexes if I remember right, maybe using the homotopy extension property for CW pairs or some such thing, but I would have to think a bit to remember how the argument goes. Too lazy for the moment.
Also, an interesting theme in more advanced topology is that often homotopy information tells you something about homeomorphism type for certain very special spaces. For example, for certain nice enough 3-manifolds, the homeomorphism type is determined by the homotopy type. For my qualifying exam, I outlined the proof of that fact. It's pretty involved.
Some other amazing examples of this happen in high dimensional topology, as with the h-cobordism theorem and the s-cobordism theorem (not exactly saying homotopy equivalent is equivalent to homeomorphic in this case, but the fact that certain maps are homotopy equivalences implies that two manifolds are homeomorphic).
Interesting homeomorphic
A couple questions
Can you give an example of two homotopy equivalent compact manifolds without boundary that are not homeomorphic?
Are there fundamental groups that determine the homeomorphism type of a manifold?
I believe two simply connected oriented differentiable 4 manifolds (compact no boundary) are homeomorphic if even the cup product forms on second cohomology are isomorphic.
I do not expect the fundamental group to determine the homeomorphism type of a manifold since I believe all smooth complex algebraic surfaces (real 4 manifolds) in CP^3 are simply connected.
Of course the homeomorphism type of compact orientable 2 manifolds with no bndry are determined by very little data, even the 1st homology group hence also the fundamental group.
I'm assuming you mean of the same dimension, otherwise, we could take any ℝ^n for two different values of n. In dimension 2, of course, among compact 3-manifolds without boundary, there's no difference between homeomorphism type and homotopy type. I should know an example for compact manifolds of the same dimension that are homotopy equivalent, but not homeomorphic, but I can't think of any concrete examples. However, the following tells me they exist.
That's roughly what Freedman's theorem says, but you need a Kirby-Siebenmann invariant to pin down the homeomorphism type (which is a Z mod 2 invariant, so it just splits it into two cases). And in this case, the intersection forms determine the homotopy type (an older theorem of Whitehead). So, the guys with the same intersection forms, but different Kirby-Siebenmann invariants are evidently homotopy equivalent, but not homeomorphic (because Freedmans theorem is an if and only if statement).
I don't think so. However, the fundamental group controls Whitehead torsion, which determines which homotopy equivalences are simple-homotopy equivalences. By playing around with handles and cobordisms and Whitehead torsion, you get the s-cobordism theorem. So, in these cases, the fundamental groups and induced maps between them will tell you that some relevant Whitehead torsion vanishes, which is one of the hypotheses you need to conclude that two ends of a suitable cobordism between the manifolds are homeomorphic.
Actually, the theorem whose proof I outlined for my qual actually says that if you have a continuous map that induces an isomorphism on the fundamental group, it is homotopic to a homeomorphism for Haken 3-manifolds, I guess (the book I used called it compact, P^2-irreducible, sufficiently large 3-manifolds). It's generally not true that just having isomorphic fundamental groups will give you a homeomorphism, although that is true for aspherical manifolds because, in that case, any isomorphism of the fundamental groups will be induced by a continuous map. A big theme in 3-manifolds is to study how the fundamental group influences the topology of the 3-manifold. For example, if the fundamental group decomposes as a free product, then, under suitable conditions, the manifold decomposes as a connected sum with each summand having the free factors as its fundamental group.
Re the intersection forms of 2n-manifolds:
If Manifolds are homeomorphic* , then their Q_M and Q_M' are equal;
homeomorphism would preserve the respective 2-homologies; a homotopy-
equivalence would be enough, actually.
But we cannot say: "if Q_M and Q_M' are equivalent, then M and M'
are diffeomorphic". : we can keep the intersections (therefore the equivalence of the Q_M's ) . Take , e.g.,
M' = M \/ (some handles with no effect on middle-dimensional homology).
Then map X' to X by collapsing those handles.
Say M = CP^2, M' = CP^2 # S^1 x S^3, the connected sum,
and map M' ---> M , and then collpase the S^1 x S^3 to a point. Then, the 2nd homology
and coh. respectively, are preserved, and so are the intersections. But, clearly, there is no homeomorphism **
* I hope poster homeomorphic did not trademark his name.
These are not compact
Oh, sorry, I forgot you wanted compact. So, you'd just need two closed manifolds of different dimensions that have the same homotopy type. It's not obvious how to do that if you don't want either to have boundary or if it's possible to do at all. But my other example works.
Freedmans theorem says the equivalence of intersection forms, plus the Kirby Siebenmann invariant implies homeomorphism. It's very important to say homeomorphism, not diffeomorphism. Actually, Freedman's theorem is a source of many exotic 4-manifolds because we have diffeomorphism invariants like Seiberg-Witten invariants that can distinguish 2-manifolds that have the same intersection form and Kirby-Siebenmann invariant.
S^1 × S^3 is not simply connected (fundamental group is Z), so Freedman's theorem doesn't apply here.
