What is the physical makeup of an electron?
  • Thread starter CF.Gauss
  • Tags
    Electron
In summary: CF. Vanadium 50In summary, an electron is a point particle with a negative elementary charge and a mass of about 511 \; \mathrm{keV}/c^2. It is a lepton, i.e., participates only in the electroweak interaction. When asked what something is, the most accurate description is detailing the physical properties of it, such as mass, charge, etc.
CF.Gauss
HI,
Firstly I'd like to open with I know what an electron is and I know all about its charge and the role it plays in electricity, current, free electron model etc etc.
My question is what is an electron 'made' out of? My reasoning is that it can't be made out of anything physical as its charge would distribute evenly throughout its-self and would fly apart as every part of the electron would repel every other part of the electron.
In physics the electron is thought of as a mathematical point particle but in a 3-spacial dimensional universe a 1-d object can't physically exist so that rules that out.
If i could magically enlarge an electron to the size of a car what would i physically see?
or is there even any credence to asking a question like that?
I'd like to know, too. We don't have a model of elementary particles which gives them any structure. Many people have tried to build such a model (Lorentz, Poincare, Feynman ...), but no one has succeeded. Modern Quantum Field Theory assumes that elementary particles are pointlike entities with no internal structure. Whether this is true or whether this is only an approximation is an open question. "The Feynman Lectures on Physics" Vol 2, Chapter 28 gives a very readable history of these attempts.
What exactly is a lion? If I pointed at one and said "that's a lion", wouldn't that be an acceptable answer?
What is unacceptable about pointing at an electron and saying "that's an electron?" Until you've answered that question, it will be difficult to write an answer that will satisfy you.
To conclude: To the best of our knowledge today (i.e., in this case the standard model of particle physics) the electron is an elementary spin-1/2 Dirac particle with one negative elementary charge and a mass of about [itex]511 \; \mathrm{keV}/c^2[/itex]. It's a lepton, i.e., participates only in the electroweak interaction (let alone gravitation, which acts universally on anything that has energy and momentum).
When you ask what something is, the most accurate description is detailing the physical properties of it, such as mass, charge, etc. Asking what it "really" is simply doesn't make any sense, as there is no more available information. Any answer is simply speculation.
CF.Gauss said:
My question is what is an electron 'made' out of? [...]
In physics the electron is thought of as a mathematical point particle [...]
In enlarging quantum objects one makes their quantum properties disappear. Macroscopic objects behave classically.
The electron is an elementary particle, hence not composed of anything but itself. But it is not a point - only pointlike (which means, the formal, unobservable, bare electron in the defining action is a point). Due to radiative corrections stemming from the renormalization procedure for relativistic quantum field theories, an observable, renormalized electron has a positive charge radius (though far too small to be probed experimentally with current methods).
What is the charge radius of the electron predicted to be? Order of magnitude.
CF.Gauss why do electrons not look like sparks/lightening?
I think the lightning you see is actually emission from partially ionized nitrogen and oxygen plasma.
Yes, and when I "see" anything else what am I "seeing"? Say fire for example, am I seeing fire or what.
Simular to what Vanadium 50 said "What exactly is a lion? If I pointed at one and said "that's a lion", wouldn't that be an acceptable answer?"
an electron looks like a bzzt, and feels like a bzzt, so it must be a bzzt.
This question is similar to asking what is a photon? Photons and electrons and other elementary particles are not actually little billiard balls that are flying around high speeds. They are both quantum excitations of their respective fields.
The entire universe is filled with a photon field, and it's mostly empty. You can think of it as an empty EM field as well. At every point in space there is a quantum harmonic oscillator for each possible spatial frequency, and thing about quantum harmonic oscillators is that only allowed energy levels come in steps of hw. The minimum energy of the oscillator is 3/2hw in 3 dimensions, and then it goes up to 5/2hw, then 7/2 hw, etc. One step above the zero-point level is considered one photon at that spatial frequency. The photon could have a range of frequencies, and be localized in some way, or be more spread out and less localized.
Just think of it of a field as an infinite set of harmonic oscillators at every point in space, and think of the particles as quantum vibrations of this field.
In a similar way, there is an electron field that fills of space with a zero-point energy, and it has certain linearly quantized energy levels above the zero level that indicate the number of electrons. This explains why every electron has exactly the same mass, charge, spin, and g-factor. Saying an electron is the same thing as saying a quantum vibration of the electron field, but the latter is too wordy. The electron vibration can be localized, as in a vibration around an atom, or more spread out like a free particle, or an electron in a double slit experiment.
The big difference between the electron field and the photon field is that with electron vibrations, they can't stack directly on top each other. This is described as the Pauli Exclusion rule. The electron field is a fermion field, described by the Dirac equation. Two electron vibrations can be in almost the same state very close to each other, but they can never occupy the same exact state.
