Solving the Equation y'(x) = 1/(x^N+1)
  • Thread starter Gregg
In summary: N-1}{N}}\prod _{j=0j\neq k}^{N-1} \left(e^{\frac{i}{N}(2n \pi )}-e^{\frac{i}{N}(2j \pi )}\right)} From... b_n=\frac{1}{(-a)^{\frac{N-1}{N}}\prod _{j=0j\neq k}^{N-1} \left(A^{\frac{1}{N}}e^{\frac{i}{N}(\theta +2n \pi )}-A^{\frac{1}{N}}
Gregg
459
How would I solve [tex] y'(x) = \frac{1}{x^N+1} [/tex] ?
Note that the polynomials [tex]x^{n}+1[/tex] can be factorized in terms of the nth-roots of (-1), i.e, as:
[tex]x_{j,n}=e^{i\pi\frac{1+2{j}}{n}}, i=\sqrt{(-1)}, j=0,...n-1[/tex]
You can then factorize your polynomial denominator, use fractional decomposition, and perform termwise integration.
Be particularly aware of the pitfalls involved in complex logarithms.
Let us take the case with n=4.
Then, the roots are:
[tex]x_{0,4}=e^{i\frac{\pi}{4}}=\frac{1}{\sqrt{2}}(1+i)[/tex]
[tex]x_{1,4}=e^{i\frac{3\pi}{4}}=\frac{1}{\sqrt{2}}(-1+i)[/tex]
[tex]x_{2,4}=e^{i\frac{5\pi}{4}}=\frac{1}{\sqrt{2}}(-1-i)[/tex]
[tex]x_{3,4}=e^{i\frac{7\pi}{4}}=\frac{1}{\sqrt{2}}(1-i)[/tex]
We may factorize x^4+1 into 4 complex-valued first-order polynomials:
[tex]\frac{1}{x^{4}+1}=\frac{1}{(x-\frac{1}{\sqrt{2}}(1+i))(x-\frac{1}{\sqrt{2}}(1-i))(x-\frac{1}{\sqrt{2}}(-1+i))(x-\frac{1}{\sqrt{2}}(-1-i))}[/tex]
If you wish to work with real valued polynomials, multiply together the complex conjugates, and get:
[tex]\frac{1}{x^{4}+1}=\frac{1}{(x^{2}-\sqrt{2}x+1)(x^{2}+\sqrt{2}x+1)}[/tex]
A partial fractions decompositions would then proceed as follows:
[tex]\frac{1}{x^{4}+1}=\frac{Ax+B}{(x^{2}-\sqrt{2}x+1)}+\frac{Cx+D}{(x^{2}+\sqrt{2}x+1)}[/tex]
You may then determine what A,B, C and D must be by multplying the whole equation with x^4+1, getting, by rearrangement:
[tex]0=(A+C)x^{3}+(\sqrt{2}{A}-\sqrt{2}C+B+D)x^{2}+(A+C+B-D)x+(B+D-1)[/tex]
The coefficients to each power of x must be 0, yielding:
[tex]B=D=1/2, C=-A=\frac{1}{2\sqrt{2}}[/tex]
In general, your anti-derivatives will be sums of logaritms and arctan-functions.
I see that when [itex]N[/itex] is chosen and fixed, the task can be completed with finite amount of effort. But is there more general results? Is there theory about these coefficients that you encounter in fractional decomposition?
Probably.
I don't know of it, though I'm sure a generalized result, in terms, perhaps, of a complex finite sum as a function of N has been made by somebody
I could see the cases N=2,3 etc. but Mathematica gives
[tex] \int \frac{dx}{x^N+1} = x\left({}_2 F_1 \left(\frac{1}{N},1,1+\frac{1}{N},-x^N\right)\right) [/tex]
[tex] \text{Hypergeometric2F1}(a,b,c,z) = \, _2F_1(a,b;c;z) [/tex]
And that is the closed-form solution, with a truly nasty function called Hypergeometric2F1 in its expression..
[tex] \, _2F_1(a,b;c;z) = 1+\frac{a b}{1!c}z + \frac{a(a+1)b(b+1)}{2!c(c+1)}z^2 +\cdots [/tex]
So I think it looks something like this
[tex] \, _2F_1(a,b;c;z) =\displaystyle 1+\sum _{k=0}^{\infty } \frac{\prod _{j=0}^{(k)} \frac{(a+j)(b+j)}{(c+j)}}{(k+1)!}z^k [/tex]
[tex] \int \frac{1}{x^N+1} \, dx = x\left(\displaystyle 1+\sum _{k=0}^{\infty } \frac{\prod _{j=0}^k \frac{(\frac{1}{N}+j)(1+j)}{(1+\frac{1}{N}+j)}}{(k+1)!}(-x^N)^{(k+1)}\right) [/tex]
Actually, this integral can be computer if N is integer, without using hypergeometric function.