I am confused. I read that ctc wall proved that simply connected differentiable oriented 4 manifolds with isomorp-hic intersection forms on second homology are h cobordant:
http://www.maths.ed.ac.uk/~aar/papers/w4.pdfThen I thought I read in wikipedia that h cobordism implies homeomorphism in dimension 4, after freedman. What have I missed?
notice I carefully restricted my statement to homeomorphism of differentiable manifolds, hence piece - wise linear, so the kirby siebenmann invariant apparently does vanish.
Yes, that's right. Doesn't look like you missed anything.
I think that the closed manifolds must have the same dimension since homotopy equivalence implies isomorphic homology.
OK. These 4 manifold theorems seem very powerful. I will read that paper by Wall.
My question was a little different. Take a group - say the fundamental group of the Klein bottle or of the two ringed torus. How many closed manifolds without boundary can you make that have these group as fundamental groups?
Is there an easy construction that shows that there are infinitely many?
Right, the one with bigger dimension will have higher up homology groups, so, yeah, it's not possible to pull off that idea if you're talking about closed manifolds.
It's easy to construct a CW complex having any given fundamental group by taking a wedge of circles and then gluing on disks to kill the relations. For 4-manifolds, the same type of trick will work if you use handles instead of cells, but there's some subtlety there because for 3-manifolds, not every group can be realized as a fundamental group. So, you can show that there exists a 4-manifold with each fundamental group. And you can attach higher handles until it gets capped off, I think, so that it's closed without affecting the fundamental group. Then, just connect sum with a bunch of simply-connected guys, and that should give you infinitely many with the same fundamental group.
very cool. So just to get a feel for this, how do I construct a closed 4 manifold without boundary whose fundamental group is the fundamental group of the Klein bottle?
Also suppose you take a high dimensional lattice, say a 95 dimensional lattice (free abelian group). On the universal covering space of this manifold, this huge lattice must act on a simply connected 4 manifold. That would be interesting to see. Do you just add 95 copies of S^1xS^3 to the 4 sphere with 190 open balls removed?
I thought the example I gave you was the simplest possible, i.e. take as fundamental group the zero group, then there are already infinitely many 4 manifolds having that fundamental group, namely all smooth surfaces in CP^3. Once you have that it should be easy to construct infinitely many with any fundamental group, maybe by taking connected sums.
Indeed. Just wanted to make the point of how homotopy-equiv. would seem to give you a homeo., by preserving homology--therefore intersection/intersection form, fund. groups, but, one needs the strong restriction of having closedness and compactness to get up to homeomorphism.
To show how weird things can get in 4-D without strong conditions, see e.g:
http://www.intlpress.com/JDG/archive/1994/39-3-491.pdf
on these same lines I remember reading that Morse functions can be used to show that every smooth compact manifold without boundary is homotopy equivalent to a CW complex.
Why is this?
Here is a nice article on obstructions to finding a smooth complex projective algebraic variety with given fundamental group. For example the integers do not occur, nor does any free group on n generators, nor does the fundamental group of the klein bottle.
http://library.msri.org/books/Book28/files/arapura.pdf
Why is this?
Layman's version:
a morse function with one min and one max say on a sphere, says you can construct the sphere up to homotopy by starting from a point (for the min) and adding one disc (for the max).
A torus with a morse function with one min, one max, and two flex points, says it has the homotopy type of a point (the min) with a circle added (first flex), then another circle (second flex), then a disc (max).
in general, the fundamental theorem of differential equation says that between consecutive critical points, the manifold looks like a cylinder was added, so no change in homotopy (the gradient flow sweeps out the cylinder). I.e. the homotopy type is determined by the critical points.
So if you have a morse function with a finite number of critical points, you get the homotopy type of a finite cell complex, and in fact the index of the critical point tells you the dimension of the cell to add.
note that even an exotic sphere has a morse function with just two critical points. so when you attach that disc you cannot always attach it differentiably in the usual way. In fact this is apparently how one produces exotic spheres. you produce a manifold that is not an ordinary smooth sphere somehow, but that does have a morse function with only two critical points. then it is homeomorphic to a sphere.
Let B be the solid sphere of radius 2 in R^3. We can continuously deform everything outside of the sphere to the boundary of B via 2x/||x||. Now, if we make the open z-axis thicker then it will become a hole in the centre of the B. Similarly if we make the unit circle thicker than it will make the interior of B empty. The resulted space is obviously homotopic equivalent to a torus.
Thanks for your examples :shy:
mathwonk said:
Layman's version:
yes but it seems like there are piece wise homotopy equivalences as one passes from on critical point to the next. But a global homotopy equivalence requires a map of the manifold into a CW complex and another from the CW complex into the manifold that are homotopy inverses of each other.
So the Eilenberg-McLane spaces cannot be made into varieties? Are these E-M spaces all CW-complexes spaces? manifolds?
I mean, I know the trivial examples from, e.g., Wikipedia, on S^1 being a K(Z,1), etc., but I wonder if there are more general results.