I like to visual all quantum particles, whether they are photons or electrons, as 3 dimensional fuzz balls, and those fuzz balls oscillate and move around and sometimes disappear according the probabilistic laws of QFT. It's the sudden collapse of the fuzz balls that's most shocking to me, (wavefunction collapse is mysterious).
Fastman, while your explanations seems to make sense, I am hesitant to really accept it, as I've never heard of "photon fields" or "electron fields" and the like. What model is this from?
You've heard of fermionic fields though right? I just sort of made it up the terms "photon field" and "electron field" on the spot.
http://en.wikipedia.org/wiki/Fermionic_field
The electron field is just a type of fermionic field governed by the Dirac equation. That's my definition anyway. It's what helps me envision quantum field theory better.
The most disappointing aspect of the field theory is that it predicts a large zero-point energy. It's been dismissed before, but now that dark energy is around, we need some explanation for why there is a negative energy field permeating the entire universe and causing cosmic acceleration. The zero-point energy of the QFs were a candidate, but the calculations were done and it's 120 orders of magnitude larger than the measured value! That's a terrible model error.
http://en.wikipedia.org/wiki/Zero-point_energy#Gravitation_and_cosmology
Actually no. My knowledge of QFT is severely lacking. Thanks for the links by the way!
False.
There is no prediction for the charge radius of the electron. There are experimental limits suggesting that any charge radius must be smaller than some number, but the number that A. Neumaier posted is neither a prediction nor a measurement.
If you could magnify an electron to the size of a car,you would have to slow it down as well ,so as to observe the individual oscillations.
I haven't seen the paper, but according to the abstract: ''indicate the validity of the SM down to the distance of order ~10^{-17} cm and the electron charge radius of ~ 10^{-16} cm.''
Thus there seems to have been a comparison between experiment and a prediction, though the number given is maybe only a bound.
I haven't found a calculation that I could have checked, But in principle, a prediction is possible: In his book
S. Weinberg,
The quantum theory of fields, Vol. I,
Cambridge University Press, 1995,
Weinberg defines and explicitly computes in (11.3.33) a formula for the
charge radius of a physical electron. But his formula is not
fully satisfying since it is not fully renormalized (infrared
divergence: the expression contains a fictitious photon mass,
and diverges if this goes to zero, as infrared corrections from soft
photons are not accounted for). See also Section V in the
review article
M.I. Eides, H. Grotch, and V.A. Shelyuto,
Theory of Light Hydrogenlike Atoms,
Phys. Rep. 342 (2001) 63-261.
http://arxiv.org/pdf/hep-ph/0002158
where the authors says:
''According to QED an electron continuously emits and absorbs virtual
photons (see the leading order diagram in Fig. 8) and as a result its
electric charge is spread over a finite volume instead of being
pointlike''. Then they give without proof the explicit formula (28)
for the charge radius, depending logarithmically on the charge of the
central field in which the electron moves.
But according to (7.12) in Phys. Rev. D 62, 113012 (2000),
the charge radius of neutrinos, another pointlike particle, computed
from the standard model to 1 loop order, is in the range of
4...6 10^-14 cm for the three neutrino species.
Then maybe you should. You brought it up.
I don't know how to get it.
Normally when someone references a book or article that they haven't read, that pretty much ends the discussion. However, I don't want this thread to end on such a misleading note.
How does one quantify substructure? One can model an electron as a uniformly charged sphere of radius r. The sensitivity of an experiment is R if it can distinguish between a sphere of radius R and one of radius r, with r << R, but not any smaller than R. (In the interest of full disclosure, hard spheres have technical difficulties, so
Today we know that for an electron r < 10-18 or a few 10-19 meters. These numbers come from both precision measurements at low energy and a search for deviations from a point-like geometry in high energy scattering. Note that this isn't saying that an electron is a point; it's saying that it appears pointlike, but that we cannot resolve a distance smaller than about 10-18 meters.
So where does this 10-16 number come from? That's the distance at which vacuum polarization becomes important and thus where the electric field starts to depart from a ~1/r potential. This happens for all charged objects: electrons, muons, quarks It would be profoundly misleading to attribute this to electron substructure because a) it is a property of every single charged particle, not just the electron and b) happens whether the electron is fundamental or composite.
I had given references that I read and understood (Weinberg Chapter 11.3, with an explicit formula for the renormalized charge radius, though in terms of a tiny photon mass, because this kind of computations have IR divergences). Only in response to the query for an explicit value, I referred to something I couldn't access but seemed to give such a value.
I wasn't speaking of substructure in the sense of being composite, but of not having the properties of a point.
This is the case for purely theoretical reasons, a direct consequence of QED, which is generally acknowledged to be reliable in this regime. (Corrections from the standard model would be tiny and not alter the general fact.)