[tex]\int \frac{dx}{x^N+ a}=\sum _{k=0}^{N-1} b_k\ln \left(x-(-a)^{\frac{1}{N}}e^{\frac{2k \pi }{N}i}\right)[/tex]
and
[tex]b_n=\frac{1}{(-a)^{\frac{N-1}{N}}\prod _{\underset{j\neq k}{j=0}}^{N-1} \left(e^{\frac{2n \pi }{N}i}-e^{\frac{2j \pi }{N}i}\right)}[/tex]
Please refer to this http://www.voofie.com/content/82/how-to-find-the-integral-of-1xna/" for step by step details.
and
Thank you, ross tang.
I mentioned, in post 2, that by using factorization by means of first order complex polynomials, you'd get a sum of complex logarithms as your answer.
It is nice to see the closed form solution in this case as well.
If N is an integer isn't this even simpler?
[tex] y=\int \frac{1}{x^N+1} dx [/tex]
[tex] y=\int (1-x^N+x^{2N}-x^{3N}+O(x^{4N})) dx [/tex]
[tex] y=x-\frac{x^{N+1}}{N+1}+\frac{x^{2N+1}}{2N+1}-\frac{x^{3N+1}}{3N+1}+O(x^{4N+1}) [/tex]
[tex] y=\displaystyle \sum_{k=0}^{\infty} \frac{x^{kN+1}}{kN+1} [/tex]
Is an infinite series simpler??
Furthermore, the anti-derivative you make there implies that |x|<1
and
How do you go from
[tex] \sum _{k=0}^{N-1} b_k\prod _{j=0j\neq k}^{N-1} \left(A^{\frac{1}{N}}e^{\frac{i}{N}(\theta +2n \pi )}-A^{\frac{1}{N}}e^{\frac{i}{N}(\theta +2j \pi )}\right)=1[/tex]
to
[tex] b_n=\frac{1}{(-a)^{\frac{N-1}{N}}\prod _{j=0j\neq k}^{N-1} \left(e^{\frac{i}{N}(\theta +2n \pi )}-e^{\frac{i}{N}(\theta +2j \pi )}\right)} [/tex]
Ah you actually go from
[tex] \sum _{k=0}^{N-1} b_k\prod _{j=0j\neq k}^{N-1} \left(A^{\frac{1}{N}}e^{\frac{i}{N}(\theta +2n \pi )}-A^{\frac{1}{N}}e^{\frac{i}{N}(\theta +2j \pi )}\right)=1 [/tex]
[tex] \Rightarrow b_n=\frac{1}{(-a)^{\frac{N-1}{N}}\prod _{j=0j\neq k}^{N-1} \left(e^{\frac{i}{N}(2n \pi )}-e^{\frac{i}{N}(2j \pi )}\right)} [/tex]
I can see
[tex] \sum _{k=0}^{N-1} b_k=\frac{1}{(-a)^{\frac{1}{N}}\prod _{j=0j\neq k}^{N-1} \left(e^{\frac{i}{N}(2n \pi )}-e^{\frac{i}{N}(2j \pi )}\right)} [/tex]
But I can't see how you get bn
@Gregg,
Have you try putting [tex]x = \sqrt[N]{A}e^{\frac{\theta +2n \pi }{N}i}[/tex]?
If you do that, you can see for every other term in the sum, i.e. when [tex] k \neq n [/tex]
[tex] b_k\prod _{\underset{j\neq k}{j=0}}^{N-1} \left(\sqrt[N]{A}e^{\frac{\theta +2n \pi }{N}i}-\sqrt[N]{A}e^{\frac{\theta +2j \pi }{N}i}\right) = 0 [/tex]
Since there is a factor of
[tex]\sqrt[N]{A}e^{\frac{\theta +2n \pi }{N}i}-\sqrt[N]{A}e^{\frac{\theta +2n\pi }{N}i}[/tex]
when j = n.
Only when k = n, the term j = n is gone, since the sum excluded the factor.
Can you write it as this?