A manifold that is covered by Euclidean space is EM. The homotopy sequence of the fibration verifies this since Euclidean space is contractible and the fiber is discrete.
So all Riemann surfaces except the sphere I guess. all flat Riemannian manifolds such as tori and the Kelin bottle.
For finite groups, the EM's are probably all infinite dimensional CW complexes e.g the classifying space for Z/2Z is the infinite real projective space.
  • #31
Lavinia, have you read the classical reference, Milnor's Morse Theory? This is Thm. 3.5 proved in roughly the first 24 pages. He proves that the region on the manifold "below" c+e where c is a critical value, has the homotopy type of the region below c-e with the attachment of a single cell determined by the index of the critical point with value c.
The passage from local to global you ask about may be Lemma 3.7. In it he proves that a homotopy equivalence between two spaces extends to one between the spaces obtained from them by attaching a cell.
He makes use of deformation retractions and ultimately uses Whitehead's theorem that a map is a homotopy equivalence if it induces isomorphism on homotopy groups, at least for spaces dominated by CW complexes.
  • #32
To make the CW complex that has the fundamental group of the Klein bottle, I guess you could use the Klein bottle itself, but the general construction is as follows. Start with a zero cell. Then, for each generator, attach a 1-cell to the 0-cell. So, two generators in this case. There is one relation, so that will be a word in the generators. Attach a 2-cell so that its boundary goes around each 1-cell according to that word. That will kill off that relation (and the least normal subgroup that contains it).
To do this in the case of manifolds, you can do something similar. You can think of a handle as a thickened up cell. If you want to build an n-manifold, you have to fatten up any k-cells you want to add, so that they are n-dimensional, so you cross them with an n-k-disk. That is a handle. Attaching maps get a little bit more complicated with handles than with CW complex because you need a framing of the core to figure out how to glue the thickened handle on. You won't run into any trouble getting any free group. Start with a 0-handle, which is a thickened 0-cell. Then, attach 1-handles to the boundary, one for each generator. Then, you want to add the 2-handles to kill the relations, as before. I guess you run into trouble here if you have a 3-manifold because the attaching spheres in that case are 1-dimensional and you trying to glue them along the boundary of the 3-manifold, which is a surface, so you don't have enough room to make it an embedding. I think that's the only problem you run into. So, this seems to work for 4-dimensions or higher. What you have at this point is a 4-manifold with boundary. I think you could take the dual handle-decomposition of the manifold and glue it back to itself, this time thinking of the handles as 3-handles and 4-handles. Just as adding a 3-cell will not touch the fundamental group (cellular approximation theorem), a 3-handle will not touch it. Same for 4-handles. Then, connect sum as many simply-connected guys as you want.
The manifold itself will be 95 1-handles attached to a 4-ball, plus a bunch of relations that will make every thing commute. Then, dual handles, for each of those. I'm not sure about the universal cover. I'm getting tired.
  • #33
Why is this?
I would rephrase it this way. Morse functions can be used to show that any smooth manifold can be build out of handles. Just shrink all the handles down to their cores. Unthicken them. Then, you have a CW complex.
The idea is to look a Morse function on a cobordism with only one critical point, since you can reduce it to that case, by tweaking the Morse function slightly so that none of the critical points are at the same level, and then cutting everything out except one critical point at a time. What you get is a handle of index equal to the index of the critical point (which is the number of minus signs you get when you diagonalize the Hessian or the dimension of the stable manifold when you flow along a gradient-like vector field).
You could also appeal to Whitehead's theorem that smooth manifolds admit a triangulation. I think the idea there is that a smooth manifold admits a local triangulation because it looks locally like R^n, which has an obvious triangulation. Then, somehow, I think you can subdivide enough so that you can patch together all the triangulations. Something like that. I don't know exactly how it goes.
  • #34
I guess they have to be homotopy equivalent to CW complexes, since they can be realized as CW complexes, and they are unique up to homotopy equivalence. The way you construct them is what I have been talking about. Make a wedge of spheres to get generators of the non-zero homotopy group. By the Hurewicz theorem, it's isomorphic to the homology in that dimension because all the lower homotopy groups vanish. Then, just keep attaching cells to kill off all the homotopy groups above that dimension. This doesn't give you a very concrete construction, so in the end, you don't really know what you've built. But some Eilenberg-Maclane spaces occur in nature, so to speak, like ℝP^∞, ℂP^∞, or S^1. As far as I know, those are the only naturally occurring ones. Some asked for examples of them when I first encountered them in my algebraic topology class, and the prof didn't seem to know of any other than those few examples and the abstract construction of them. Of course, maybe the term "natural occurring" doesn't have too much meaning.
  • #35
Not to go too-far off-topic, but maybe a reasonable meaning for " x being naturally-occuring" is that one is somewhat likely to either run into x or hear about it while doing research that is not too wildly unusual.
  • Topology and Analysis