I didn't attribute it to electron substructure but to Weinberg's discussion in his QFT book. (One might attribute it to virtual substructure the physical electron being a composite of a bare electron and a cloud of bare virtual photons, but I don't like this sort of imagery.)
Let me complement your experimental view with the theoretical side of the matter.
The deviations from pointlikeness are usually described by means of
form factors that would be constant for a point particle but become
momentum-dependent for particles in general.
The form factors contain everything that can be observed
about single particles in an electromagnetic field.
http://en.wikipedia.org/wiki/Electric_form_factor :
''The electric form factor is the Fourier transform of electric
charge distribution in space.''
http://en.wikipedia.org/wiki/Magnetic_form_factor :
''a magnetic form factor is the Fourier transform of an electric
current distribution in space.''
In particular, the charge radius is defined as the number r such that
the electric form factor has an expansion of the form
[tex]F_1(q^2) = 1-(r^2/6) q^2[/tex] if [tex]r^2q^2<<1[/tex].
(Units are such that c=1 and hbar=1.) This definition is motivated
by the fact that the average over exp(i q dot x) over a spherical shell
of radius r has this asymptotic behavior.
See Formula (11.3.32) in
S. Weinberg,
Cambridge University Press, 1995.
QED (which treats the electron as pointlike in the usual sense of the
word - that it appears as a fundamental field in the Lagrangian) imply
a positive value for the charge radius of the electron. Indeed, this
is Weinberg's conclusion from his calculations in Section 11.3,
together with an estimate of infrared effects taken from (14.3.1).
CF.Gauss said:
What exactly is an electron?
The electron is a elementary subatomic particle with a negative elementary electric charge. It has no known components or substructure.
Observation of a single electron in a Penning trap shows the upper limit of the particle's radius is 10^−22 meters.
[tex]r_e \leq 10^{-22} \; \text{m}[/tex]
I request to make a recommendation for the Physics Forums Science Advisers to simply cite and reference a Wikipedia webpage for layman original poster (OP) subject questions, instead of referencing high level physics science papers, in order to avoid a lot of confusion and hyperbole.
Reference:
Electron - Wikipedia
electron is electron only. we are still investigating that elementary "thing". we know some of it's properties, ie. particle property, wave property, charge, mass etc. we don't know what exactly it is, only can measure some of it's characteristics, that's all
Well said lordsandman. If we ever come to understand what an electron really is then we won't need high energy machines anymore.
How do you know we don't understand what an electron really is?
How do you define "what an electron really is", without just describing its measured properties?
And even worse: How do you test this, if you cannot use any measurement by construction?
To Drakkith
Well, it depends on what understand means to those studying the issue. I suppose the words "understand" and "really" should banned from the world of physics.
ailog said:
To Drakkith
I think people should understand that we can't even know if our knowledge about something is complete. So making statements like "when we really understand" is 100% meaningless.
  • #31
How will we know when we have reached that point?
  • #32
I am not sure if you are quoting me but what I said was "If we ever come to understand what an electron really is". There's a big giant if in the statement. I don't believe we ever will and not just for the electron. The universe is too complex for our order of intelligence.
  • #33
If we are smart enough we will admit that there will always be something to learn and we will never reach that point. But I left the possibility open with an if statement. Now if I can figure out a method to create an electron out of a vacuum at my garage workbench then I'm getting closer.
  • #34
If the universe is governed by a number of laws, we can learn these laws, no matter how complex they are. Being so distant doesn't mean we will never reach.
About the OP's question, I believe he is asking about it's volume and shape, and other physical properties usually observed by eyes.
  • #35
The electron is just a static wave-form that self-reflects. The energy needed for this wave to form is the rest mass of the electron.
<h2>1. What is the size of an electron?</h2><p>The size of an electron is incredibly small, with a radius of approximately 2.8 x 10^-15 meters.</p><h2>2. What is the mass of an electron?</h2><p>The mass of an electron is approximately 9.11 x 10^-31 kilograms, which is about 1/1836th the mass of a proton.</p><h2>3. What is the charge of an electron?</h2><p>An electron has a negative charge of -1.602 x 10^-19 coulombs.</p><h2>4. What is the location of an electron in an atom?</h2><p>Electrons are located in orbitals around the nucleus of an atom. The exact location and movement of an electron cannot be determined, but its probability of being in a certain area can be calculated.</p><h2>5. Can an electron be broken down into smaller particles?</h2><p>No, an electron is considered to be an elementary particle and cannot be broken down into smaller components. It is considered to be one of the fundamental building blocks of matter.</p>
  • Electromagnetism
  • Electromagnetism
  • Quantum Physics
  • Electromagnetism
  • Beyond the Standard Models
  • Electromagnetism
  • Quantum Physics