[tex] \sum _{k=0}^{N-1} b_k=\frac{A^{\frac{1}{N}}e^{\frac{i}{N}(\theta +2n \pi )}-A^{\frac{1}{N}}e^{\frac{i}{N}(\theta +2k \pi )}}{\prod _{j=0}^{N-1} \left(A^{\frac{1}{N}}e^{\frac{i}{N}(\theta +2n \pi )}-A^{\frac{1}{N}}e^{\frac{i}{N}(\theta +2j \pi )}\right)} [/tex]
So every time that [tex] k \ne n [/tex] it is possible for [tex] j=n [/tex] and therefore a factor of zero in the product. With [tex] k=n [/tex] since [tex] j \ne k = n [/tex] there is no zero factor.
[tex] b_n=\frac{1}{\prod _{j=0k\neq j}^{N-1} \left(A^{\frac{1}{N}}e^{\frac{i}{N}(\theta +2n \pi )}-A^{\frac{1}{N}}e^{\frac{i}{N}(\theta +2j \pi )}\right)} [/tex]
Then i get
[tex] b_n=\frac{1}{ A^{\frac{1}{N}}e^{i \frac{\theta }{N}}\prod _{j=0k\neq j}^{N-1} \left(e^{\frac{(2n i \pi )}{N}}-e^{\frac{(2j i \pi )}{N}}\right)} [/tex]
[tex] b_n=\frac{1}{(-a)^{\frac{1}{N}}\prod _{j=0k\neq j}^{N-1} \left(e^{\frac{(2n i \pi )}{N}}-e^{\frac{(2j i \pi )}{N}}\right)} [/tex]
which is different so what have I missed?
I am sorry. I think my notation confused you.
I wrote this as the equation:
[tex]\sum _{k=0}^{N-1} b_k\prod _{j=0j\neq k}^{N-1} \left(A^{\frac{1}{N}}e^{\frac{i}{N}(\theta +2n \pi )}-A^{\frac{1}{N}}e^{\frac{i}{N}(\theta +2j \pi )}\right)=1[/tex]
But in fact, i really means this:
[tex]\sum _{k=0}^{N-1} \left( b_k\prod _{j=0j\neq k}^{N-1} \left(A^{\frac{1}{N}}e^{\frac{i}{N}(\theta +2n \pi )}-A^{\frac{1}{N}}e^{\frac{i}{N}(\theta +2j \pi )}\right)\right)=1[/tex]
I understand that
where do you get [tex] (-a)^{{N-1}\over{N}} [/tex] from?
I am sorry. I have little bit of typo in the answer.
It should be like this:
[tex]
\Rightarrow b_k=\frac{1}{(-a)^{\frac{N-1}{N}}\prod _{\underset{j\neq k}{j=0}}^{N-1} \left(e^{\frac{2k \pi }{N}i}-e^{\frac{2j \pi }{N}i}\right)}
[/tex]
You don't understand why there is a factor of [tex](-a)^{\frac{N-1}{N}}[/tex]. Actually it is just property of the product notation.
The step you missed is this one:
[tex]
\prod _{\underset{j\neq k}{j=0}}^{N-1} \left(\sqrt[N]{A}e^{\frac{\theta }{N}i}\left(e^{\frac{2 n \pi }{N}i}-e^{\frac{2j \pi }{N}i}\right)\right)
[/tex]
[tex]
\Rightarrow \left(\sqrt[N]{A}e^{\frac{\theta }{N}i}\right)^{N-1}\prod _{\underset{j\neq k}{j=0}}^{N-1} \left(e^{\frac{2 n \pi }{N}i}-e^{\frac{2j \pi }{N}i}\right)
[/tex]
When you take out a factor in the product sign, you are not just taking 1 factor out. Since in the product, there are N-1 factors, so you are take N-1 factors out instead. Hope you can understand.
[tex]
[/tex]
[tex]
[/tex]
[tex]
[/tex]
Ahh that is much clearer now! I didn't think about that product
Hello !
in order to find a primitive of 1/((x^N)+1), let t=x^N and z = y/x
where z(x) is the new function to find.
This leads to z as an Euler's hypergeometric integral with variable t.
Finally, back to y and x, we obtain the solution :
y = x*F(a,b;c;X) + constant
where F is the Gauss hypergeometric function (usually noted 2F1 in the hypergeometric functions classification)
a = 1
b = 1/N
c =1+(1/N)
X = -x^N
Using the general series definition of the hypergeometric function, it is easy to express y(x) in terms of a rather simple infinite series.
JJacquelin said:
Hello !
a = 1
b = 1/N
c =1+(1/N)
X = -x^N
I suggest you read post 9 by Gregg.
