| New Reply |
EMF induced in conducting wire |
Share Thread | Thread Tools |
| Sep13-12, 08:40 PM | #1 |
We just went over Faraday's law in class and our teacher stressed how a changing flux is needed to induce an emf in some coil/loop/wire.
I was just wondering then, how is an emf induced in a straight conducting wire moving at a constant velocity in a constant magnetic field? It seems as if Δϕ=0... I think ε=vBl is the equation which is used to describe this phenomena. |
| PhysOrg.com |
physics news on PhysOrg.com >> Promising doped zirconia >> New X-ray method shows how frog embryos could help thwart disease >> Bringing life into focus |
| Sep14-12, 06:40 AM | #2 |
Recognitions:
yes. Your teacher meant that for a stationary wire, a changing flux is required to create an emf. But if the wire is moving through a magnetic field, then an emf can also be created, as you said.
| Sep14-12, 08:44 AM | #3 |
But if you have a loop of wire moving through a constant magnetic field then there is no change in flux so no induced emf.. What is the difference between a moving straight wire and a loop/coil?
| Sep14-12, 12:30 PM | #4 |
EMF induced in conducting wireA good book on motors/generators will illustrate this better than I can verbally describe things. My advice to all pondering such questions is to - draw a picture. Drawing a picture really makes things easier to understand. That is why I always like to draw a picture. It beats words by a big margin. Draw a picture. BR. Claude |
| Sep14-12, 05:55 PM | #5 |
prior posts all look ok....
Any way you can produce a change in electric potential will push charges around a closed circuit. Some explanatory viewpoints here: http://en.wikipedia.org/wiki/Induced_emf |
| Sep15-12, 04:38 AM | #6 |
Recognitions:
As I said before, if the wire is stationary, then there must be a change in flux to create an emf, but this is not true if the wire is moving. Think about the charge carriers moving through the wire. If the wire is moving (in addition to them moving along the wire), then there is an extra velocity which the charge carriers must have. And so the magnetic field will have an extra effect on the charge carriers due to the fact that the wire is moving. Or another way to think about it is that although the flux is not changing, the magnetic field is being 'swept through', as the wire moves through it. P.S. this kind of emf is called motional emf (which makes sense really). |
| New Reply |
| Tags |
| conductor, emf, flux, induction, voltage |
| Thread Tools | |
Similar Threads for: EMF induced in conducting wire
| Thread | Forum | Replies | ||
| Polarity of Induced EMF in a Conducting Ring | Classical Physics | 23 | ||
| two conducting spheres connected by conducting wire. | Introductory Physics Homework | 2 | ||
| Current carrying wire and induced electric field within the wire | Introductory Physics Homework | 2 | ||
| Rotating Conducting Cylinder in B -- Induced Voltage | Introductory Physics Homework | 3 | ||
| induced charge in conducting plate | Classical Physics | 2 | ||