JJacquelin said:
Hello !
a = 1
b = 1/N
c =1+(1/N)
X = -x^N
Earlier on in the thread we found the same 2F1 solution as you did an infinite series representation aswell. A point was made about a finite series being more desireable though.
I would approach it entirely from the perspective of complex analysis:
[tex]
\begin{aligned}
\int_C \frac{dz}{z^N-1}&=\sum_{j=0}^{N-1}\int_C \frac{a_j}{z-z_j}dz\\
&=\sum_{j=0}^{N-1} a_j\log(z-z_j)\biggr|_{c_a}^{c_b} \\
&=\sum_{j=0}^{N-1} a_j\big(\log(c_b-z_j)-\log(c_a-z_j)\big)\\
\end{aligned}
[/tex]
and then ask how must the multi-valued antiderivative be interpreted so that only the end-points of the contour [itex] (c_a, c_b)[/itex], can be used in the expression above for all reasonable contours even ones which loop around multiple times. :)
Also, if it were mine, I'd check it with something real:
[tex]y'=\frac{1}{x^4+1},\quad y(0)=y_0[/tex]
Now, how does the numeric solution to that compare with all those multi-valued logarithms or hypergeometric expressions? For me, that comparison is a crucial part of doing mathematics.
Is [tex] a_j = \frac{z_j}{N} [/tex] ?
Is it supposed to be obvious?
No. It's not that. My [itex]a_j[/itex] is just the coefficients of the partial fraction decomposition. Ross in post 10 showed a compact way of computing these coefficients which he called [itex]b_n[/itex] which looks like he's using the Residue Theorem to compute: the coefficients are just the residues for each zero (pole). And my [itex]z_j[/itex] are the roots of [itex]x^N+1[/itex]. Sorry I didn't make that more clear above.
Oh right I just thought that it was since
[tex] \frac{1}{3 (z-1)}-\frac{(-1)^{1/3}}{3 \left(z+(-1)^{1/3}\right)}+\frac{(-1)^{2/3}}{3 \left(z-(-1)^{2/3}\right)} = \frac{1}{z^3-1}[/tex]
and
[tex]-\frac{1}{4(z+1)}+\frac{1}{4(z-1)}-\frac{i}{4(z+i)}+\frac{i}{4(z-i)}=\frac{1}{z^4-1}[/tex]
Hello !
All right, but of course don't directly develop in series the general hypergeometric F(a,b;c,X) function.
First, simplify it, since parameters are particular (a=1, c=1+b). It reduces into particular hypergeometric functions of lower level : Beta incomplete (in the complex range) or Lerch function.
The series development of the Lerch function directly leads to very simple series.
(i.e. : joint page)
Of course, everybody is aware that these series can be obtained on a very simple way by developing in series 1/(1+x^N) or (x^-N)/(1+x^-N) before integration.
May be apparently !
But if the finite series contains functions like log, or polylog, or etc., each of these functions is an infinite series, so, the computation would be a finite sum of infinite series. Why only one special function like hypergeometric (or better, the Lerch function in the present case) be less desirable ?
Well, this is my viewpoint. But I understand that many people prefer using more common functions than only one special function.
and
Ok then. That's interesting. I didn't know that. Perhaps it is as you indicated. Is that true for the general case? If so, sorry if I said it wasn't.
  • #31
Hello Gregg and Jackmell
Yes that's true for the general case. But with + instead of - at denominator, the general term of the series will not be real. On theoretical viewpoint, it doesn't matter : after integration the general term will be a complex logarithm. On the other hand, further simplifications will be laborious.
In order to remain in the real range, it's better to start with a similar series, but with a quadric at denominator. The integation isn't too difficult and leads to a general term including real logarithm and arctangent. (i.e.: attachement)
1. What does the equation y'(x) = 1/(x^N+1) represent?
The equation represents a first-order ordinary differential equation, where the derivative of the unknown function y with respect to the independent variable x is equal to the inverse of x raised to the N+1 power.
2. What is the purpose of solving this equation?
The purpose of solving this equation is to find the general solution for the unknown function y, which can then be used to model and understand various physical phenomena.
3. What are the possible values for N in the equation?
The value of N can be any real number, as long as it is not equal to -1. This is because the denominator of the equation cannot be equal to zero.
4. How can this equation be solved?
This equation can be solved using various methods, such as separation of variables, integrating factors, or substitution. The specific method used will depend on the form of the equation and the skills of the solver.
5. What are some real-world applications of this equation?
This equation can be used to model various physical phenomena, such as population growth, radioactive decay, and chemical reactions. It can also be applied in engineering and economics to analyze systems and make predictions.
  • Differential Equations
